DIR-860LEOL EOS
Wireless AC1200 Dual-Band Gigabit Cloud Router USB 3.0
Description
The DIR-860L Wireless AC1200 Dual-Band Gigabit Cloud Router USB 3.0 lets you easily connect, control, and monitor a network using the future of wireless technology, today. It’s mydlink Cloud-enabled and supports the SharePort Mobile app to stream and share your media files.
Fast and Reliable Home Networking
The D-Link DIR-860L Wireless AC1200 Dual-Band Gigabit Cloud Router USB 3.0 creates a blazing fast home network that connects all of your computers and mobile devices to your broadband Internet connection. Concurrent dual-band 802.11ac brings you the future of high-bandwidth wireless connectivity allowing you to stream HD video, make Internet calls, and surf the Internet from every corner of your home without interruption. Gigabit Ethernet ports provide high-speed wired connections for up to four PCs or other devices. It’s stylish, easy-to-use, and comes IPv6-ready for a reliable network today and tomorrow.
Use mydlink to Monitor Your Network
The Wireless AC1200 Dual-Band Gigabit Cloud Router USB 3.0 is mydlink Cloud-enabled, so you can effortlessly access and view your network no matter where you are. See who is connected to your router, change settings, or block someone from using your network connection, all from any Internet connected PC, or an iOS or Android mobile device. Parents can monitor what sites their children are visiting, and can stay informed and in control on the go.
File Sharing Right at Your Fingertips
The SharePort Mobile app allows you to connect a USB storage device to the DIR-860L and instantly share documents, movies, pictures, and music with mobile devices. You can put your music library on a USB drive and share it with your entire home. You can show photos on the  living room TV while a family member watches a movie on their mobile device. You can stream media files to multiple devices without interruption, or save them to your device for offline playback. The intuitive interface lets anyone immediately connect to a variety of entertainment options stored securely on your own storage device.
Smooth Streaming with Wireless AC
The DIR-860L uses the latest Wireless AC technology, which can provide transfer rates of up to 1.2Gbps* (900AC + 300N). The router operates on both the 2.4 GHz and 5 GHz wireless bands at the same time using concurrent dual-band technology and four internal antennas. This allows you to browse the web, chat and email using the 2.4 GHz band, while simultaneously streaming digital media, playing online games, or making Internet phone calls on the 5 GHz band.
Easy to Set Up and Use
Get the DIR-860L up and running in no time right from your couch using the QRS (Quick Router Setup) Mobile app on your iOS or Android device. Simply plug in the router, open the app, and follow a few easy steps to get your home network connected without having to touch a computer. You can also set up a secure network with the touch of a button using Wi-Fi Protected Setup. Simply press the WPS button to instantly establish a secure connection to a new device. If you have additional mydlink cloud products, you can take advantage of mydlink Zero Configuration. Simply connect your mydlink-enabled device to the DIR-860L and the router will automatically link it to your mydlink account with no configuration required.
General features
Device Interfaces
• 802.11 a/b/g/n/ac wireless LAN
• Four 10/100/1000 Gigabit LAN ports
• 10/100/1000 Gigabit WAN port
• USB 3.0 port
Antenna Type
• Four internal antennas
Standards
• IEEE 802.11ac (draft)
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• IEEE 802.11a
• IEEE 802.3
• IEEE 802.3u
Wireless Speed
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mbit/s
• IEEE 802.11b: 1, 2, 5.5, 11 Mbit/s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbit/s
• IEEE 802.11n (2.4 GHz/5 GHz): 6.5 to 300 Mbit/s (MCS0 to MCS15)
• IEEE 802.11ac: from 6.5 to 866 Mbit/s
Output Power of Transmitter
• IEEE 802.11a:
  17 dBm (+/-2dB) at 6, 9 Mbit/s
