תאור
Cylindrical HD video camera for outdoor use DCS-7010L mydlink-enabled service provides round the clock surveillance. Robust housing and a powerful infrared light makes this camera ideal for outdoor surveillance around the clock.
24/7 Camera Surveillance
DCS-7010L has a megapixel sensor and can create crisp, detailed still images and high-quality video at up to 720p HD. EPTZ function, you can zoom, rotate the camera image, and view such a vast area.
Built-in ICR-filter blocks infrared light during the day to improve image quality. At night, the ICR-filter is moved to the side to use a wider range of radiation surveillance, and with a powerful infrared illumination (up to 10 meters), provides control over an object, even in complete darkness.
Design for outdoor use
Designed specifically for outdoor use, the camera DCS-7010L has a full metal weatherproof housing standard IP-66, which protects the unit from dust and rain. Port Power over Ethernet (PoE) allows you to connect to the DCS-7010L Network and provide power to the camera through a single Ethernet-cable, which simplifies installation and does not require a power outlet nearby. Bracket for wire protects cables from damage.
Remote access through the service mydlink
Cylindrical HD video camera for outdoor use supports service mydlink, allowing you to access and configure the camera remotely, regardless of location. You can view the images from the camera in real time over the Web-site mydlink, or you can download the mobile application mydlink and monitor directly to your mobile device with iOS or Android. Keep the house, when you're at work or supervise work in the office while you're on the go, with the service mydlink.
Zero Configuration Mechanism
If you have a router that supports the service mydlink, is due to the mechanism Zero Configuration to install and configure DCS-7010L is not difficult. Simply connect the camera to the power adapter, and then - to the mydlink router using Ethernet-cable. The camera will be automatically added to your account. Mydlink service allows even inexperienced users to easily install and use cameras that support this service.
Universality
DCS-7010L has many features that enhance the surveillance capabilities and make the camera ideal for any situation. To the audio input and audio output, you can connect a microphone and speaker, thus providing two-way audio, and set the camera, for example, at the entrance to the building.
מאפיינים כללים
Hardware profile camera
• 1/4-inch megapixel CMOS-sensor with progressive scan technology
• The distance IR illumination: 10 m
• Minimum illumination: 0 lux with IR lighting
• Built-in ICR-filter
• The audio input and audio output
• 10x digital zoom
• Focal length: 4.3 mm
• Aperture: F2.0
• Viewing angle:
• 47 ° (horizontal)
• 37 ° (vertical)
• 60 ° (diagonal)
Camera Body
• Weatherproof housing (standard IP-66)
• Bracket for cable
Image details
• Setting the image quality and size, frame rate and bit rate
• Timestamps and paste text
• Customizable windows for motion detection
• Configurable zone private masks
• Set the shutter speed, brightness, color saturation, contrast and sharpness
Video Compression
• Compression formats H.264/MPEG-4/MJPEG
• H.264/MPEG-4 multicast streaming
• JPEG for still images
Video Resolution
• 16:9 - 1280 x 800, 1280 x 720, 800 x 450, 640 x 360, 480 x 270, 320 x 176, 176 x 144 up to 30 frames / s ¹
• 4:3 - 1024 x 768, 800 x 600, 640 x 480, 480 x 360, 320 x 240, 176 x 144 up to 30 frames / s ¹
Audio support
• G.726
• G.711
Interfaces to external devices
• Port 10/100 BASE-TX Fast Ethernet
• Supports 802.3af PoE
• Port DI / DO
• Card slot for MicroSD / SDHC
Network Protocols
• IPv6
• IPv4
• TCP / IP
• UDP
• ICMP
• DHCP-Client
• NTP-Client (D-Link)
• DNS-client
• DNS-Client (D-Link)
• SMTP-client
• FTP-client
• HTTP / HTTPS
• Samba-client
• PPPoE
• UPnP port forwarding
• RTP / RTSP / RTCP
• Filtering of IP-addresses
• QoS
• CoS
• Multicast
• IGMP
• ONVIF
Safety
• Security Administrator and user group
• Password authentication
• Encryption HTTP and RTSP
System control
• System requirements for Web-based
• Web-browser: Internet Explorer, Firefox or Chrome
Event management
• Motion detection
• Event notification and download stop-kadrov/videoklipov via email or FTP
• Support for multiple FTP and SMTP servers
• Multiple event notifications
• Several ways to backup
Remote management
• Creating and maintaining stop-kadrov/videoklipov to a local hard drive or NAS via web-browser
• Interface settings, accessible via web-browser
Support for mobile devices
• OS Windows 7/Vista/XP, PDA or mobile phone
• Mobile application mydlink mobile devices with iOS and Android
System Requirements D-ViewCam ™
• Operating System: Microsoft Windows 7/Vista/XP
• Web-browser: Internet Explorer 7 or above
• Protocol: Standard TCP / IP
The software features D-ViewCam ™
• Remote management / control of up to 32 cameras
• Viewing images on a single screen up to 32 cameras
• Supports all management functions in the Web-interface
• Recording Options for triggering a sensor or manually
נתונים פיזיים
Weight
• 510 g ± 5%
Power
• External power adapter:
- Input: 100-240 VAC, 50/60 Hz
- Output: 5 VDC, 1.2 A
• Power over Ethernet-cable (technology PoE)
Power consumption
• 5.4 W (max)
Temperature
• Operating: -25 ° to 50 ° C
• Storage: -20 ° to 70 ° C
Humidity
• Operating: 20% to 80% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Certificates
• CE
• CE LVD
• FCC
• C-Tick
