DCS-6510
מצלמת מעקב עם גוף עמיד עם אפשרות צילום לילי, מותאם להתקנה חיצונית בתקן IP66
היכן לקנות
תאור
Round-The-Clock surveillance
The D-Link DCS-6510 is a fixed dome day and night network camera, ideal for small-to-medium business applications and remote monitoring over the Internet. The camera employs a superior CMOS sensor with low lux sensitivity to deliver a truly superior image quality under varied lighting conditions. The DCS-6510 is equipped with a BNC video connector for an analog video signal, and DI/DO (digital input/digital output) connectors for external alarms and sensors.
High-quality video feeds
To maximize bandwidth efficiency and improve image quality, the DCS-6510 provides real-time video compression using the MJPEG, MPEG-4 and H.264 codecs. Furthermore, the DCS-6510 supports 3 separate profiles for simultaneous video streaming and is capable of recording in MJPEG, MPEG-4 and H.264 compression at VGA resolution. This kind of versatility enables a wide variety of security applications. For example, keep an eye on your home during lunch through a 3GPP enabled mobile device, or fine-tune your security system in real-time over the local network. You may also remotely manage a directory of recorded video files on a network attached storage (NAS) device or SD card.
Flexible installation
Power over Ethernet (PoE) connectivity allows for discreet installation in virtually any indoor location. This camera’s built-in 802.3af compliant PoE module eases the installation process by reducing the need to drill holes or lay additional cabling. In addition, the 10/100BASE-TX Ethernet port seamlessly connects to local network or to the Internet via a gateway router. This camera can be accessed and viewed from any network place as a device on the network.
Removable IR cut filter for continuous monitoring
The ICR Filter can be manually applied via the web, or set to automatically adjust based on lightning conditions. This feature allows the camera to capture crisp color images during the daytime, and grayscale images in low-light conditions.
Centralized management with D-VIEWCAM™
The included D-Link D-ViewCam™ is sophisticated video management software which enables you to manage up to 32 network cameras, set e-mail alert notifications, create recording schedules, and trigger motion detection to record directly to your hard drive. D-ViewCam™ also allows you to upload a floor plan of your business, and create a realistic layout according to the locations of your cameras, further simplifying the management process
מאפיינים כללים
General specification
• 1/4” CMOS Sensor
• Removable IR-cut Filter: Auto/Schedule/
Manual
• 3A Control: AGC, AW B, AES
• BLC: Backlight compensation
• Built-in IR LED (20 meter)
• DC Iris Varifocal 3.7 ~ 12 mm, F 1.4 ~ 2.8
View angle
• Vertical: 56.9° (W) ~ 17.1° (T)
• Horizontal: 76.9° (W) ~ 22.7° (T)
• Diagonal: 97.6° (W) ~ 28.4° (T)
IR LED
• 20 meter illumination distance with 12
LEDs and light sensor
• Minimum illumination:
• Color: 0.2 lux (F1.4)
• B/W: 0.02 lux (F1.4) without IR LED
• B/W: 0 lux with IR LED on
• 3-axis angle:
Vertical: 120
Horizontal: 340
Rotational: 300
System requirements
• Operating System: Microsoft Windows XP, Vista, Windows 7
• Internet Explorer 6 or above , Firefox 3.5 or above, Safari 4
Networking Protocol
• IPv4, DHCP, ARP, DNS, TCP/IP, DDNS(D-Link), HTTP, HTTPS, UPnP™ Port Forwarding, Samba, SMTP, PPPoE, NTP(D-Link), FTP, RTP, RTSP, UDP, RTCP,ICMP, 3GPP
Built-in network interface
• 10/100BASE-TX Fast Ethernet
Video codecs
• H.264
• MPEG4
• MJPEG
• JPEG for still images
Resolution
• 640 x 480 at up to 30 fps
• 320 x 240 at up to 30 fps
• 160 x 120 at up to 30 fps
Video features
• Adjustable image size, quality and bit rate
• Time stamp and text overlays
• 3 configurable privacy masks
• Flip & mirror
Audio codecs
• G.726
• G.711
תקנים
הורדות
איורים
DCS-6510/Ax
מראה מקדימה
דף מידע
ראה גם
