![](/up/prod/600/DEM-QX10Q-LR4.jpg)
DEM-QX10Q-LR4
40GBase-LR4 Single-mode QSFP+ Transceiver (up to 10 km)
תאור
D-Link's 40G QSFP+ Module series are hot-swappable QSFP+ transceivers that plug into QSFP+ slots on switches and support 40G Ethernet. The D-Link 40GBase QSFP+ Module Series transceivers offer customers a wide variety of 40G Ethernet connectivity options for data centers, enterprise wiring closets, and service provider transport applications.
Quad Small Form-factor Pluggable Plus Format
The transceivers use the Quad Small Form-factor Pluggable Plus format (QSFP+) connectors,which integrate four transmitting and four receiving channels. QSFP+ supports up to 10.5 Gb/s per channel for applications such as 40G Ethernet.
Hot Pluggable
All D-Link transceivers are hot pluggable. You can connect atransceiver while the system is powered on without causing any issues, and easily swap one for another without having to reboot the switch each time. This permits modules to be added or removed without interrupting the network, facilitating maintenance and greatly reducing downtime.
40G Ethernet speeds
The transceivers all support 40G Ethernet, which results in very fast data transmissions of up to 40 Gbit/s. This is 40 times faster than Gigabit Ethernet and enables the switch to handle faster and higher data transmissions, making it very suitable for business needs.
מאפיינים כללים
Transceiver Type
• QSFP+
Fiber Media support
• Single-mode
Distance Capacity
• 10 km
Compliant Standard
• IEEE 802.3ba, 40GBase-LR4
Connector
• Duplex LC
Single/Bi Direction
• Single direction
Wavelength
• 1271 nm, 1291 nm, 1311 nm, 1331 nm
Output Optical Power (TX)
• Max.: 2.3 dBm
• Min.: -7 dBm
Input Optical Power (RX)
• Max.: 2.2 dBm
• Min.: -13.7 dBm
Sensitivity
• -11.5 dBm
Cable Type
• Single mode 9/125 um fiber cable
Supported Features
• Hot Pluggable
• MSA Compliant
Physical Parameters
Power
• 3.3 V
Max. Input Current
• 1.1 A
Dimensions
• 71.8 mm x 18.3 mm x 8.5 mm
Operating Temperature
• 0 to 70 °C
Storage Temperature
• -20 to 85 °C
Operating Humidity
• 5% ~ 85%
Storage Humidity
• 5% ~ 85%
Certificates
• RoHS
תקנים
הורדות
DEM-QX10Q-LR4/B1A
