DCS-6010LEOL EOS
מצלמת מעקב רשת עם זווית ראיה 360° ותמיכה ב mydlink
היכן לקנות
תאור
Wireless 802.11n IP-camera with a viewing angle of 360 ° DCS-6010L, Featuring a fisheye ("fish-eye"), two-megapixel sensor and a maintenance service mydlink, is the perfect solution for video surveillance of a large area
360 ° viewing angle
DCS-6010L uses lens fisheye, to provide an incredibly wide viewing angle. Just place the camera on the wall for a panoramic view room or place the camera on the ceiling of the 360-degree view of the absence of dead zones. Distortion correction function captures the image from the camera, so you can use ePTZ to zoom, remote and turn the camera images and video surveillance of a large area.
Remote access through the service mydlink
Wireless 802.11n IP-camera with a viewing angle of 360 ° DCS-6010L supports service mydlink, allowing you to access and configure the camera remotely, regardless of location. You can view the images from the camera in real time over the Web-site mydlink, or you can download the mobile application mydlink and monitor directly to your mobile device with iOS or Android. Keep the house, when you're at work or supervise work in the office while you're on the go, with the service mydlink.
Zero Configuration Mechanism
If you have a router that supports the service mydlink, is due to the mechanism Zero Configuration to install and configure DCS-6010L is not difficult. Simply connect the camera to the power adapter, and then - to the mydlink router using Ethernet-cable. The camera will be automatically added to your account. Mydlink service allows even inexperienced users to easily install and use cameras that support this service.
Ready, scalable solution for video surveillance
DCS-6010L is a standalone solution for video surveillance can record still images and video on the Micro SD card and does not require a PC or network storage.
Options for expanding video delivery including software D-ViewCam, providing the ability to manage 32 cameras, with a range of functions, including viewing of multiple cameras and automatic e-mail alert for suspicious or unusual activity.
Universal
DCS-6010L has many features that enhance the surveillance capabilities and make the camera ideal for any situation. Built-in microphone and speaker provide two-way audio alarm siren work or a specific event. DCS-6010L also supports wireless 802.11n, which allows you to place the camera anywhere without the need to run Ethernet-cable.
מאפיינים כללים
Weight
• 267 g ± 5%
External power adapter
• Input: 100-240 VAC, 50/60 Hz
• Output: 5 VDC, 1.2 A
Power consumption
• 3.9 W (max)
Temperature
• Operating: 0 to 40 C
• Storage: -20 to 70 C
Humidity
• Operating: 20% to 80% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Certificates
• CE
• CE LVD
• FCC
• C-Tick
נתונים פיזיים
Camera
Hardware profile camera
• 1/3 inch, 2-megapixel CMOS-sensor with progressive scan technology
• Minimum illumination: 2 lux
• Built-in microphone and speaker
• 10x digital zoom
• Focal length: 1.25 mm
• Aperture: F2.0
• Viewing angle:
  - 180 (horizontal)
  - 180 (vertical)
  - 180 (diagonal)
Image details
• Setting the image quality and size, frame rate and bit rate
• Correct the distortion fisheye
• Timestamps and paste text
• Adjust brightness, color saturation, contrast and sharpness
• Customizable windows for motion detection
Video Compression
• Compression formats H.264/MPEG-4/MJPEG
• H.264/MPEG-4 multicast streaming
• JPEG for still images
Video Resolution
1600 x 1200, 1200 x 900, 800 x 600, 400 x 300 up to 15 kadrov/s1
Audio support
• G.726
• G.711
Interfaces to external devices
• Port 10/100 BASE-TX Fast Ethernet
• Wireless 802.11n
• Card slot Micro SD / SDHC
Network
Network Protocols
• IPv6
• IPv4
• TCP / IP
• UDP
• ICMP
• DHCP-Client
• NTP-Client (D-Link)
• DNS-client
• DDNS-client (D-Link)
• SMTP-client
• FTP-client
• HTTP / HTTPS
• Samba-client
• PPPoE
• UPnP port forwarding
• RTP / RTSP / RTCP
• Filtering of IP-addresses
• QoS
• CoS
• Multicast
• IGMP
• ONVIF
Safety
• Security Administrator and user group
• Password authentication
• Encryption HTTP and RTSP
System control
System requirements for Web-based
Web-browser: Internet Explorer, Firefox or Chrome
Event management
• Motion detection
• Event notification and download stop-kadrov/videoklipov via email or FTP
• Support for multiple FTP and SMTP servers
• Multiple event notifications
• Several ways to backup
Remote management
• Creating and maintaining stop-kadrov/videoklipov to a local hard drive or NAS via Web-browser
• Interface settings, available through Web-browser
Support for mobile devices
• OS Windows 7/Vista/XP, PDA or mobile phone
• Mobile application mydlink mobile devices with iOS and Android
System Requirements D-ViewCam ™
• Operating System: Microsoft Windows 7/Vista/XP
• Web-browser: Internet Explorer 7 or above
• Protocol: Standard TCP / IP
The software features D-ViewCam ™
• Remote management / control of up to 32 cameras
• Viewing images on a single screen up to 32 cameras
• Supports all management functions in the Web-interface
• Recording Options for triggering a sensor or manually
תקנים
הורדות
איורים
DCS-6010L/Ax
מראה מאחורה
מראה מקדימה
מראה משמאל
דף מידע
ראה גם
