DWA-137EOL EOS
תאור
Wireless USB- Adapter DWA- 137 allows you to connect your computer to a high-speed wireless network and provides excellent reception. When the connection is established, you can access high speed Internet connection and start to explore the Web-pages , streaming video and music, as well as playing online games, and choose to share content for friends.
High performance
Adapter DWA- 137 delivers high performance wireless connectivity for your computer. Users can easily add a network adapter , and view Web- page , to provide shared access to files and printers , and chatting . High speed wireless connectivity extends the use of the Internet, ensuring efficient services , bandwidth intensive , such as IP-telephony , online gaming , and video streaming.
Extended range
Adapter DWA- 137 provides the ability to use a wireless connection in remote places. Antenna with high gain , which is equipped with an adapter , improves the quality of signal reception. Therefore, using DWA- 137 can connect to a wireless network at a greater distance from the router or access point , than when using conventional wireless adapter. Swiveling antenna eliminates low- band signal and improve the reception quality by fine tuning of the antenna in space. Maximize wireless performance by connecting to a wireless router 802.11n, and use a network connection anywhere in your home.
Easy to install and use
Setup Wizard D-Link makes it easy to install the USB- adapter . Technology Wi-Fi Protected Setup (WPS) provides a secure wireless connection without requiring the user to complicated settings. With this technology, no need to specify complex encryption codes manually , just press the button to connect the device to the network and configure security. Backward compatible with the 802.11g standard can be used in wireless networks with outdated equipment .
מאפיינים כללים
Interfaces
• USB 2.0
• The status indicator
• WPS Button
Safety
• Wi-Fi Protected Access (WPA ™ and WPA2 ™)
• 64/128-bit data encryption WEP "
• Wi-Fi Protected Setup
Standards
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
Frequency band
• 802.11b: from 2.4 GHz to 2.4835 GHz
• 802.11g: from 2.4 GHz to 2.4835 GHz
• 802.11n: from 2.4 GHz to 2.4835 GHz
Receiver sensitivity
• IEEE 802.11b:
-92 DBm at 1 Mbit / s
-90 DBm at 2 Mbit / s
-88 DBm at 5.5 Mbit / s
-86 DBm at 11 Mbit / s
• IEEE 802.11g:
-89 DBm at 6 Mbit / s
-88 DBm at 9 Mbits / s
-86 DBm at 12 Mbit / s
-84 DBm at 18 Mbit / s
-81 DBm at 24 Mbit / s
-77 DBm at 36 Mbit / s
-74 DBm at 48 Mbit / s
-73 DBm at 54 Mbit / s
• IEEE 802.11n:
2.4 GGts/HT-20
-89 DBm at MCS0 / 8
-86 DBm at MCS1 / 9
-84 DBm at MCS2/10
-81 DBm at MCS3/11
-77 DBm at MCS4/12
-73 DBm at MCS5/13
-72 DBm at MCS6/14
-71 DBm at MCS7/15
2.4 GGts/HT-40
-86 DBm at MCS0 / 8
-83 DBm at MCS1 / 9
-81 DBm at MCS2/10
-78 DBm at MCS3/11
-74 DBm at MCS4/12
-70 DBm at MCS5/13
-69 DBm at MCS6/14
-68 DBm at MCS7/15
Antenna
• 1 built + 1 detachable dipole with a gain of 5 dBi
Safety
• 64/128-bit WEP data encryption
• Wi-Fi Protected Access (WPA and WPA2)
Operating system
• Windows ® 8/7/Vista/XP (SP3)
Interface
• USB 2.0
