DCS-6210EOL EOS
תאור
	The DCS-6210 Full HD Mini Fixed Dome Network Camera is an industry rated vandal proof and weatherproof camera suited to a wide range of traditionally difficult deployment scenarios.
	Built for Tough Environments
	Specially designed for use in challenging environments the DCS-6210 has a toughened metal, industry-certified IK-10 (vandal-proof) and IP-66 (weather-proof) housing. This means that it
	is able to withstand sudden high impact, and adverse weather conditions. Additionally, the DCS-6210 carries a Power over Ethernet (PoE) port which allows you to connect the camera
	to your network and power it through a single cable. This both expands and simplifies your deployment options by doing away with the need for a nearby power outlet, making
	deployment on ceilings much easier.
	Surveillance in Full High Definition
	The DCS-6210 is built with a megapixel image sensor to give you high-quality snapshots and video with resolutions up to 1080p Full HD. This gives you sharp, high-resolution pictures and
	videos with rich detail. Get a closer look with ePTZ, which lets you zoom in, zoom out, and pan across your camera’s video so you can survey a large area easily.
	A Complete, Expandable Surveillance Solution
	The DCS-6210 is a self-sufficient surveillance solution, capable of recording snapshots and video to a MicroSD card without requiring a PC or network storage device.
	If you want to expand your surveillance options, D-ViewCam management software is also included, giving you the ability to manage up to 32 cameras with a robust set of features,
	including multi-camera views and automated e-mail alerts to keep you informed of suspicious or unusual activities.
	Built for Versatility
	The DCS-6210 comes with a wealth of features that enhance its surveillance capabilities, making it ideal for any situation. It’s 3 axis lens mounting allows you to position it perfectly, while its motion detection capabilities allow it
	to automatically record video and send you a notification when motion is detected.
מאפיינים כללים
	Hardware profile camera
	• 1/2 inch, 7-megapixel CMOS-sensor with progressive scan technology
	• Fixed lens with a focal length of 4.3 mm and aperture F2.0
	• 10x digital zoom
	• Viewing angle:
	  • 79 (H)
	  • 43 (vertical)
	  • 90 inch (diagonal)
	Camera Body
	• Weatherproof (standard IP-66) and anti-vandal (standard IK-10) package
	Image details
	• Setting the image quality and size, frame rate and bit rate
	• Timestamps and paste text
	• Customizable windows for motion detection
	• Configurable zone private masks
	• Setting the white balance, brightness, color saturation, contrast, sharpness, and backlight compensation (BLC)
	Video Compression
	• Compression formats H.264/MPEG-4/MJPEG
	• H.264/MPEG-4 multicast transmissions
	• JPEG for still images
	Video Resolution
	• 16:9 - 1920x1080 (up to 15 frames / s), 1280x800, 1280x720, 800x450, 640x360, 480x270, 320x176, 176x144 and 30 kadrov/s1
	• 4:3 - 1440x1080 (up to 25 frames / s), 1024x768, 800x600, 640x480, 480x360, 320x240, 176x144 and 30 kadrov/s1
	Audio support
	• G.726
	• G.711
	Interfaces to external devices
	• Port 10/100 BASE-TX Fast Ethernet
	• Supports 802.3af PoE
	• Card slot Micro SD / SDHC
	Network Protocols
	• IPv6
	• IPv4
	• TCP / IP
	• UDP
	• ICMP
	• DHCP-Client
	• NTP-Client (D-Link)
	• DNS-client
	• DDNS-client (D-Link)
	• SMTP-client
	• FTP-client
	• HTTP / HTTPS
	• Samba-client
	• PPPoE
	• UPnP port forwarding
	• RTP / RTSP / RTCP
	• Filtering of IP-addresses
	• QoS
	• CoS
	• Multicast
	• IGMP
	• ONVIF
	Safety
	• Security Administrator and user group
	• Password authentication
	• Encryption HTTP and RTSP
	System requirements for the web-interface
	Web-browser: Internet Explorer, Firefox, Safari, Chrome
	Event management
	• Motion detection
	• Event notification and download stop-kadrov/videoklipov via email or FTP
	• Support for multiple FTP and SMTP servers
	• Multiple event notifications
	• Several ways to backup
	Remote management
	• Creating and maintaining stop-kadrov/videoklipov to a local hard drive or NAS via Web-browser
	• Interface settings, available through Web-browser
	System Requirements D-ViewCam ™
	• Operating System: Microsoft Windows 7/Vista/XP
	• Web-browser: Internet Explorer 7 or above
	• Protocol: Standard TCP / IP
	Software features D-ViewCam ™
	• Remote management / control of up to 32 cameras
	• Viewing images on a single screen up to 32 cameras
	• Recording Options for triggering a sensor or manually
	• Supports all management functions available through the web-interface
