DCS-930LEOL EOS
תאור
	The camera monitor home and office
	DCS-930/930L - versatile and unique surveillance solution for small office and home. In contrast to the standard Web-cameras DCS-930/930L is a complete system with built-in CPU and web-server that transmits high quality video images for security and surveillance. Easy installation and intuitive Web-based interface offer easy integration with Ethernet / Fast Ethernet or wireless network 802.11n. DCS-930/930L also comes with remote control and motion detection for comprehensive and effective home security solution.
	802.11n wireless connectivity
	DCS-930/930L wireless interface supports 802.11n, and thus a simple integration into existing network. Wireless N technology enables high quality video streaming to remote sites or mobile devices. Site Survey feature also allows you to view and easily connect to nearby wireless networks. DCS-930/930L has an Ethernet port for connection to traditional wired networks.
	Mydlink utility for quick and easy access to the video (DCS-930L)
	A convenient utility mydlink ™ you can quickly set the camera DCS-930L, then register it on the web-site mydlink ™. DCS-930L will then automatically configure and connect to the service mydlink ™ for easy access to video from anywhere on the Internet.
	Easy setup and ease of use
	Network Camera supports Plug-n-Play, which allows computers running Windows XP/Vista/7 automatically recognize the camera and add it to the network. By subscribing to one of the free servers, DDNS, you can set the camera domain name (for example, mycamera.dlinkddns.com). This will allow the use of remote access to the camera, not knowing its IP-address. Software D-ViewCam D-Link allows you to view up to 32 cameras on one computer screen. Users can set up automatic notification by e-mail for instant information on abnormal events.
מאפיינים כללים
	System Requirements
	• Operating System: Microsoft Windows XP, Vista, Windows 7
	• Internet Explorer 6 or higher, Firefox 3.5 or higher, Safari 4
	Network Protocols
	• IPV4, ARP, TCP, UDP, ICMP
	• DHCP-client
	• NTP-client (D-Link)
	• DNS-client
	• DDNS-client (DynDNS, and D-Link)
	• SMTP-client
	• FTP-client
	• HTTP-server
	• PPPoE
	• Port Forwarding UPnP
	• LLTD
	• UPnP-X1
	Built-in network interface
	• 10/100BASE-TX Fast Ethernet
	• 802.11b/g/n WLAN
	Wireless connection
	• 802.11b/g/n with data encryption protocols WEP/WPA/WPA2
	Transmitter output power
	• 16 dbm for 11b, 12 dbm for 11g, 12 dbm for 11n (typical)
	SDRAM
	• 32 MB
	Flash-memory
	• 4 MB
	Reset button
	• Return to factory default settings
	Support for video compression algorithms
	• MJPEG
	• JPEG for still photography
	Video Properties
	• Adjustable image size and quality
	• Time stamp and text
	• Rotating and Mirroring
	Video Resolution
	• 640 x 480 resolution and 20 frames / s
	• 320 x 240 up to 30 frames / s
	• 160 x 120 up to 30 frames / s
	Lens
	• Focus: 5.01 mm, F2.8
	Sensor
	• 1/5 inch VGA CMOS-sensor
	Minimum illumination
	• A lux@F2.8
	Viewing angles
	• Horizontal: 45.3 °
	• Vertical: 34.5 °
	• Diagonal: 54.9 °
	Digital zoom
	• Up to 4x
	3A Control
	• Automatic Gain Control (AGC)
	• Automatic White Balance (AWB)
	• Automatic Electronic Shutter (AES)
