DGS-1210-10XS/MEחדש
Managed L2 Switch with 8 x 100/1000Base-X SFP ports and 2 x 10GBase-T/SFP+ combo ports
תאור
The DGS-1210-10XS/ME is an ideal solution for Metro Ethernet networks. This switch features 8 x 100/1000Base-X SFP ports and 2 x 10GBase-T/SFP+ combo ports. The DGS-1210-10XS/ME supports Auto Voice VLAN, providing maximum priority for voice traffic, and offers a comprehensive set of security and authentication features to protect the network from both internal and external threats.
High Availability / Performance
The DGS-1210-10XS/ME supports Spanning Tree Protocols (STP) including 802.1D-2004, 802.1w,  and 802.1s. These protocols provide backup paths for data transmission in case of network failures, ensuring high availability.The switch also supports 802.3ad Link Aggregation,allowing multiple ports to be grouped together to increase bandwidth and improve link redundancy. For Quality of Service (QoS), the DGS-1210-10XS/ME complies with 802.1p, offering 8 hardware queues with Strict Priority and Weighted Round Robin (WRR) scheduling. Packet classification can be based on ToS, DSCP, MAC address, IPv4/IPv6 address, VLAN ID, TCP/UDP port, protocol type, or user-defined packet content, providing flexible configuration for multimedia applications such as VoIP or IPTV.
Auto Voice VLAN
The DGS-1210-10XS/ME features Auto Voice VLAN, which automatically detects VoIP devices in the network and assigns them to dedicated VLANs. Voice traffic within these VLANs is given highest priority, ensuring clear, uninterrupted audio and reliable VoIP performance even under heavy network load. This feature simplifies deployment and guarantees optimal service for voice applications.
Security & Authentication
The DGS-1210-10XS/ME supports IEEE 802.1X port-based/host-based access control, Guest VLAN, and RADIUS/TACACS+ authentication for secure network access. The IP-MAC-Port Binding feature allows administrators to control device access based on IP and MAC addresses, as well as the port number, providing enhanced access management capabilities. The built-in D-Link Safeguard Engine™ identifies and prioritizes packets destined for the switch CPU to prevent malicious attacks that could disrupt normal operation. Additionally, the Access Control List (ACL) feature improves network security and switch performance.
Management Capabilities
A user-friendly web interface provides administrators with access to advanced management features, including DHCP auto-provisioning. Switches can obtain an IP address from a TFTP server and automatically load pre-defined configuration settings, enabling centralized management. The switches support Link Layer Discovery Protocol (LLDP), which advertises the device’s identity and capabilities to neighboring devices, helping administrators manage the network topology effectively. Each port also supports cable diagnostics, which can detect cable length mismatches and other faults, simplifying troubleshooting and lowering management overhead.
Traffic & Bandwidth Control
Integrated bandwidth control allows network administrators to define throughput levels for each port, with a minimum granularity of 64 Kbps for ingress traffic. The DGS-1210-10XS/ME also supports broadcast storm protection, minimizing the risk of network attacks caused by broadcast traffic. Port mirroring simplifies traffic diagnostics and allows administrators to monitor switch performance and adjust it as needed. Support for IGMP Snooping reduces unnecessary multicast traffic, optimizing network bandwidth and overall performance.
Multicast Applications
The DGS-1210-10XS/ME supports a full set of Layer 2 multicast functions, including IGMP Snooping, IGMP filtering, Fast Leave, and multicast traffic configuration on specific ports. With L2 multicast support, the switch is fully capable of handling growing IPTV applications. Host-based IGMP/MLD Snooping allows multiple multicast subscribers to share a single network interface. Using ISM VLAN, multicast traffic is delivered within a dedicated VLAN, efficiently conserving bandwidth. ISM VLAN profiles enable users to quickly assign or replace pre-configured multicast settings on subscriber ports, simplifying network management.
