DCS-2132LEOL EOS
תאור
Wireless 802.11n HD Camcorder "Cube" DCS-2132L mydlink-enabled service provides round the clock remote monitoring your home or office.
24/7 Camera Surveillance
DCS-2132L has a megapixel sensor and can create crisp, detailed still images and high-quality video at up to 720p HD. EPTZ function, you can zoom, rotate the camera image, and view such a vast area.
Built-in ICR-filter blocks infrared light during the day to improve image quality. At night, the ICR-filter is moved to the side to use a wider range of radiation surveillance, and with infrared illumination provides control over an object, even in complete darkness.
Remote access through the service mydlink
Wireless 802.11n HD Camcorder "Cube" supports service mydlink, allowing you to access and configure the camera remotely, regardless of location. You can view the images from the camera in real time over the Web-site mydlink, or you can download the mobile application mydlink and monitor directly to your mobile device with iOS or Android. Keep the house, when you're at work or supervise work in the office while you're on the go, with the service mydlink.
Zero Configuration Mechanism
If you have a router that supports the service mydlink, is due to the mechanism Zero Configuration to install and configure DCS-2132L is not difficult. Simply connect the camera to the power adapter, and then - to the mydlink router using Ethernet-cable. The camera will be automatically added to your account. Mydlink service allows even inexperienced users to easily install and use cameras that support this service.
Universality
DCS-2132L has many features that enhance the surveillance capabilities and make the camera ideal for any situation. PIR-sensor detects movement near the camera, allowing you to automatically record the video and send a notice in this case. Built-in microphone and speaker allow two-way communication and can be useful when used at the entrance to the building. Wireless connectivity 802.11n standard makes it easy to place the camera anywhere without running Ethernet-cable.
Ready, scalable solution for video surveillance
DCS-2132L is a standalone solution for video surveillance can record still images and video on the MicroSD card and does not require a PC or network storage device.
Options for expanding video delivery including software D-ViewCam, providing the ability to manage 32 cameras, with a range of functions, including viewing of multiple cameras, and automatic e-mail alert for suspicious or unusual activity.
מאפיינים כללים
Hardware profile camera
• 1/4-inch megapixel CMOS-sensor with progressive scan technology
• Distance of infrared light: 5 m
• Minimum illumination: 0 lux with IR lighting
• Built-in ICR-filter
• Built-in PIR (Passive infrared) sensor (5 m)
• Built-in microphone / speaker
• 10x digital zoom
• Focal length: 3.45 mm
• Aperture: F2.0
• Viewing angle:
• 57,8 ° (horizontal)
• 37,8 ° (vertical)
• 66 ° (diagonal)
Image details
• Setting the image quality and size, frame rate and bit rate
• Timestamps and paste text
• Customizable windows for motion detection
• Configurable zone private masks
• Set the shutter speed, brightness, color saturation, contrast and sharpness
Video Compression
• Compression formats H.264/MPEG-4/MJPEG
• H.264/MPEG-4 multicast streaming
• JPEG for still images
Video Resolution
• 16:9 - 1280 x 800, 1280 x 720, 800 x 450, 640 x 360, 480 x 270, 320 x 176, 176 x 144 up to 30 frames / s ¹
• 4:3 - 1024 x 768, 800 x 600, 640 x 480, 480 x 360, 320 x 240, 176 x 144 up to 30 frames / s ¹
Audio support
• G.726
• G.711
Interfaces to external devices
• Port 10/100 BASE-TX Fast Ethernet
• IEEE 802.11n
• Port DI / DO
• Card slot for MicroSD / SDHC
Network Protocols
• IPv6
• IPv4
• TCP / IP
• UDP
• ICMP
• DHCP-Client
• NTP-Client (D-Link)
• DNS-client
• DDNS-client (D-Link)
• SMTP-client
• FTP-client
• HTTP / HTTPS
• Samba-client
• PPPoE
• UPnP port forwarding
• RTP / RTSP / RTCP
• Filtering of IP-addresses
• QoS
• CoS
• Multicast
• IGMP
• ONVIF
Safety
• Security Administrator and user group
• Password authentication
• Encryption HTTP and RTSP
System control
System requirements for Web-based
Web-browser: Internet Explorer, Firefox or Chrome
Event management
• Motion detection
• Event notification and download stop-kadrov/videoklipov via email or FTP
• Support for multiple FTP and SMTP servers
• Multiple event notifications
• Several ways to backup
Remote management
• Creating and maintaining stop-kadrov/videoklipov to a local hard drive or NAS via Web-browser
• Interface settings, available through Web-browser
Support for mobile devices
• OS Windows 7/Vista/XP, PDA or mobile phone
• Mobile application mydlink mobile devices with iOS and Android
System Requirements D-ViewCam ™
• Operating System: Microsoft Windows 7/Vista/XP
• Web-browser: Internet Explorer 7 or above
• Protocol: Standard TCP / IP
Software features D-ViewCam ™
• Remote management / control of up to 32 cameras
• Viewing images on a single screen up to 32 cameras
• Supports all management functions in the Web-interface
• Recording Options for triggering a sensor or manually
