DGS-1210-28MP/FLמיועד לפרויקטים
24 10/100/1000Base-T PoE Ports and 4 100/1000Base-T/SFP Combo Ports L2 Managed Switch
תאור
The D-Link DGS-1210/FL Series is the latest generation of switches to provide increased Power over Ethernet (PoE) output, a range of physical interface types, multiple management interfaces, and advanced Layer 2 features. With all of these features combined, the DGS-1210/FL Series provides a cost-efficient and flexible solution for expanding any business network.
Seamless Integration
The DGS-1210-28MP/FL switch is equipped with 24 10/100/1000Base-T ports and 4 100/1000Base-T/SFP combo ports. The switch includes support for IEEE 802.3af/at and higher power budget, allowing more PoE devices to be powered by the switch and for devices to be installed in remote locations without immediate access to power outlets.
Advanced Features
The DGS-1210-28MP/FL switch comes equipped with a complete lineup of L2 features, including IGMP snooping, port mirroring, Spanning Tree Protocol (STP), and Link Aggregation Control Protocol (LACP). The IEEE 802.3x Flow Control function allows servers to directly connect to the switch for fast, reliable data transfers. The switch also supports advanced features such as static routes, which allow network administrators to divide the network into VLANs, increasing network efficiency. Network maintenance features include loopback detection and cable diagnostics. Loopback detection significantly speeds up troubleshooting by automatically detecting and shutting down switching loops. The cable diagnostics feature, designed primarily for administrators and customer service representatives, determines the cable quality and quickly discovers errors, allowing for hassle-free diagnostics and maintenance.
Secure your Network
D-Link's innovative Safeguard Engine protects the switches against traffic flooding caused by virus attacks. The switch also supports 802.1X port-based authentication, allowing the network clients to be authenticated through external RADIUS servers. The Access Control List (ACL) feature enhances network security and helps to protect the internal IT network.
מאפיינים כללים
General Port Standards & Functions
• IEEE 802.3 10Base-T Ethernet (twisted-pair copper)
• IEEE 802.3u 100Base-TX Fast Ethernet (twisted-pair copper)
• IEEE 802.3ab 1000Base-T Gigabit Ethernet (twisted-pair copper)
• IEEE 802.3z 1000Base-X
• IEEE 802.3x Flow Control
• IEEE 802.3af
• IEEE 802.3at
• Auto-negotiation
Number of Ports
• 24 10/100/1000Base-T PoE
• 4 combo 100/1000Base-T/SFP
Network Cables
• UTP Cat. 5, Cat. 5e (100 m max.)
Full/Half Duplex
• Full/half duplex for 10/100 Mbps speeds
• Full duplex for Gigabit speed
Media Interface Exchange
• Auto or configurable MDI/MDIX
Performance
Switching Capacity
• 56 Gbps
Transmission Method
• Store-and-forward
MAC Address Table
• 8K entries
MAC Address Update
• Up to 256 static MAC entries
Maximum 64 bytes packet forwarding rate
• 41.7 Mpps
Packet Buffer Memory
• 512 KB
PoE Capable Ports
• Up to 30 W on ports 1 to 24
PoE Power Budget
• 370 W
Physical & Environmental
Power Input
• 100 to 240 V AC 50/60 Hz, internal universal power supply
Maximum Power Consumption
• 446.1 W (PoE on)
• 29.8 W (PoE off)
Standby Power Consumption
• 18.5 W/100 V, 17.1 W/240 V
Fan Quantity
• 2
Acoustics
• High fan speed: 51.7 dB(A)
• Low fan speed: 44.9 dB(A)
Heat Dissipation
• 445.79 W (1,521.99 BTU/hr)
Operating Temperature
• -5 to 50 °C
Storage Temperature
• -40 to 70 °C
Operating Humidity
• 10% to 90% non-condensing
Storage Humidity
• 5% to 90% non-condensing
Dimensions
• 440 x 250 x 44 mm
Weight
• 3.94 kg
Diagnostic LEDs
• Power (per device)
• PoE Max (per device)
• Link/Activity/Speed (per port)
• Power Fail/Power Ok (per PoE port)
• Fan Error
MTBF
• 277,967 hours
Certifications
• CE
• VCCI
• FCC
• cUL
• BSMI
• CCC
• C-Tick
Software Features
L2 Features
• IGMP Snooping
  - IGMP v1/v2/v3 Snooping
  - IGMP v3 awareness
