DMC-F20SC-BXUEOL
ממיר נחושת (100base-TX) לאופטי (100base-FX) - עד 20 ק"מ על כבל Single Mode
היכן לקנות
תאור
Media Converter DMC-F20SC-BXD and DMC-F20SC-BXU interfaces designed to convert the "twisted pair - single-mode fiber to single fiber" networks Ethernet 10/100BASE-TX and 100BASE-FX. The devices can simultaneously transmit and receive signals at 1310 nm and 1550 nm single fiber at distances up to 20 km.
Media Converter DMC-F20SC-BXD and DMC-F20SC-BXU have 1 RJ-45 twisted-pair port and 1 optical cable (SC-connector). On twisted pair port supports automatic speed modes (full duplex or half duplex), the polarity of MDI / MDI-X, which simplifies installation media converter to the existing network. The converter supports management functions such as LLCF (Link Loss Carry Forward, Link Pass Through) and LLR (Link Loss Return) for the port FX.
מאפיינים כללים
Interfaces
• Port 10/100BASE-TX
• Port 100BASE-FX single-fiber FX (plug SC)
Standards
• IEEE 802.3 10BASE-T
• IEEE 802.3u 100BASE-TX, 100BASE-FX
Wavelength
• TX: 1310nm, RX: 1550 nm, 20 km
Transfer rate
• 148,800 pps max.
Indicators
• Power, Link / Act / Speed
נתונים פיזיים
Power
• Switching Power Adapter 5V/1A
Power consumption
• Power On. (standby): 0.97 Tues
• Input Power: 1.57 W continuous power
• Maximum power input:
   - AC: 1.44 Tues
   - Constant: 2.18 Tues
Heat release
• Power On. (standby) with a variable power input 5.36 BTU / h
• Max.: 7.44 BTU / h
MTBF
• 482.583 h
Measurements
• 70 x 95 x 25 mm
Operating temperature
• 0 C ~ 50 º C
Storage temperature
• -10 ~ 70 ° C
Humidity
• Operating: 10% ~ 90%
• Storage: 5% to 90%
Certificates
• EMI: CE class A, FCC class A, VCCI class A, BSMI class A
• Safety: LVD, UL / cUL
תקנים
הורדות
איורים
DMC-F20SC-BXU/A1
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
