DCS-6112VEOL EOS
מצלמת מעקב רשת עם גוף עמיד נגד נזק ונדאלי עם תמיכה ב FullHD
היכן לקנות
תאור
D-Link’s DCS-6112V Full HD Vandal-proof Fixed Dome Network Camera features industry-leading high definition (Full HD) megapixel resolution and H.264 compression that enable high-quality video footage to be recorded. The DCS-6112V connects to a network to provide high-quality live video over the Internet. The camera also features a 3-axis inner bracket that allows for flexible observation area adjustment. With the free-bundled D-ViewCam 32-channel recording software, this network camera provides a complete solution for high-quality live viewing and reliable recording. The camera also has a built-in MicroSD card slot which can be used for local backup by storing important events on an easily retrievable MicroSD card.
Full HD Surveillance
The DCS-6112V delivers Full HD 16:9 widescreen IP video surveillance which provides vivid high-quality video, making it easier to view and monitor footage.
Multiple Video Streams
The DCS-6112V supports simultaneous streaming of H.264, MPEG-4, and MJPEG video to provide both high-quality and bandwidth-efficient compression formats. H.264 produces a small file size, making it  useful for extended recording with high detail or for use in low-bandwidth networks. MJPEG delivers excellent file integrity, ideal for situations which require extensive image detail. Additionally, the DCS-6112V supports multicast H.264 streaming, allowing users to view the camera feed by subscribing to a multicast IP address on the network.
Flexible Connectivity
The DCS-6112V includes input and output ports for connectivity to external devices such as IR sensors, switches, and alarm relays. The DCS-6112V also incorporates Power over Ethernet (PoE), allowing it to be easily installed in a variety of locations without the need for supplemental power cabling.
3GPP Mobile Surveillance
Support for 3GPP Mobile Surveillance allows users to view a live video feed from a 3GPP compatible Internet-ready mobile device. This extends monitoring capabilities, allowing users to check the camera’s video feed while on the go without a computer.
Vandal and Tamper-proof
Vandal-proof and anti-tamper features make the DCS-6112V camera suitable for tamper-prone locations such as transportation hubs, schools, or correctional facilities. The robust camera housing is IK-10-certified, allowing it to withstand a high amount of force. The electronic tamper detection system can sense whenever the camera has been redirected, de-focused, blocked, or spray-painted, and respond promptly with a visible or audible alarm.
D-ViewCam for Management
The included D-Link D-ViewCam™ is sophisticated software which allows users to manage up to 32 network cameras, set e-mail alert notifications, create recording schedules, and use motion detection to record important events directly to a hard drive. D-ViewCam™ also allows users to upload a floor plan to create a realistic layout of the premises where the cameras are located, further simplifying the management process.
Viewing Window and ePTZ
Customize your Region of Interest (ROI) by simply drawing a rectangle on the full view display in the web interface software. Being able to digitally move the ROI is an advantage for a fixed camera since it can utilize the virtual auto pan along with preset point settings to display vivid details from HD video footage. The viewing window also allows you to utilize zoom to obtain more-indepth footage.
מאפיינים כללים
Key features
• 1/2 inch, 7-megapixel CMOS-sensor with progressive scan technology
• The lens is fixed focal length of 4 mm, F1.5 (horizontal viewing angle - 77,4 °)
• 16x digital zoom
• Flash-Memory 128 MB
• SDRAM, 256 MB
• Minimum illumination: 0.12 lux/F1.5
Functional videos
• Setting quality, size and speed of image transmission
• Timestamps and paste text
• Three windows to configure the motion detection
• Functions ePTZ
• 5 private masks
• Flip and mirror image
• Custom white balance, shutter speed, adjust brightness, saturation, contrast,
Video Compression
• Video compression formats H.264/MPEG4/MJPEG
• JPEG for still images
• H.264/MPEG-4 multicast streaming
Video Resolution
• 1920x1080 @ 15 fps, 1280x1024 @ 20 fps, 1280x720 @ 30 fps, 640x480 @ 30 fps, 320x240 @ 30 fps, 176x144 @ 30 fps
Audio support
• Voice compression (GCM-AMR), rate from 4.75 kbit / s to 12.2 kbit / s
• Audio Coding (MPEG-4, AAC), transfer rate: 16 kbit / s to 128 kbit / s
• Supports two-way transmission of sound and the ability to mute the sound (mute)
Network protocols
• IPv4, TCP / IP, UDP, ICMP, DHCP Client, NTP Client (D-Link), DNS Client, DDNS Client (D-Link), SMTP Client, FTP Client, HTTP / HTTPS, Samba Client, PPPoE, UPnP Port Forwarding , RTP / RTSP / RTCP, IP filtering, 3GPP, LLTD, CoS / QoS, SNMP, IGMP, 802.1x, ONVIF
Security
• Protection of the Administrator account and user group
• Authentication by password
• Digital encryption, HTTP and RTSP
• HTTPS streaming
• Control access of remote users
System requirements
• Operating System: Microsoft Windows 7/Vista/XP/2000
• Browser: Internet Explorer 6 or higher, Chrome, Firefox, Safari
System requirements for the D-ViewCam™
• Protocol: Standard TCP / IP
Event management
• Motion detection
• Detection of attempts to tamper (Tamper Detection)
• Support for multiple servers, HTTP, SMTP and FTP
• Event notification and download snapshots / video clips through HTTP, SMTP or FTP
• Multiple event notifications
• Several ways to backup
Remote management
• Setting up a Web-browser
• Obtaining snapshots / video and save to your local hard drive or NAS via Web-browser
Software features
• Remote management / control of up to 32 cameras
• View images from 32 cameras on one screen
• Supports all management functions through a Web-based interface
• Option to record the image sensor or manual operation
Support for mobile phones and software
• Mobile phone with 3GPP-player, QuickTime 6.5, Real Player 10.5, Windows 7, Vista, XP, 2000
External interfaces of the device
• One D / I-interface and a D / O-interface for external sensor and alarm
• Audio input (MIC in)
• Audio / video output (AV out)
• Switching the TV system (NTSC / PAL)
• Slot for MicroSD-card
נתונים פיזיים
Input power
• 12 Vdc 1,25 A, 50/60 Hz, 802.3af PoE
Max. power consumption
• 4.4 W
Operating temperature
• From 0 to 40 ° C
Storage temperature
• -20 To 70 ° C
Protection
• IK-10
Humidity
• 90% (no condensation)
Weight
• 572 g
Certificates
• CE (Class A), CE LVD (EN60965-1), FCC (Class A), ICES-003, C-Tick
תקנים
הורדות
איורים
DCS-6112V/Ax
מראה מקדימה
DCS-6112V/Bx
מראה מימין
מראה מקדימה
דף מידע
ראה גם
