DIS-310G-24Xחדש
Layer 3 Industrial Managed Switch with 16x10/100/1000Base-T Ports, 4x1000Base-X SFP Ports and 4x10GBase-X SFP+ Ports
תאור
The DIS-310G-24X Layer 3 Gigabit Industrial Managed Switch is designed specifically to withstand a wide range in temperature change, vibrations and shock. This rugged yet easy to deploy switch has superior environmental specifications compared to those of commercial network switches. With its hardened design combined with high availability network features, this switch forms vital parts of any network infrastructure facilitating the increasing demand for smart cities, city-wide surveillance and wireless connectivity. With its comprehensive feature set, the DIS-310G-24X managed switch is easy to configure, partition and organize user’s network and provide reliable and quality of service. The DIS-310G-24X boasts 16 GE ports with 4 1G SFP and 4 10G SFP+ ports, giving you versatility and speed.
Durable, Reliable, and Efficient
The DIS-310G-24X switch is housed in a highly resistant IP40-rated metal casing to protect the switches from harsh environmental conditions. High electromagnetic susceptibility (EMS) protects the DIS-310G-24X from undesirable effects when operating in environments with strong electromagnetic interference. Meanwhile, the fanless design extends the life of the DIS-310G-24X while also enabling them to operate in a wide temperature range from -20 °C up to 75 °C. With DIN rail mounting capability, the DIS-310G-24X can fit seamlessly into your industrial equipment infastructure. In addition, the DIS-310G-24X supports dual power input, which allows for a redundant power supply configuration to make sure the switches continue to operate in the event of a primary power supply failure.
Green Ethernet Technology
The DIS-310G-24X features green technology; IEEE 802.3az Energy-Efficient Ethernet (EEE). Energy-Efficient Ethernet reduces the power consumption of the switch when network utilization is low, effectively lowering the cost of ownership during periods of inactivity.
מאפיינים כללים
Hardware Version
• A1
Interfaces
• 16 10/100/1000Base-T ports
• 4 1000Base-X SFP ports
• 4 10GBase-X SFP+ ports
• RJ-45 console port
• Alarm Relay
Diagnostic LEDs
• Power
• SYS
• Link/Act (per port)
Material
• IP40-rated metal casing
Installation
• DIN rail mountable
Port Functions
• IEEE 802.3 10Base-T
• IEEE 802.3u 100Base-TX
• IEEE 802.3ab 1000Base-T
• IEEE 802.3z 1000Base-X
• IEEE 802.3ae 10GBase-X
Media Interface Exchange
• Auto-MDI/MDIX adjustment for all twisted pair ports
Switching Capacity
• 120 Gbps
Transmission Method
• Store-and-forward
Maximum Forwarding Rate
• 89.28 Mpps
MAC Address Table Size
• 16K entries
Packet Buffer Memory
• 1.5 MB
Jumbo Frame
• 9 KB
Flash Memory
• 16 MB
DRAM Size
• 256 MB
Software Features
L2 Features
• MAC Address Table
  • 16K entries
• IGMP Snooping
  • IGMP v1/v2/v3 Snooping
  • 1024 IGMP groups
  • IGMP Snooping Fast Leave
  • 1024 static IGMP groups
  • Per VLAN IGMP Snooping
  • IGMP Snooping Querier
• Loopback Detection
• 802.1AX/802.3ad Link Aggregation