מאפיינים כללים
Hardware Design
CPU
• 1,4 GHz
RAM
• 1 024 MB
Flash
• 128 MB
Interfaces
• 8 x 100/1000Base-X SFP
• 2 x Combo 100/1000/2.5G/5G/10GBase-T/SFP+
• RJ-45 console port
LEDs
• Power
• Link/Activity (for 1000Base-X SFP)
• Link/Activity/Speed (for 10GBase-T and 10GBase-X SFP+)
• Console
• RPS
Button
• RPS
Power
• Power connector (AC)
• RPS connector1
Other Port Standards & Functions
• IEEE 802.3u 100Base-TX
• IEEE 802.3ab 1000Base-T
• IEEE 802.3bz 2.5GBase-T
• IEEE 802.3bz 5GBase-T
• IEEE 802.3an 10GBase-T
• IEEE 802.3u 100Base-FX
• IEEE 802.3z 1000Base-X
• IEEE 802.3ae 10GBase-X
• Auto-Negotiation
• IEEE 802.3x Flow Control
• Auto MDI/MDIX
Full/Half-Duplex
• Full/half-duplex for 10/100 Mbps speeds
• Full-duplex for 1000 Mbps speed
Performance
Switching Capacity
• 56 Gbps
Transfer Mode
• Store-and-forward
MAC Address Table Size
• 16K entries
64-byte Max. Forwarding Rate
• 41,66 Mpps
Packet Buffer
• 1,5 MB
Jumbo Frame
• 10 240 bytes
Software
L2 Features
• MAC Address Table: 16K
• Flow Control
  - 802.3x
  - HOL Blocking Prevention
• Link Aggregation
  - 802.1AX
  - 802.3ad
  - Supports max 8 groups per device/8 ports per group
• Spanning Tree Protocol
  - 802.1D STP
  - 802.1w RSTP
  - 802.1s MSTP
  - BPDU Filtering
  - Root Guard (Restriction)
  - Loop Guard
• Loopback Detection
• Port Mirroring
  - Support One-to-One, Many-to-One, Flow-based (ACL) mirroring for ingress traffic
  - Supports 1 mirroring group
  - Supports Mirroring for both Tx/Rx
• Flow mirroring
  - Supports Mirroring for Rx
• VLAN Mirroring
• RSPAN
• L2 Protocol Tunneling
L2 Multicasting
• IGMP Snooping
  - IGMP v1/v2/v3
  - IGMP v3 awareness
  - IGMP Authentication
  - Support 1024 groups
  - VLAN/host-based IGMP Snooping Fast Leave
  - Report Suppression
  - IGMP Snooping Querier
  - Data Driven Learning
• MLD Snooping
  - MLD v1/v2
  - MLD v2 awareness
  - Port-based MLD Snooping Fast Leave
  - MLD Snooping Querier
VLAN
• 802.1Q Tagged VLAN
• VLAN group:
  - Max. 4094 VLAN groups
• Port-based VLAN
• GVRP
  - Max. 256 Dynamic VLAN Groups
• Auto Surveillance VLAN
• 802.1v Protocol VLAN
• Voice VLAN
• MAC-based VLAN
• Multicast VLAN (ISM VLAN for IPv4/IPv6)
• Asymmetric VLAN
• Private VLAN
• VLAN Trunking
• Port-based Q-in-Q
• Q-in-Q Selective
• 8 queues per port
• Queue Handling
  - Strict Priority
  - Weighted Round Robin (WRR)
• CoS based on:
  - Switch port
  - 802.1p priority queues
  - VLAN ID
  - MAC address
  - IPv4/IPv6 address
  - DSCP
  - ToS
  - Protocol type
  - TCP/UDP port
  - IPv6 traffic class
• Bandwidth Control
  - Port-based (Ingress, Min. Granularity 64 Kbps)
   - Flow-based (Ingress, Min. Granularity 64 Kbps)
   - Egress queue bandwidth control (Min. Granularity 64 Kbps)
L3 Features
• ARP
  - Max. 768 ARP entries
  - Supports 768 static ARP entries
• Gratuitous ARP
• IP Interfaces: 4
• Default Route
• Static route
  - Supports 64 IPv4 static routes
  - Supports 32 IPv6 static routes
• ACL based on
  - MAC address
  - IPv4/IPv6 address
  - Protocol type
  - TCP/UDP port number
• Up to 768 ingress access rules
• Time-based ACL
• CPU interface filtering
Security
• Port Security
  - Up to 64 MAC addresses per port
• Broadcast/multicast/unicast storm control
• D-Link Safeguard Engine
• DHCP Server Screening
• IP Source Guard
• DHCP Snooping
• IPv6 ND Snooping
• IP-MAC-Port Binding (IMPB)
  - ND Snooping IPv6
  - ARP inspection
  - IP inspection
  - IPv6 DHCP snooping
• Traffic segmentation
