DPN-R5402CEOL EOS
תאור
Use of new technology GPON
Device DPN-R5402C GPON (Gigabit Passive Optical Network) ONT (Optical Network Terminal) provides a connection on the optical channel to the device class GPON OLT side CO and connection features 802.11n wireless router with Gigabit Ethernet end user. The main advantage of GPON technology is the optimum utilization of bandwidth. This technology is the next step in providing high-speed access to Internet services for homes and businesses. This unit ONT provides a reliable connection with high bandwidth over long distances for users who live or work in remote apartment buildings and business centers.
High Speed Internet Access
DPN-R5402C device allows telecommunications service providers to meet the growing needs of users in the services provided, ensuring the fastest possible through the use of optical fiber. The device supports symmetric mode and provides various options for deploying networks in homes, schools and apartment buildings and business centers.
Everything you need for your home or small business
DPN-R5402C device is an integrated solution for network tasks at home or small business. It is equipped with a four-port Gigabit Ethernet, two ports VoIP FXS, one RF port and supports 802.11n.
Support for voice services
DPN-R5402C device is equipped with two ports FXS, the opportunity to use voice services provider.
מאפיינים כללים
Device Interfaces
• IEEE 802.11n wireless LAN
• 2-port FXS analog phone with an RJ-11
• 1-port RF (CATV)
• 1 optical port for SC GPON
• 4 ports with automatic identification speed 10/100/1000 Gigabit LAN with RJ-45 connector
• WPS button
• Reset button (return to factory default state)
Wireless network and routing
• Compliant with IEEE 802.11b/802.11g/802.11n 2,4 GHz
• Support for protecting WEP 64/128 bit
• Support for WPA and WPA2 security
• Support for Wi-Fi protected setup (WPS)
• Internal customers WAN (DHCP, Static IP, PPPoE)
• Stateful packet inspection (SPI)
• Firewall
• Support for VPN Pass-through (IPSec, PPTP, L2TP)
• DHCP-server, DNS Relay
• Filtering by IP / MAC-addresses, DMZ
• IGMP, Multicast, VLAN
GPON specifications
• Compliance with ITU-T 984.x
• 1 x SC, which can be connected to the fiber optic cable from the CO
• Cable: single-mode fiber optic cable
• Support OMCI (ONT Management control interface) for remote control
• The maximum capacity for the upstream (ONT-> OLT): 1,25 Gbit / s
• The maximum capacity for the downstream (OLT-> ONT): 2,4 Gb / s
• Output power of an optical receiver: 0.5 5dBm
• Receiver sensitivity:-27dBm
• The wavelength of the upstream (ONT-> OLT): 1310
• Wavelength for Downstream (OLT-> ONT): 1490 nm
• Wavelength for CATV: 1550
• AES Encryption
• Supports IGMP v1/v2/v3 Snooping, 128 entries can be enabled / disabled
• Configuring port UNI (speed, duplex mode, pause flow control, on / off, auto)
• The maximum length of frames: 1522 bytes
• Study of MAC-addresses
• Authentication ONT
VOIP function
• 2-port FXS
• SIP (RFC 3261)
• Echo cancellation
• Identification of tones and tone generation
• Call Transfer, Caller ID
• Fax relay
• Voice codecs: G.711 a-law, G.711 u-law, G.723.1 (optional), G.729a / b (optional)
Indicators
• Power
• Link (PON)
• Act (PON)
• LAN (1-4)
• WAN
• Phone (1-2)