  • Max. 8 groups per device, 8 ports per group
• LLDP
• LLDP-MED
• Spanning Tree Protocol
  • 802.1D STP
  • 802.1w RSTP
  • 802.1s MSTP
  • BPDU Filtering
  • Root Guard
  • Loop Guard
• Port Mirroring
  • One-to-One
  • Many-to-One
  • Mirroring for Tx/Rx
• Flow Control
  • 802.3x Flow Control
  • HOL Blocking Prevention
• MLD Snooping
  • MLD v1/v2 Snooping
  • Support 508 MLD Groups
  • MLD Snooping Fast Leave
  • Supports 508 static MLD groups
  • MLD Snooping Querier
  • Per VLAN MLD Snooping
• VLAN Mirroring
• RSPAN
• L2 Protocol Tunneling
• Ethernet Ring Protection Switching (ERPS)
VLAN
• 802.1Q
  • Configurable VID from 1 - 4094
• GVRP
  • Max. 4094 dynamic VLAN group
• Double VLAN (Q-in-Q)
  • Port-based Q-in-Q
  • Selective Q-in-Q
• Port-based VLAN
• 802.1v Protocol-based VLAN
• MAC-based VLAN
• VLAN translation
• Voice VLAN
• Auto Surveillance VLAN
• Subnet-based VLAN
• VLAN Trunking
• Super VLAN
• Asymmetric VLAN
• Private VLAN
Quality of Service (QoS)
• 802.1p
• 8 queues per port
• Queue Handling
  • Strict Priority Queue (SPQ)
  • Weighted Round Robin (WRR)
  • SPQ + WRR
• Policy Map
  • Remark 802.1p priority
  • Remark ToS/DSCP
  • Rate Limiting
  • Time-based QoS
• Bandwidth Control
  • Port-based (ingress/egress, min. granularity 64 Kbps)
  • Flow-based (ingress/egress, min. granularity 64 Kbps)
  • Queue-based bandwidth control
• CoS based on:
  • Switch port
  • Inner/Outer 802.1p Priority
  • Inner/Outer VID
  • MAC address
  • IP address
  • ToS/IP preference
  • DSCP
  • Protocol type
  • TCP/UDP port number
  • Ether Type
L3 Features
• IP interface
  • Supports 64 interfaces
• Static routing
• ARP
• Loopback Interface
• VRRP
• UDP Helper
• IPv6 Tunneling
  •  Static
  •  GRE
  •  6to4
• Up to 512 IPv4 / 170 IPv6 routing entries
• Up to 2042 IPv4 / 1700 IPv6 L3 forwarding entries
• IPv4/IPv6 Static Route
  • Max. 512 IPv4 entries
  • Max. 170 IPv6 entries
• IPv4/IPv6 Default Route
• PBR (Policy-based Route)
• Null Route
• Route Preference
• Route Redistribution
• RIPv1/v2/ng
• OSPF
  • OSPF v2/v3
  • OSPF passive interface
  • Stub area/NSSA
  • Text/MD5
Access Control List (ACL)
• Max. ACL entries:
  • Ingress
  • IPv4: 1279
  • IPv6: 319
• ACL based on:
  • 802.1p priority
  • VID
  • MAC address
  • Ether Type
  • LLC
  • VLAN
  • IP address
  • IP preference/ToS
  • DSCP mask
  • Protocol type
  • IPv6 Traffic Class
• Max Access List Numbers: 256
Security Features
• Broadcast/Multicast/Unicast Storm Control
• Traffic segmentation
• SSH v2
• TLS v.1.2
• SSL v3
• Port Security
  • Up to 8K MAC addresses per port
• ARP Spoofing Prevention
  • Max. 350 entries
• IP Source Guard
• Dynamic ARP Inspection (DAI)
• L3 Control Packet Filtering
• BPDU Attack Protection
• DOS Attack Prevention
• IP-MAC-Port Binding (IMPB)
• DHCP Snooping
• Password encryption
AAA
• 802.1X Authentication
  • Supports port/host-based policy assignment
  • Identity-driven Policy Assignment
  • Ingress/Egress Bandwidth Control
  • ACL Assignment
• Guest VLAN
• Trusted Host
• RADIUS/TACACS+ Accounting
