תאור
Observation of high-resolution
Professional megapixel DCS-3710 sensor with WDR and the possibility of night shooting has a 1/3-inch CMOS-sensor with progressive scan technology, as well as auto iris lens 2.8 ~ 12mm DC. The DCS-3710 enables you to capture video in the absence of light and low light, as well as highlighting the objects behind. In addition, the removable IR cut filter, providing the ability to work in day / night, allows to obtain high-quality video at any time. DCS-3710 is equipped with an interface Power over Ethernet (PoE) and a slot for SD-cards. Because of this, the camera can be easily installed in various locations.
Support for multicast data
DCS-3710 supports multiple video streams of MPEG-4 and MJPEG simultaneously, which provides high image quality and increases the effective bandwidth through compression formats. MJPEG provides file integrity, making it ideal in situations where detailed images of high quality. Data compression is the MPEG-4 allows you to get small files, which is useful for long-term recording, or in networks with low bandwidth. The camera can provide access to video on demand.
Flexible connectivity
DCS-3710 is equipped with inlet and outlet ports for connection to external devices such as IR sensors, switches and alarm relays. The camera is also equipped with RS-485 interface for connecting external devices, pan / tilt. In addition, the interface 12 provides power to the additional LED-light source.
Application wide dynamic range (WDR)
Function WDR (Wide Dynamic Range) provides a clear image even in backlight when the light intensity may change significantly. The DCS-3710 can be successfully applied in environments with high contrast. For example, while inside, the camera DCS-3710 allows you to monitor conditions in the intense sunlight. Thus, the DCS-3710 camera is the ideal solution for security applications.
מאפיינים כללים
Key Features
• Progressive Scan, 1/3-inch CMOS-sensor
• Removable IR-cut filter:
• Auto / Schedule / Manual
• 3A Control: AGC, AWB, AES
• varifocal lens 2.8-12mm, F1.3 *
• varifocal lens 2.9-8mm, F1.3 **
• Minimum illumination: 0.3 lux, B / W: 0,02 lux
• WDR SN ratio: 100dB
Audio
• 2-way audio transmission
• The external audio input
• External Audio
• Codec G.726
Video compression
• Simultaneous compression in MPEG and MJPEG
• Simultaneous compression formats h.264 **
• Support for profiles through the web-based interface, viewing video on 3G mobile phone and video recording
Video Resolution
• Supported Resolutions: 1280 x 960/1280 x 720/640 480/320 x 240/160 x 120
• Up to 30 frames per second for all resolutions
Network connection
• 802.3af Power over Ethernet (PoE)
• Auto-negotiation 10/100 Mb / s Fast Ethernet
Connector I / O
• Lens with Auto Iris, 4-pin connector
• DI x 2
• DO x 1
• RS-485
• 12 VDC, 200 mA output
• Slot for SD-Card
Security
• Protection of the Administrator and User Groups
• Authentication by password
Remote management
• Camera confiscation, and the camera system log
• To capture a Web-browser and save to your hard drive
Network protocols
• IPv4, DHCP, ARP, DNS, TCP / IP, DDNS (D-Link), HTTP, port forwarding UPnPTM
• Samba, SMTP, PPPoE, NTP (D-Link), FTP, RTP, RTSP, UDP, RTCP, ICMP, 3GPP
System requirements for viewing
• Internet Explorer 6.0 or higher
System requirements to run for the D-Viewcam
• Operating system: Windows Vista, Microsoft Windows XP
• Web-browser: Internet Explorer 6.0 or higher
• Protocol: TCP / IP
נתונים פיזיים
Input voltage
• 100-240 VAC, 50/60 Hz, 12 V DC, 1.25 A
Dimensions
• 88 x 53 x 194 mm
Operating temperature
• From 0 ˚ to 40 ˚ C
Storage temperature
• From -20 ˚ to 70 ˚ C
Humidity
• 20% - 80% (no condensation)
Certificates
• CE (Class A)
• On-Tick (Class A)
• FCC (Class A)
* Only for DCS-3710
** Only for DCS-3710/B1A