  17 dBm (+/-2dB) at 12~36 Mbit/s
  16 dBm (+/-2dB) at 48 Mbit/s
  15 dBm (+/-2dB) at 54 Mbit/s
• IEEE 802.11b: 17dBm at 1, 2, 5.5, 11 Mbit/s
• IEEE 802.11g:
  17 dBm at 6, 9 Mbit/s
  17 dBm at 12, 18 Mbit/s
  17 dBm at 24, 36, 48 Mbit/s
  16 dBm at 54 Mbit/s
• IEEE 802.11n (5 GHz):
  HT20
  17dBm (+/-2dB) at MCS0/1 and MCS8~9
  17dBm (+/-2dB) at MCS2~MCS5 and MCS10~MCS13
  16dBm (+/-2dB) at MCS6 and MCS14
  15dBm (+/-2dB) at MCS7 and MCS15
  HT40
• IEEE 802.11n (2.4 GHz)
  HT20
  14dBm at MCS0/1 and MCS8~9
  14dBm at MCS2~MCS5 and MCS10~MCS13
  14dBm at MCS6 and MCS 14
  14dBm at MCS7 and MCS 15
  HT40
  12dBm at MCS0/1 and MCS8~9
  12dBm at MCS2~MCS5 and MCS10~MCS13
  12dBm at MCS6 and MCS14
  12dBm at MCS7 and MCS15
• IEEE 802.11ac (5GHz)
  HT20
  17dBm at MCS0/1 and MCS9~10
  17dBm at MCS2~MCS5 and MCS11~MCS14
  16dBm at MCS6 and MCS15
  15dBm at MCS7 and MCS16
  14dBm at MCS8 and MCS17
  HT40
  17dBm at MCS0/1 and MCS10~11
  17dBm at MCS2~MCS5 and MCS12~MCS15
  16dBm at MCS6 and MCS16
  15dBm at MCS7 and MCS17
  14dBm at MCS8 and MCS18
  13dBm at MCS9 and MCS19
  HT80
  16dBm at MCS6 and MCS 16
  15dBm at MCS7 and MCS 17
  14dBm at MCS8 and MCS 18
  13dBm at MCS9 and MCS 19
Receiver Sensitivity
• IEEE 802.11a:
  -82dBm at 6 Mbit/s
  -81dBm at 9 Mbits/s
  -79dBm at 12 Mbit/s
  -77dBm at 18 Mbit/s
  -74dBm at 24 Mbit/s
  -70dBm at 36 Mbit/s
  -66dBm at 48 Mbit/s
  -65dBm at 54 Mbit/s
• IEEE 802.11b:
  -76 dBm at 2 Mbit/s
  -76 dBm at 11 Mbit/s
• IEEE 802.11g:
  -82 dBm at 6 Mbit/s
  -81 dBm at 9 Mbits/s
  -79 dBm at 12 Mbit/s
  -77 dBm at 18 Mbit/s
  -74 dBm at 24 Mbit/s
  -70 dBm at 36 Mbit/s
  -66 dBm at 48 Mbit/s
  -65 dBm at 54 Mbit/s
  HT20
  -82dBm at (MCS0/8)
  -79dBm at (MCS1/9)
  -77dBm at (MCS2/10)
  -74dBm at (MCS3/11)
  -70dBm at (MCS4/12)
  -66dBm at (MCS5/13)
  -65dBm at (MCS6/14)
  -64dBm at (MCS7/15)
  HT40
  -79dBm at (MCS0/8)
  -76dBm at (MCS1/9)
  -74dBm at (MCS2/10)
  -71dBm at (MCS3/11)
  -67dBm at (MCS4/12)
  -63dBm at (MCS5/13)
  -62dBm at (MCS6/14)
  -61dBm at (MCS7/15)
• IEEE 802.11n (2.4 GHz):
  HT20
  -82dBm at (MCS0/8)
  -79dBm at (MCS1/9)
  -77dBm at (MCS2/10)
  -74dBm at (MCS3/11)
  -70dBm at (MCS4/12)
  -66dBm at (MCS5/13)
  -65dBm at (MCS6/14)
  -64dBm at (MCS7/15)
  HT40
  -79dBm at (MCS0/8)
  -76dBm at (MCS1/9)
  -74dBm at (MCS2/10)
  -71dBm at (MCS3/11)
  -67dBm at (MCS4/12)
  -63dBm at (MCS5/13)
  -62dBm at (MCS6/14)
  -61dBm at (MCS7/15)
• IEEE 802.11ac (5GHz):
  HT20
  -82dBm at (MCS0)
  -79dBm at (MCS1)
  -77dBm at (MCS2)
  -74dBm at (MCS3)
  -70dBm at (MCS4)
  -66dBm at (MCS5)
  -65dBm at (MCS6)
  -64dBm at (MCS7)
  -59dBm at (MCS8)
  -57dBm at (MCS9)
  HT40
  -79dBm at (MCS0)
  -76dBm at (MCS1)
  -74dBm at (MCS2)
  -71dBm at (MCS3)
  -67dBm at (MCS4)
  -63dBm at (MCS5)
  -62dBm at (MCS6)
  -61dBm at (MCS7)
  -56dBm at (MCS8)
  -54dBm at (MCS9)
  HT80
  -76dBm at (MCS0)
  -73dBm at (MCS1)
  -71dBm at (MCS2)
  -68dBm at (MCS3)
  -64dBm at (MCS4)
  -60dBm at (MCS5)
  -59dBm at (MCS6)
  -58dBm at (MCS7)
  -53dBm at (MCS8)
  -51dBm at (MCS9)
Minimum System Requirements
• Windows 7/Vista/XP SP3 or Mac OS X 10.4 or higher
• Microsoft Internet Explorer 6 or higher, Firefox 1.5 or higher, or other Java-enabled browser
• CD-ROM
• Ethernet network interface
• Cable or DSL modem
• Subscription with an Internet Service Provider
Advanced Features
• Guest Zone
• SharePort™ web access
• Multi-language web setup wizard
• Green Ethernet
• DLNA Media server support
• Dual Active Firewall
• VPN passthrough/multi-session PPTP/L2TP/IPSec
mydlink Features
• Remote Management
• View current upload/download bandwidth
• View currently connected clients
• View web browsing history per client
• Block/unblock client network access
• Manage wireless network details
• Accessible through a web browser or iOS or Android mobile app
Mobile App Support
• mydlink Lite
• SharePort Mobile
• QRS Mobile
Wireless Security
• WPA & WPA2 (Wi-Fi Protected Access)
• Wi-Fi Protected Setup (WPS) PIN/PBC
Certificates
Order info
Pictures
DIR-860LA1
Back view
Front view
Downloads
Support Resources
