DNR-202LEOL EOS
תאור
		DVR DNR-202L mydlink -enabled service allows you to record four network cameras on the locally attached USB- drives. DNR-202L is an efficient and reliable device that supports the plug-and-play and intuitive Web- interface, simplifying setup and network cameras . With a wide range of management functions for IP- cameras , recording, playback and storage of video , DNR-202L provides comprehensive remote monitoring of high quality and is a good alternative obsolete surveillance systems .
		Mydlink service on your mobile device
		Thanks to the support service mydlink, DNR-202L allows users to view and remotely manage devices through mydlink -enabled Web- browser using Web- site mydlink or Web-based DVR. Additionally, the app mydlink View NVR provides access and control of the device DNR-202L with mobile devices.
		Convenient and reliable video recording
		DNR-202L allows you to manage multiple cameras , providing direct access to live video and playback of recorded data via the Internet. Full functional video management and the ability to simultaneously play and record new video characterize DNR-202L as a convenient and effective DVR . Furthermore , light weight, small size and portability of the device makes it suitable for installation in any place.
		Universal monitoring and adjustment
		Users have a wide range of options for viewing and organizing record keeping using the OSD . It may appear auxiliary user-defined camera names and status records . Also, the screen can display one or more cameras , and users can manage the interface of functional PTZ ( pan / tilt / zoom ) .
		Automatic detection cameras
		One can not imagine an easier search and configure IP- cameras. Just click auto scan , and DNR-202L detect all cameras connected to the network. Built-in buzzer DVR DNR-202L will beep when detecting each of the chambers .
		Wide functional recording
		In the DNR-202L uses a simple and intuitive interface that allows users to quickly and easily configure the general settings , including compression, resolution and frame rate for all connected cameras. When the cameras are set up, recording can be performed automatically.
מאפיינים כללים
		Video format
		• H.264/MPEG-4/MJPEG for video
		• JPEG for still pictures
		Support audio
		• G.711
		• G.726
		Reset button
		• Factory reset (press and hold for 10 seconds )
		Auto Scan button
		• Detection of IP- cameras (press and hold for 3 seconds )
		Interfaces for external devices
		• Port 10/100 BASE-TX Fast Ethernet
		• 2 USB 2.0 ports for external HDD
		Video resolution
		• 1280 x 720 (1 channel)
		• 640 x 480 (4 channels)
		Video display Modes
		• Showing 1 and 4 channels
		Recording modes
		• Scheduled , Manual , Event (Motion )
		• Continuous
		Write performance
		• 32 Mbit / s
		Playback modes
		• Time , Event , Camera
		Playback performance
		• Max . 720P for 1 channel
		Playback control
		• Play , Stop , Pause, Next , Previous , Next, Previous
		Video export formats
		• AVI
		Physical interface
		• RJ- 45 10/100 LAN Ethernet ( Auto MDI / MDIX)
		Network protocols
		• IPv4, ARP, TCP, UDP, ICMP
		• DHCP- client
		• DNS- client
		• HTTP- server
		• HTTPS
		• SMTP
		• RTP
		• RTCP
		• RTSP
		• NTP
		• UPnP
		Security
		• Password authentication for the administrator account
		Automatic logout
		• Idle timeout user configuration pages
		System requirements
		• Microsoft Windows: XP SP3, Vista, 7, 8
		• Mac OS X 10.5 or higher
		Browser requirements
		• Internet Explorer 8 or higher , Firefox 3.5 or higher , Chrome 2 or higher , Safari 4 or higher
		Support for mobile devices
		• Android
		• iOS
		Remote management
		• Create snapshots / video through a Web- browser
		• Interface settings , accessible through Web- browser
		System log
		• Status of active users
		• History of authorization
