DPN-1021Gמיועד לפרויקטים
GPON ONT VoIP Gateway with 1 GPON Port, 1 10/100/1000Base-T Port, 1 10/100Base-TX Port, and 1 FXS Port
תאור
GPON Technology
DPN-1021G provides an optical line connection to a GPON OLT device. The key advantage of GPON technology is extraordinary bandwidth of the channel. This helps to deliver the next generation of high-speed Internet services to home and office users. DPN-1021G helps to provide a reliable, long-reaching last-mile connection by extending the high-bandwidth public network to people living and working in remote multi-unit buildings.
Triple Play Services
High-speed broadband access with the rate up to 2.4Gbps allows to provide customers with all high-demand services (such as HD IPTV, VoIP, Internet connection) simultaneously.
Voice
The device is equipped with an FXS port which allows connection of an analog phone for calls via Internet.
Ethernet WAN
Any Ethernet port of the device can be configured to connect to a private Ethernet line.
Security
The VoIP gateway DPN-1021G includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
In addition, the gateway supports IPsec and allows to create secure VPN tunnels.
Built-in Yandex.DNS service protects against malicious and fraudulent web sites and helps to block access to adult content on children's devices.
Easy Configuration and Update
You can configure the settings of DPN-1021G via the user-friendly web-based interface (the interface is available in two languages – in Russian and in English).
DPN-1021G itself checks the D-Link update server. If a new approved firmware is available, a notification will appear in the web-based interface of the device.
The built-in TR-069 client allows to perform remote configuration and diagnostics of the device independently from the customer.
מאפיינים כללים
Hardware
| Processor |
• RTL9602
| RAM | • 128MB, DDR3 |
| Flash | • 128MB, NAND |
Interfaces
• GPON port (SC/APC connector)
• 10/100/1000BASE-T LAN port
• 10/100BASE-TX LAN port
• RJ-11 FXS port
LEDs
• POWER
• GPON
• Internet
• VoIP
• 2 LAN LEDs
Buttons
• ON/OFF button to power on/power off
• RESET button to restore factory default settings
Power connector
• Power input connector (DC)
PON
GPON features
• Class B+ GPON optical transceiver
• Upstream (transmitter): 1310nm ± 50nm, 1.244Gbps upstream burst data rate
• Downstream (digital receiver): 1490nm ± 10nm, 2.488Gbit/s downstream continuous data rate
• Single mode fiber cable
• AES encryption
• Support of IGMP v1/v2 Snooping, 16 entries, enable/disable, Fast leaving
• MAC learning
• UNI port configuration (rate, duplex mode, flow control, disable/enable, auto mode)
• Maximum frame length to 1522 bytes
• Compliance to ONT dying gasp
• ONT authentication
| Phone | |
General SIP Features
• Invite with Challenge
• Register by IP address or domain name of SIP server
• Backup proxy support
• Support of DHCP option 120
• RFC3986 SIP URI format support
• Outbound proxy support
• STUN client
• NAT keep-alive
• Call types: voice/modem/fax
• User programmable Dial Plan
• Manual peer table (P2P)
• E.164 Numbering, ENUM support
Call Features
• Direct IP-to-IP сall without SIP proxy
• Call hold/retrieve
• Call awaiting
• Forwarding (unconditional, busy, no answer)
• Do Not Disturb
• Blocking hidden number calls
• Speed dialing
• Phone book
• Hotline
• Vertical service codes
• Filtering by IP address (white/black list)
• Alarm clock
Voice Features
• Codecs: G.711 a/μ-law, G.729A, G.726, G.722, G.723.1
• DTMF detection and generation
• In-band DTMF, out-of-band DTMF (RFC2833, SIP-INFO)
• Comfort Noise Generation (CNG)
• Voice Activity Detection (VAD)
• Dynamic Jitter Buffer
• Call progress tone generation (FXS)
• DTMF/PULSE dial support
• Caller ID detection and generation
• T.30 FAX bypass to G.711, T.38 Real Time FAX Relay
• Adjustable Flash Time
• Volume control (speaker/microphone)
| Software | |
WAN connection types
• Static IPv4 / Dynamic IPv4
• Static IPv6 / Dynamic IPv6
• PPPoE
• PPTP/L2TP
• PPPoE IPv6
• PPPoE Dual Stack
Network functions
• DHCP server/relay
• • IPv6/Stateful/Stateless mode for IPv6 address assignment, IPv6 prefix delegation
• DNS relay
• Dynamic DNS
• Static IP routing
• Static IPv6 routing
• IGMP Proxy
• RIP
• Support of UPnP IGD
• Support of VLAN
• Support of MVR
• WAN ping respond
• Support of SIP ALG
• Support of RTSP
• Autonegotiation of speed, duplex mode, and flow control/Manual speed and duplex mode setup for each Ethernet port
Firewall functions
• IP filter
• IPv6 filter
• MAC filter
• URL filter
• DMZ
• Prevention of ARP and DDoS attacks
• Virtual servers
• Built-in Yandex.DNS web content filtering service |
VPN
• IPSec/PPTP/L2TP/PPPoE pass-through
• IPSec tunnels
Management
• Local and remote access to settings through TELNET/WEB (HTTP/HTTPS)
• • Bilingual web-based interface for configuration and management (Russian/English)
• Support of remote logging
• Ping utility
• Traceroute utility
• TR-069 client
Physical Parameters
Dimensions (L x W x H)
• 160 x 115 x 43 mm (6.3 x 4.5 x 1.7 in)
Weight
• 200 g (0.44 lb)
Operating Environment
Power
• Output: 12V DC, 1A
Temperature
• Operating: from 0 to 40 °C
• Storage: from -40 to 70 °C
Humidity
• Operating: from 10% to 90% (non-condensing)
• Storage: from 5% to 95% (non-condensing)
Delivery Package
• GPON ONT VoIP gateway DPN-1021G
• Power adapter DC 12V/1A
תקנים
הורדות
DPN-1021G GPON ONT VoIP Gateway with 1 GPON Port, 1 10/100/1000Base-T Port, 1 10/100Base-TX Port, and 1 FXS Port
