DGS-1005A/G
5-Port 10/100/1000 Mbps Unmanaged Switch
תאור
The DGS-1005A Unmanaged Switch is economical, plug-and-play networking switch solution for SOHO and small and medium businesses wanting to benefit from the increased bandwidth of Gigabit Ethernet. It provides five 10/100/1000 Mbps ports that enable you to easily expand your network and provide a quick way to upgrade your network to fast connectivity.
Upgrade to Gigabit Networking
With data transfer speeds of up to 2000 Mbps at full duplex, this switch is ideal for quick file transfers, online gaming and smooth streaming media. It features easy-to-access Ethernet ports with LED indicators per port to easily distinguish link status. Auto MDI/MDIX crossover makes connection a cinch; just plug in your cables and you’re ready to go.
Conserve Energy
The DGS-1005A implements 802.3az Energy Efficient Ethernet, which saves energy and reduces heat automatically without sacrificing performance or functionality. The switch can detect when a connected computer is shut down or when there is no Ethernet traffic, and will put the port in standby mode, saving a substantial amount of power.
Reliable Plug and Play Installation
The DGS-1005A is Plug-and-Play device that requires no configuration, so setup is simple and hassle-free, and you can easily connect multiple computers, share files, music, and video across your home or small office network, or even create a multiplayer gaming environment. 802.3x flow control on each port minimizes dropped packets when the port’s receiving buffer is full, giving you a more reliable connection for all of your connected devices.
Smooth Streaming
This switch supports QoS, which prioritizes network traffic so that time-sensitive data is delivered efficiently, even during bursts of high data traffic. This helps ensure an optimal experience for streaming media and VoIP calls.
מאפיינים כללים
Device Interfaces
• 5 10/100/1000 Mbps LAN ports
Standards
• IEEE 802.3 10BASE-T
• IEEE 802.3u 100BASE-TX
• IEEE 802.3ab 1000BASE-T
• IEEE 802.3x Flow Control
• IEEE 802.1p QoS (8 queues)
Switching Capacity
• 10 Gbps switching fabric
Advanced Features
• Auto MDI/MDIX adjustment for all ports
• Secure store-and-forward switching scheme
• Full/half-duplex for Ethernet/Fast Ethernet speeds
• Supports 15 KB jumbo frame
• Store and-Forward switching method
• Auto-negotiation for each port
Data Transfer Rates
• Ethernet:
  • 10 Mbps (half duplex)
  • 20 Mbps (full duplex)
• Fast Ethernet:
  • 100 Mbps (half duplex)
  • 200 Mbps (full duplex)
• Gigabit Ethernet
  • 2000 Mbps (full duplex)
Transmission Method
• Store-and-forward
MAC Address Table Size
• 2K
Max. Packet Forwarding Rate
• 7.44 Mpps
RAM Buffer
• 384 KB
LEDs
• Per port: Link/Act
• Per device: Power
Physical Parameters
Dimensions
• 94 x 75 x 22.45 mm
Weight
• 75 g
Power
• DC 5 V / 1 A
Power Consumption
• Power On (Standby): 1.13 W
• Maximum: 2.56 W
Temperature
• Operating: 0° to 40°C
• Storage: -10° to 70°C
Humidity
• Operating: 10% to 90% (Non-condensing)
• Storage: 5% to 90% (Non-condensing)
MTBF
• 1 531 223 hours
Maximum Heat Dissipation
• 8.74 BTU/h
Certifications
• CE Class B
• FCC Class B
• ICES-003 Class B
• VCCI Class B
• LVD
• RCM
• Anatel
• BSMI
תקנים
הורדות
DGS-1005A/G1A
איורים
DGS-1005A/G/G
מראה מקדימה
מראה מימין
מראה מקדימה
מראה משמאל
מראה מאחורה
דף מידע
ראה גם
