DCS-960LEOL EOS
תאור
The DCS-960L HD Ultra-Wide View Wi-Fi Camera boasts a horizon-wide 180° lens that easily captures your entire room, wall-to-wall, in high-quality 720p. Its rotatable head makes ceiling installations easy, and the built-in night vision, and handy mobile app empower you with knowing exactly what is happening, day or night.
Peace Of Mind With 24/7 Complete Coverage
Unlike traditional cameras, the DCS-960L uses an ultra-wide view lens to give you a full 180° eld of view, letting you cover an entire room with a single camera. Built-in de-warping technology gives you a distortion-free image, and the 720p HD sensor captures ne details with ease. Send e-mail noti cations with snapshots or video clips whenever motion or sound is detected using just the DCS-960L and an Internet connection. De ne areas of your camera’s video to monitor for motion, and set volume limits to detect when a loud sound is picked up by the camera. Night time monitoring is possible with the built-in infrared LEDs which allow for night time viewing of up to 16 feet (5 meters), enabling round-the-clock monitoring of a home or small office.
Wireless AC For Speed And Reliability
When setting up a surveillance camera, you need to make sure that it can provide smooth video wherever you decide to install it. The DCS-960L has built-in Wireless AC and takes advantage of the latest Wi-Fi technology to give you a high bandwidth connection to your router for streaming HD video from your camera, and improved range for more exible placement.
Instant Anywhere Access With mydlink Cloud Service
Enhanced with mydlinkTM support, the DCS-960L makes it easier and more convenient for you to look after your family and home or o ce environment. With a mydlink service enabled camera, you can stay connected to everything you love from anywhere, anytime. Access your camera through the mydlink website or the mydlink mobile app that lets you view and manage your camera through your tablet or mobile phone, no matter where you are.
מאפיינים כללים
Interfaces
• microSD card slot
Indicators
• Power / status
Button
• WPS button
• Reset Button
Power connector
• microUSB connector for power supply (DC)
Main characteristics
• 1 / 2.7 inch megapixel CMOS-sensor with progressive scan technology
• Focal length: 1.72 mm
• Aperture: F2.0
• Minimum distance to the object: 500 mm
• Viewing angle:
- 180 ° (horizontal)
- 120 ° (vertical)
- 180 ° (diagonal)
• Minimum illumination:
- Color mode: 0.5 lux
- Black and white mode: 0.1 lux
- Black-and-white mode with infrared illumination: 0 Lux
• Distance infrared light: 5 m
• Built-in ICR filter
• 8x digital zoom
• Eliminating image distortion
• Built-in microphone
Specifications image
• Setting the image size and quality, frame rate and bit rate
• Adjust the brightness, contrast, sharpness, color saturation and hue
• Customizable windows for motion detection
• Time stamp and text insertion
Video compression
• Compression formats H.264 / MJPEG
• JPEG for still pictures
Video resolution
• 1280 x 720, 800 x 600, 720 x 480, 640 x 480, 640 x 360, 320 x 240 and 30 frames / s
Audio
• G.711
Network protocols
• IPv4, ARP, TCP, UDP, ICMP
• DHCP-Client
• NTP-client (D-Link)
• DNS-client
• DDNS-client (D-Link)
• SMTP-client
• FTP-client
• HTTP-server
• PPPoE
• RTP, RTSP, RTCP
• UPnP Port Forwarding
• HTTPS for configuration
• Bonjour
Security
• Protection of the Administrator account and user group
• Password authentication
• HTTP and RTSP Authentication
Wireless module
• 802.11ac / n / g / a with WEP / WPA / WPA2 encryption
• Work in the frequency bands 2.4 GHz and 5 GHz
• Wireless connection speed of up to 433 Mbit / c1 for the 5 GHz band
Event management
• Motion Detection
• Detection of sound
• Event notification and downloading still images / video clips via e-mail or FTP
Remote control
• Interface settings available through the Web-browser
Mobile device management
• mydlink Lite app for iPhone, iPad, iPod Touch, mobile devices based on Android and Windows Phone
• mydlink + app for iPad and mobile devices based on Android
System requirements for Web-based
• Operating System: Microsoft Windows 7/8/10 or Mac OS X 10.7 or higher
• Web-Browser: Internet Explorer 8, Firefox 12, Safari 6 or higher
