KVM-450EOL EOS
תאור
The D-Link PS2/USB 8/16 Port Combo KVM Switch is a high-end local remote management solution which allows you to control up to 4096* PCs from a single console.
Versatile Management
Toggle between clients using the front panel buttons, keyboard hotkeys, or On-screen Display (OSD menu). The on-screen menu allows you to label each channel with a descriptive name, providing clear and easy navigation. A convenient Auto-Scan function allows you to automatically toggle between multiple computers sequentially at preset intervals. The front panel LEDs assist with workstation/server status monitoring. Green LEDs indicate that systems are online, while separate red LEDs indicate when a particular system has been selected for management via console.
Convenient Installation
The sturdy metal chassis is mountable in a standard 19” rack. Daisy chain multiple KVM switches together up to three levels deep; cascaded units require no special configuration and automatically configure themselves as master or slave. Target workstations can be connected via keyboard/mouse or PS/2 using a custom combo cable. A PS/2 or USB keyboard is emulated on each terminal allowing all attached computers to successfully boot without keyboard errors. Hot-pluggable connections allow you to add devices to or remove them from the KVM switch without the need to shut it down.
מאפיינים כללים
Number of managed computers
• 16
Switching method
• Push button and hot keys (on keyboard PS / 2) or OSD (On-Screen-Display)
Indicators
• Red when switching PCs
• Green in PC mode, online / reading
PC connectors
• Video: 8-pin HDB "mom", 16-pin HDB-15 "mother"
• Keyboard / Mouse: PS / 2 and USB
Console ports
• Keyboard: 1 x 6-pin mini-DIN "female"
• Mouse 1 x 6-pin mini-DIN "female"
• Video: 1 x HDB-15 "mother"
Port for software upgrade
• Mini USB
Scan interval
• Customizable interval via OSD menu
Display DDC, DDC2
• Maximum resolution up to 2048 x 1536 @ 65 Hz
"Hot" replacement during operation
• Yes
Operating System Support
• Windows 98SE/ME/2000/2003/2008/XP/Vista/7, Linux, Mac OS 9/OS X and Sun Microsystems
