DCS-3716EOL EOS
תאור
High definition video surveillance
High-performance 3-megapixel camera DCS-3716 to conduct day / night camera equipped with 1/2 ,8-inch CMOS-sensor with progressive scan technology, as well as a lens with a focal length of 3.1-8mm auto iris. The DCS-3716 enables you to capture video in low light, and illumination of objects in the rear. In addition, ICR-filter allows you to receive high-quality video at any time. DCS-3716 is equipped with a slot for SD-cards. Interface Power over Ethernet (PoE), allows you to place the camera in various locations.
Multiple video streams
To increase the efficiency of bandwidth utilization and to increase the image quality the camera DCS-3716 uses streaming video compression formats: MJPEG, MPEG-4 and H.264. MJPEG format provides file integrity, making it ideal for situations that require high image detail. Data compression is H.264 and MPEG-4 allows you to get small files, which is useful for long-term recording, or in networks with low bandwidth. The camera can provide access to video on demand.
Extensive connectivity
DCS-3716 is equipped with inlet and outlet ports for connection to external devices such as IR sensors, switches and alarm relays. The camera is also equipped with RS-485 interface for connecting external devices, pan / tilt. In addition, the interface 12 provides power to the additional LED-light source.
WDR technology
Technology WDR (Wide Dynamic Range) provides a clear image even in backlight when the light intensity may change significantly. The DCS-3716 can be successfully applied in environments with high contrast. For example, while inside, the camera DCS-3716 allows you to monitor conditions in the intense sunlight. Thus, the DCS-3716 camera is the ideal solution for security applications.
מאפיינים כללים
Camera
• 1/2 inch 3 ,8-megapixel CMOS-sensor with Sony Exmor technology, progressive scan
• Minimum illumination: 0.5 lux (Color); 0.05 lux (monochrome)
• Built-in infrared filter
• WDR SN ratio: 100 dB
• 10x digital zoom
• Lens with variable focal length from 3.1 to 8 mm
• Aperture F1.2
• Angle:
Horizontal: 38,7 ° to 95,9 °
Vertical: 29,1 ° to 71 °
Diagonal: from 48,3 ° to 123,1 °
Functional videos
• Setting quality, size and speed of image transmission
• Timestamps and paste text
• Windows to configure the motion detection
• 3 private mask
• A custom white balance, shutter speed, adjust brightness, saturation, contrast,
Video compression
• Video compression formats H.264/MPEG4/MJPEG
• JPEG for still images
Video resolution
• 16:9 - 1280x1080, 1280x720, 800 x 450 640 x 360 480 x 270 320 x 176 176 x 144
• 4:3 - 2048 x 1536,1600 x 1200,1024 x 768, 800 x 600 640 x 480 480 x 360 320 x 240 176 x 144
• 3M (2048x1536) - up to 15 frames per second, with other resolutions - up to 30 frames per second
Audio support
• G.726
External interfaces
• 2 DI / DO 1
• 12 VDC, 200 mA
• RS-485
• Slot for SD-Card
• Audio In / Out
• Video Output
Network Protocols
• IPv4, TCP / IP, UDP, ICMP, DHCP Client, NTP Client (D-Link), DNS Client, DDNS Client (D-Link), SMTP Client, FTP Client, HTTP / HTTPS, Samba Client, PPPoE, UPnP Port Forwarding , RTP / RTSP / RTCP, IP filtering, 3GPP, IGMP, ONVIF
Security
• Protection of the Administrator account and user group
• Authentication by password
System requirements
• Operating System: Microsoft Windows 7/Vista/XP/2000
• Browser: Internet Explorer, Firefox, Netscape, Opera
Event management
• Motion detection
• Event notification and download snapshots / video clips through HTTP, SMTP or FTP
• Support for multiple servers, HTTP, SMTP and FTP
• Multiple event notifications
• Several ways to backup
Remote management
• Setting up a Web-browser
• Obtaining snapshots / video and save to your local hard drive or NAS via Web-browser
Support for PDAs, mobile phones and software
• Windows 7/Vista/XP, PDA or mobile phone 3GPP
System requirements for the D-ViewCam ™
• Browser: Internet Explorer 6 or above
• Protocol: TCP / IP
Software Features D-ViewCam ™
• Manage / control up to 32 cameras
• View images from 32 cameras on one screen
• Supports all management functions through a Web-based interface
• Option to record the image sensor or manual operation