  - Supports 512 group (shared with MLD Snooping, and static group)
  - Supports 512 static multicast group (shared with MLD Snooping, and static group)
  - IGMP per VLAN
  - Supports IGMP Snooping Querier
  - Host-based IGMP Snooping Fast Leave
• Loopback Detection
• 802.3ad Link Aggregation:
  - Maximum of 8 groups/8 ports per group
• LLDP
• LLDP-MED
• Jumbo Frame
  - Up to 10,000 bytes
• Spanning Tree Protocol
  - 802.1D STP
  - 802.1W RSTP
  - 802.1s MSTP
• Flow Control
  - 802.3x Flow Control
  - HOL Blocking Prevention
• Port Mirroring
  - One-to-One
  - Many-to-One
  - Supports Mirroring for Tx/Rx/Both
• Multicast Filtering
  - Forwards all unregistered groups
  - Filters all unregistered groups
• Configurable MDI/MDIX
• MLD snooping
  - MLD v1
  - MLD v2 awareness
  - Supports 512 group (shared with IGMP Snooping, and static group)
  - Supports 512 static multicast group (shared with IGMP Snooping, and static group)
  - Host-based MLD Snooping Fast Leave
VLAN
• 802.1Q
• VLAN Group
  - Max. 256 static VLAN groups
  - Configurable VID from 1 - 4094
• Asymmetric VLAN
• Auto Surveillance VLAN
• Voice VLAN
• Double VLAN (Q-in-Q)
  - Port-based Q-in-Q
QoS (Quality of Service)
• 802.1p
• 8 queues per port
• Queue Handling
  - Strict
  - Weighted Round Robin (WRR)
• CoS based on
  - 802.1p priority queues
  - DSCP
  - Switch port
• Bandwidth Control
  - Port-based (Ingress/Egress, min. granularity 10/100/1000 is 16 Kb/s)
L3 Features
• ARP
  - Max. 128 ARP entries
  - Supports 128 static ARP entries
• 4 IP interfaces
  - Supports 4 interfaces
L3 Routing
• Static routing
  - Max. IPv4 entries: 128
  - Max. IPv6 entries: 128
• Max. 200 access lists
• Max. ACL entries
  - Ingress: 150
• Each rule can only be associated with a single port
• ACL based on
  - MAC address
  - IP address
  - Protocol type
  - TCP/UDP port
Security
• Broadcast/Multicast/Unicast Storm Control
• D-Link Safeguard Engine
• 802.1X Port-based Access Control
• IP-MAC-Port Binding (Smart Binding)
  - ARP Inspection
  - DHCP Snooping
• DoS attack prevention
• Traffic segmentation
• SSH
• Port Security
  - Supports up to 64 MAC addresses per port
OAM
• Cable Diagnostics
AAA
• 802.1X Authentication
  - Supports local/RADIUS database
  - Supports port/host-based access control
  - Supports EAP, OTP, TLS, TTLS, PEAP
• RADIUS server
• TACACS+ Server
• Support MD5 authentication
Management
• Web-based GUI
• CLI
• D-View 7 (EOL|EOS)
• Telnet Server
• SSH server
• TFTP Client
• SNMP v1/v2c/v3
• SNMP Trap
• Backup/upgrade firmware
• Upload/download configuration file
• System Log
• BootP/DHCP Client
• SNTP
• ICMP v6
• IPv4/v6 Dual Stack
• DHCP Auto Configuration
• Time setting
  - SNTP
• RMONv1
• Dual image
• DHCP Relay
  - DHCP local relay
  - DHCP relay option 82
D-Link Green 3.0 Technology
• Power Saving by:
  - System hibernation
  - Port shut off
  - LED shut off
MIB/RFC
• RFC783, 1350 TFTP
• RFC791 IP
• RFC768 UDP
• RFC793 TCP
• RFC792 ICMPv4
• RFC2463, 4443 ICMPv6
• RFC826 ARP
• RFC951, 1542, 2131 BootP/DHCP Client
• RFC1213 MIB II
• RFC1350 TFTP
• RFC1493 Bridge MIB
• RFC1769 SNTP
• RFC1157, 2570, 2573, 2575, 2576 SNMP MIB
• RFC1442, 1901, 1902, 1903, 1904, 1905, 1906, 1907, 1908, 2578, 3418 SNMPv2 MIB
• RFC1398, 1643, 1650, 2358, 2665 Ether-like MIB
• RFC1321, 2284, 2865, 2716, 3580 Extensible Authentication Protocol (EAP)
• RFC2674 802.1p MIB
• RFC2461, 4861 Neighbor Discovery for IPv6
• RFC2462, RFC4862 IPv6 Stateless Address Auto-configuration (SLAAC)
• RFC4291 IPv6 Addressing Architecture
• RFC2893, 4213 IPv4/IPv6 dual stack function
• RFC2138, 2139, 2618, 2865 RADIUS Authentication Client MIB
• RFC2475, 2598 CoS
• RFC3164, 3195 System Log
• RFC3411, 3412, 3413, 3414, 3415, 3416, 3417 SNMPv3
• Private MIB
תקנים
הורדות
DGS-1210-28MP/FL  24 10/100/1000Base-T PoE Ports and 4 100/1000Base-T/SFP Combo Ports L2 Managed Switch
איורים
DGS-1210-28MP/FL/R1
מראה מקדימה
מראה מימין
מראה מאחורה
דף מידע
ראה גם