• SSL
  - Supports v1/v2/v3
  - Supports TLS 1.0/1.1/1.2/1.3
  - Supports IPv4/IPv6 access
• SSH
  - Supports SSH v2
• DHCP client filtering
• BPDU attack protection
• DoS attack prevention
• Duplicate Address Detection (DAD)
OAM
• 802.3ah Ethernet Link OAM
• D-Link Unidirectional Link Detection (DULD)
• Dying Gasp
• Y.1731 OAM
• Cable diagnostics
• Digital Diagnosics Monitoring (DDM)
AAA
• 802.1X:
  - Supports port/host-based access control
  - Identity-driven Policy Assignment
  - Supports local/RADIUS database
  - Supports EAP, OTP, TLS, TTLS, PEAP
• Guest VLAN
• Support MD5 authentication
• Trusted Host
• RADIUS/TACACS+ Accounting
• User account privilege (4 level user access)
• Web-based Access Control (WAC)
  - Host-based Access Control
  - Identity Driven WAC policy assignment
  - Dynamic VLAN Assignment
  - Bandwidth Control Assignment
  - ACL Assignment
• RAIDUS and TACACS+ Authentication
• Microsoft® NAP
  - Support 802.1X NAP
  - Support DHCP NAP
• MAC-based Access Control (MAC)
  - Host-based access control
  - ACL Assignment
Management
• Web-based GUI
  - Support IPv4/IPv6 access
  - Support SSL (HTTPS)
• Command Line Interface (CLI)
• Telnet Server for IPv4/IPv6
• Telnet Client for IPv4/IPv6
• TFTP Client for IPv4/IPv6
• DNS Client for IPv4/IPv6
• FTP Client for IPv4/IPv6
• SNMP
  - Support v1/v2c/v3
• SNMP Traps
• System Log for IPv4/IPv6 Syslog Server
• sFlow
• RMON v1
• RMON v2:
  - Supports Probe Config group
• LLDP/LLDP-MED
• BootP/DHCP client
• DHCP Auto-configuration
• DHCP/DHCPv6 Local Relay
• DHCP Relay Option 12/58/59/77/82
• DHCP auto-image
• PPPoE Circuit-ID insertion
• D-Link Discover Protocol (DDP)
• SNTP
• Password recovery
• Password encryption
• Command Logging
• SMTP
• DHCPv6 Prefix Delegation (PD)
• Ping/Traceroute for IPv4/IPv6
• Zero Touch Provisioning (ZTP)
Green Features
• IEEE 802.3az Energy Efficient Ethernet (EEE)
• Power Saving by:
  - Link Status
  - LED Shutoff
  - Port Shutoff
  - System Hibernation
MIB Standards
• RFC1065, RFC1155, RFC2578 MIB Structure
• RFC1213 MIBII
• RFC1493 Bridge MIB
• RFC1157, RFC2573, RFC2575, RFC2576 SNMP MIB
• RFC3418 SNMPv2 MIB
• RFC2819 RMON MIB
• RFC2021 RMONv2 MIB
• RFC1643, RFC1650, RFC2665, Ether-like MIB
• RFC2674 802.1p MIB
• RFC2233 Interface Group MIB
• RFC4022 MIB for TCP
• RFC4113 MIB for UDP
• RFC2389 MIB for Diffserv.
• RFC2925 Ping & TRACEROUTE MIB
• TFTP uploads and downloads (D-Link MIB)
• Trap MIB (D-Link MIB)
• DDM MIB (D-Link MIB)
• Private MIB
• RFC3621 Power Ethernet MIB
• DDP MIB
• LLDP-MED MIB
IETF Standards
• RFC768 UDP
• RFC791 IP
• RFC793 TCP
• RFC792 ICMPv4
• RFC2463, RFC4443 ICMPv6
• RFC826 ARP
• RFC1338, RFC1519 CIDR
• RFC2474, RFC3168, RFC3260 Definition of the DS Field in the IPv4 and IPv6 Headers
• RFC1321, RFC2284, RFC2865, RFC2716, RFC3580 Extensible Authentication Protocol (EAP)
• RFC2573, SNMP Applications
• RFC2574 User-based Security Model for SNMPv3
IPv6
• RFC1981 Path MTU Discovery
• RFC2460 IPv6
• RFC2461, RFC4861 Neighbor Discovery for IPv6
• RFC2462, RFC4862 IPv6 Stateless Address Auto-configuration (SLAAC)
• RFC3513, RFC4291 IPv6 Addressing Architecture
• RFC2893, RFC4213 IPv4/IPv6 dual stack function
Physical Parameters
Dimensions (W × D× H)
• 280 x 180 x 44 mm
Weight
• 0,978 kg
Operating Conditions
Power
• 100-240V AC, 50/60 Hz
Max Power Consumption
• 17,97W
Standby Power Consumption
• 6,49W
Heat Dissipation
• 17,95W (61,3 BTU/h)
Electrostatic Discharge Protection (ESD)
