תאור
The D-Link DCS-7517 5 Megapixel H.265 Outdoor Network Camera is a high definition professional surveillance and security solution suitable for small, medium, and large enterprises. The camera features a progressive scan CMOS sensor and support for H.265 to deliver truly superior quality video in all conditions. Power over Ethernet (PoE) and a rugged, weatherproof design makes this camera extremely reliable and ideal for deployment in any surveillance application.
Built for the Outdoors
Specifically designed for outdoor environments, the DCS-7517 is IP68 certified – one of the toughest Ingress Protection (IP) ratings that is given to products tested to protect against dust and long-term water immersion. A sunshield provides added protection against the elements while blocking out glare, and various mounting options gives installers maximum flexibility for any location. Most importantly, support for Power over Ethernet (PoE) provides power and network connectivity via a single cable – making the DCS-7517 a truly versatile solution that can be used in a wide range of applications.
Advanced Monitoring with H.265 Support
In low-light situations, the IR cut filter automatically slides out of the way to use all available light. The DCS-7517 also has built-in smart IR LED illuminators with a 30-meter range, allowing the camera to keep watch even in complete darkness. To maximize bandwidth efficiency and improve image quality, the DCS-7517 provides real-time video compression using the H.265 and MJPEG codecs. The H.265 codec, or High Efficiency Video Coding (HEVC), uses the latest compression algorithms to save even more space than H.264, for better visual quality and recording performance. These features work together to give you a reliable surveillance camera capable of monitoring an area 24 hours a day – no matter the environment or the application.
Flexible Connectivity
The DCS-7517 has a built-in 802.3af compliant PoE module that simplifies installation by providing power and networking connectivity with a single cable, reducing the need to drill holes or lay additional cabling. In addition, the optional cable harness provides a group of connections such as audio input/output and digital input/output, which supports connections to external triggers such as IR sensors, switches, and alarm relays.
Robust Management Software
The DCS-7517 5 Megapixel H.265 Outdoor Network Camera includes D-ViewCam, a complete surveillance software package that enables you to view, manage, and record from up to 32 cameras on a single computer in a central location. Recordings and e-mail alerts can be triggered through motion detection or events triggered by digital input devices, keeping administrators informed of any unusual activity.
מאפיינים כללים
Hardware Profile
• 1/2.9” 5-Megapixel progressive CMOS sensor
• 30 meter smart IR illumination distance
• Built-in Infrared-Cut Removable (ICR) Filter module
• Minimum illumination:
- 0.01 lux Color mode
- 0.008 lux Black and White mode
- 0 lux Black and White mode with IR LED on
• 10x digital zoom
• Minimum object distance 0.5 m
• 2.8 to 12 mm motorized zoom varifocal DC iris lens
• Aperture: F1.4
• Angle of view (4:3):
- (H) 75° to 24°
- (V) 55° to 18°
- (D) 96° to 30°
• Shutter Speed: 1/2 to 1/10000
Camera Housing
• IP68 compliant weatherproof housing
• Included sunshield
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• 3 configurable motion detection windows
• Tamper detection
• Configurable privacy mask zones
• Configurable exposure, brightness, saturation, contrast, sharpness, white balance, WDR, de-noise, flip and mirror
• Digital Image Stabilization (DIS)
Video Compression
• Simultaneous H.265/H.264/MJPEG format compression
• H.265/H.264 multicast streaming
• JPEG for still images
Video Resolution
• 16:9 - 1920 x 1080, 1280 x 720, 720 x 576, 540 x 360, 320 x 180 at up to 30 fps
• 4:3 - 2560 x 1920, 1280 x 960, 800 x 600, 640 x 480, 320 x 240 up to 30 fps
Audio Support
• AAC
• G.711
External Device Interface
• 10/100 BASE-TX Ethernet port with PoE (Class 3)
• 1 DI / 1 DO*
• Reset button
• microSD card slot (SD/SDHC/SDXC)**
• Audio input / output*
• DC 12 V input / output
Network Protocols
• IPv6
• IPv4
• TCP/IP
• UDP
• ICMP
• DHCP client
• NTP client (D-Link)
• DNS client
• DDNS client (D-Link)
• SMTP client
• FTP client
• Bonjour
• HTTP/HTTPS
• PPPoE
• UPnP port forwarding
• RTP/RTSP/RTCP
• IP filtering
• Multicast
• CoS
• QoS
• SNMP
• ONVIF compliant
Security
• IEEE 802.1X
• Administrator and user group protection
• Password authentication
• HTTP and RTSP authentication
Event Management
• Motion detection
• Tamper detection
• Event notification and uploading of snapshots/video clips via e-mail or FTP
• Supports multiple HTTP, SMTP and FTP servers
• Multiple event notifications
• Multiple recording methods for easy backup
Remote Management
• Take snapshots/video clips and save to local hard drive
• Configuration accessible via web browser
System Requirements for Web Interface
• Operating System: Microsoft Windows 7 / 8 / 10
• Browser: Internet Explorer, Firefox, Chrome
D-ViewCam Software Functions
• Supports all management functions provided in web interface
• Viewing of up to 32 cameras on one screen
• Remote management/control of up to 32 cameras
• Scheduled motion triggered, or manual recording options
D-ViewCam System Requirements
• Operating System:
- 32-bit: Windows 8 / 7 (SP1)
- 64-bit: Windows 10 / 8 / 7 (SP1) / Server 2012 / Server 2008 R2
• Web Browser: Internet Explorer 7 or higher
• Protocol: Standard TCP/IP
Physical Parameters
Weight
• 1.54 kg (with sunshield and mounting bracket)
Dimensions
• 316.5 x 100 x 249.1 mm (with bracket)
• 223.5 x 97.5 x 90.7 mm (w/o bracket)
Power
• External power adapter: 12 V DC 1.5 A. 50/60 Hz
• PoE: IEEE 802.3af Class 3
Power Consumption
• Max: 10 watts +/- 5%
Temperature
• Operating: -40° to 50°C
• Storage: -20° to 70°C
Humidity
• Operating: 20 to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• CE LVD
• FCC
• C-Tick
* The DI/DO and Audio In/Out functions are supported via the optional cable harness.
** Camera is compatible with microSD/SDHC/SDXC cards up to v3.01. Camera is not compatible with v4.x cards.
נתונים פיזיים
תקנים
הורדות