• Web-based Access Control (WAC)
• Authentication Database Failover
• MAC-based Access Control (MAC)
• MD5 authentication
• IPv4/IPv6 RADIUS server
OAM (Operations, Administration and Maintenance)
• Cable diagnostics
• 802.3ah Ethernet Link OAM
• Dying Gasp
• Y.1731 OAM
Management
• Web-based GUI
  • IPv4/IPv6 access
  • SSL (HTTPS)
• Command Line Interface (CLI)
• Telnet Server
• TFTP Client
• Secured FTP (SFTP) Server
• SNMP
  • v1/v2c/v3
• SNMP Traps
• Telnet Server
• Telnet Client for IPv4/IPv6
• sFlow
• DHCP Client
• DHCP Server
• DHCP Auto-Configuration
• DHCP/DHCPv6 Local Relay
• DHCP Relay Option 82
• Flash File System
• Debug command
• IPv4 SNTP Server
• Network Time Protocol (NTP)
• Password recovery/ encryption
• BootP/DHCP Client
• System Log
• SNTP
• ICMPv6
• RMON v1/v2
• Trusted host
• Dual image
• Command logging
• Zero Touch Provisioning (ZTP)
Green Feature
• Power saving by link status
MIBs
• RFC1065, RFC1066, RFC1155, RFC1156, RFC2578 MIB Structure
• RFC1213 MIBII
• RFC1493, RFC4188 Bridge MIB
• RFC1157, RFC2571, RFC2572, RFC2573, RFC2574, RFC2575, RFC2576 SNMP MIB
• RFC1442, RFC1901, RFC1902, RFC1903, RFC1904, RFC1905, RFC1906, RFC1907, RFC1908, RFC2578, RFC3418, RFC3636 SNMPv2 MIB
• RFC2819 RMON MIB
• RFC2021 RMONv2 MIB
• RFC1398, RFC1643, RFC1650, RFC2358, RFC2665, RFC3635 Ether-like MIB
• RFC2674, RFC4363 802.1p MIB
• RFC2233, Interface Group MIB
• RFC4133 Entity MIB
• Private MIB
• RFC3621 Power Ethernet MIB
• LLDP-MED MIB
• IPv4 Multicast Routing MIB
• IP Forwarding Table MIB
RFC Standards
• RFC791 IP
• RFC768 UDP
• RFC793 TCP
• RFC792 ICMPv4
• RFC2463, RFC4443 ICMPv6
• RFC4884 Extended ICMP to Support Multi-Part Messages
• RFC826 ARP
• RFC1338, RFC1519 CIDR
• RFC2474, RFC3168, RFC3260 Definition of the DS Field in the IPv4 and IPv6 headers
• RFC2571 SNMP Framework
• RFC1886 DNS extension support for IPv6
• RFC1981 Path MTU Discovery for IPv6
• RFC2460 IPv6
• RFC2461, RFC4861 Neighbor Discovery for IPv6
• RFC2462, RFC4862 IPv6 Stateless Address Autoconfiguration (SLAAC)
• RFC3513, RFC4291 IPv6 Addressing Architecture
• RFC2893, RFC4213 IPv4/IPv6 dual stack function
• RFC2068, RFC2616
• RFC2866 RADIUS Accounting
• RFC2574 User-based Security Model for SNMPv3
• RFC854 Telnet
• RFC2131 DHCP Client
Physical Parameters
Power Input
• 48-60 V DC terminal block dual input
Power Consumption
• Maximum: 27.35 W
• Standby: 14.28 W
Heat Dissipation
• 27.33 W (93.32 BTU/hr)
MTBF
• > 200,000 hours
Acoustic
• 0 dB
Ventilation
• Fanless
Surge Protection
• Built-in 6 KV surge protection on copper ports
Dimensions
• 140 x 100 x 170 mm
Weight
• 2.2 kg
Temperature
• Operating: -40° to 75°C
• Storage: -40° to 85°C
Humidity
• Operating: 5% to 95% non-condensing
• Storage: 5% to 95% non-condensing
Certificates
• RoHS
Safety
• cUL
• CB
• CE
• BSMI
EMI
• CE Class A
• VCCI Class A
• FCC Class A
• IC
• BSMI
• RCM
תקנים
הורדות
DIS-310G-24X   Layer 3 Industrial Managed Switch with 16x10/100/1000Base-T Ports, 4x1000Base-X SFP Ports and 4x10GBase-X SFP+ Ports
איורים
DIS-310G-24X/A1
מראה מקדימה
מראה מימין
מראה משמאל
Top view
דף מידע
ראה גם