• Up to 6 kV on copper ports (IEC 61000-4-5)
Ventilation System
• Fanless
Temperature
• Operating: 0 to 50 °C
• Storage: -25 to 70 °C
Humidity
• Operating: 10% to 90% (non-condensing)
• Storage: 5% to 90% (non-condensing)
Package Contents
• DGS-1210-10XS/ME Switch
• Power Cord
• Power cord retainer
• RJ-45 Console Cable
• 2 x brackets for 19-inch rack mounting
• 4 x rubber feet
• Mounting kit
• Quick Installation Guide
Certifications
• RoHS
Safety
• CE
• LVD
• UL
• CB
EMI
• FCC Class A
• CE Class A
• VCCI
• BSMI
• CCC
תקנים
הורדות
DGS-1210-10XS/ME  Managed L2 Switch with 8 x 100/1000Base-X SFP ports and 2 x 10GBase-T/SFP+ combo ports
Supported Devices
SFP Transceivers
DGS-712 1000Base-T SFP (RJ45), up to 100 m
DEM-310GT 1000Base-LX SFP (Duplex LC), 1310 nm, single-mode, up to 10 km
DEM-311GT 1000Base-SX SFP (Duplex LC), 850 nm, multi-mode, up to 550 m
DEM-312GT2 1000Base-SX+ SFP (Duplex LC), 1310 nm, multi-mode, up to 2 km
DEM-314GT 1000Base-LX SFP (Duplex LC), 1550 nm, single-mode, up to 50 km2
DEM-315GT 1000Base-ZX SFP (Duplex LC), 1550 nm, single-mode, up to 80 km2
WDM SFP Transceivers
DEM-330T/3KM  1000Base-BX-D SFP (Simplex SC), TX: 1550 nm, RX: 1310 nm, single-mode, up to 3 km
DEM-330R/3KM 1000Base-BX-U SFP (Simplex SC), TX: 1310 nm, RX: 1550 nm, single-mode, up to 3 km
DEM-330T/10KM  1000Base-BX-D SFP (Simplex LC), TX: 1550 nm, RX: 1310 nm, single-mode, up to 10 km
DEM-330R/10KM  1000Base-BX-U SFP (Simplex LC), TX: 1310 nm, RX: 1550 nm, single-mode, up to 10 km
DEM-331T/20KM  1000Base-BX-D SFP (Simplex LC), TX: 1550 nm, RX: 1310 nm, single-mode, up to 20 km
DEM-331R/20KM  1000Base-BX-U SFP (Simplex LC), TX: 1310 nm, RX: 1550 nm, single-mode, up to 20 km
DEM-331T/40KM  1000Base-BX-D SFP (Simplex LC), TX: 1550 nm, RX: 1310 nm, single-mode, up to 40 km2
DEM-331R/40KM  1000Base-BX-U SFP (Simplex LC), TX: 1310 nm, RX: 1550 nm, single-mode, up to 40 km2
SFP+ Transceivers
DEM-431XT  10GBase-SR SFP+ (Duplex LC), 850 nm, multi-mode, up to 300 m
DEM-432XT  10GBase-LR SFP+ (Duplex LC), 1310 nm, single-mode, up to 10 km
DEM-433XT  10GBase-ER SFP+ (Duplex LC), 1550 nm, single-mode, up to 40 km2
DEM-434XT  10GBase-ZR SFP+ (Duplex LC), 1550 nm, single-mode, up to 80 km2
DEM-435XT  10GBase-LRM SFP+ (Duplex LC), 1310 nm, multi-mode, up to 200 m
WDM SFP+ Transceivers
DEM-436XT-BXD/40KM  10GBase-BX-D SFP+ (Simplex LC), TX: 1330 nm, RX: 1270 nm, single-mode, up to 40 km2
DEM-436XT-BXU/40KM  10GBase-BX-U SFP+ (Simplex LC), TX: 1270 nm, RX: 1330 nm, single-mode, up to 40 km2
DEM-436XT-BXD/20KM  10GBase-BX-D SFP+ (Simplex LC), TX: 1330 nm, RX: 1270 nm, single-mode, up to 20 km
DEM-436XT-BXU/20KM  10GBase-BX-U SFP+ (Simplex LC), TX: 1270 nm, RX: 1330 nm, single-mode, up to 20 km
10G SFP+ Cables
DEM-CB100S  10GBase-X SFP+ passive DAC, 1 m
DEM-CB300S  10GBase-X SFP+ passive DAC, 3 m
DEM-CB700S  10GBase-X SFP+ passive DAC, 7 m
40G QSFP+ / 10G SFP+ Cables
DEM-CB100QXS-4XS 40G QSFP+ Passive Direct Attach Cable (DAC), 1x QSFP+ to 4x 10GBase-X SFP+, 1 m  (For connecting to switches with 40G QSFP+ ports)
Redundant Power Supply1
DPS-500A  AC redundant power supply for switches, 140 W
DPS-500DC/B  DC redundant power supply for switches, 140 W
DPS-CB150-2PS/B  Power cable for connecting redundant power supply to switches, 1.5 m
1Not included
2Operation over short distances requires the use of an attenuator. Not included.
איורים
DGS-1210-10XS/ME/C1
מראה מקדימה
מראה מימין
מראה משמאל
מראה מאחורה
דף מידע
ראה גם
