DSA-2308X
Service Router with 8 Configurable Ports (6x10/100/1000Base-T, 2x10GBase-X SFP+) and 2 USB Ports
Description
The router DSA-2308X is equipped with 6 10/100/1000Base-T ports and 2 10G SFP+ ports, which provide a very high-throughput connection to deploy a larger network. The device is designed to protect SMB networks infrastructure against external threats and organize secure VPN connection. The router supports concurrent connection of a large number of users.
The advanced security functions allow to divide the network into zones, configure the zone interaction policies and traffic filtering rules with a wide range of available parameters.
The router supports multiple types of secure VPN connection tunnels: IPsec (IKEv1/IKEv2), L2TP over IPsec, PPTP/L2TP, GRE, IPIP, EoGRE, OpenVPN, WireGuard, and unmanaged L2TPv3 tunnels.
In addition, the SSH protocol support provides more secure remote configuration and management of the router due to encryption of all transmitted traffic, including passwords.
The router supports the SkyDNS web content filtering service, which provides more settings and opportunities for safer Internet experience for home users of all ages and for professional activities of corporate users.
The schedules are also implemented; they can be applied to the rules and settings of the firewall and used to reboot the router at the specified time or every specified time period and to automatically save the configuration of the router to a connected USB storage.
The new ad blocking function effectively blocks advertisements which appear during web surfing.
LAN/WAN Conversion, WAN Failover
You can use any Ethernet or SFP port of the router as LAN or WAN port. The firmware supports assigning several WAN ports, for example, in order to configure the primary and backup WAN connection of different ISPs. In addition, you can configure the WAN failover using a 3G/4G modem.
USB Ports
The router is equipped with two USB ports for connecting a USB modem, a USB storage device or a printer. You are able to quickly connect to the Internet via a USB modem and use a USB storage device as a network drive.
In order to use multifunction USB ports effectively, the router supports simultaneous operation of several USB devices. For example, you can access multimedia content of the connected HDD storage and at the same time share a USB printer.
Easy configuration and update
By default, a DHCP client WAN connection is configured for each WAN port and all settings to get started are configured.
You can customize the settings of the router DSA-2308X via the user-friendly web-based interface (the interface is available in two languages – in Russian and in English).
You can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
The built-in TR-069 client allows to perform remote configuration and diagnostics of the device.
The built-in SLA agent allows to monitor the state of the router’s network and clients and to pass the collected data in order to timely troubleshoot the problems.
General features
				 Hardware
				 Processor
				 • Intel Atom C3758 (2.2GHz, 8-core)
				 RAM
				 • 16GB, DDR4
				 Flash
				 • 32GB, eMMC
				 Interfaces
				 • 6 10/100/1000BASE-T LAN/WAN ports
				• 2 10GBase-X SFP+ LAN/WAN ports
				• USB 2.0 port
				• USB 3.0 port
				• RJ-45 console port
				 LEDs
				 • Power
				• Activity/Link (per port)
				 Buttons
				 • POWER button to power on/power off and restore factory default settings
				• RST button for hardware reboot
				• Switch to power on/power off
				 Power connector
				 • Power input connector (AC)
				 Mounting
				 • Desktop
				• 19-inch rack
				 Performance
				 Number of VPN tunnels
				 • Up to 250
				 VPN connections throughput
				 • IPsec tunnel (56-bit key)
				250Mbps
				• GRE/IPIP tunnel
				900Mbps
				• PPTP server
				70Mbps
				• L2TP server
				900Mbps
				• EoGRE tunnel
				900Mbps
				• L2TPv3 tunnel
				900Mbps
				 Maximum number of concurrent sessions
				 • 500,000
				 New sessions per second
				 • 45,000
				 Number of policies
				 • 2000
				 Software
				 Firewall functions
				 • Zones
				Division into zones; ability to specify rules and policies for zone interaction
				One or several interfaces or VPN servers in a zone
				Types of zones: FW, IPv4, IPv6, IPSec
				• Policies
				Types of policies: ACCEPT, DROP, REJECT
				• Rules for zones, network interfaces, and VPN servers
				Wide choice of parameters to add to a rule
				Exclusion of parameters from a rule
				Action upon rule activation: ACCEPT, DROP, REJECT, RETURN, REDIRECT, POLICY, MASQUERADE, DNAT, SNAT, LOG, TTL
				Port Knocking (Recent)
				Statistics collection
				• Others
				Stateful Packet Inspection (SPI)
				URL filter
				Ad blocking function
				Built-in SkyDNS web content filtering service
				Support of TWIN IP (IP Passthrough)
				 WAN connection types
				 • Mobile Internet (via supported USB modem)
				• PPPoE
				• IPv6 PPPoE
				• PPPoE Dual Stack
				• Static IPv4 / Dynamic IPv4
				• Static IPv6 / Dynamic IPv6
				• PPPoE + Static IP (PPPoE Dual Access)
				• PPPoE + Dynamic IP (PPPoE Dual Access)
				• PPTP/L2TP + Static IP
				• PPTP/L2TP + Dynamic IP
				• L2TP Dual Stack
				• IPIP6 in DSLite mode
				• 6in4
				• 6to4
				• 6rd
				 Network functions
				 • Physical
				Configuration of the device's ports according to the switch model
				Support of several physical switches
				Port tagging
				Tracking link watcher events (port connection on/off)
				Combining interfaces into network bridges
				Ports/connections statistics
				• Networks interaction
				Support of several independent LAN subnets
				Support of several physical WAN ports; WAN failover
				Network isolation or routing
				• Routing
				Static routing (flexible configuration of routes, rules, and routing tables)
				RIP v1/v2
				• Others
				DHCP server/relay
				Advanced configuration of built-in DHCP server
				Stateful/Stateless mode for IPv6 address assignment, IPv6 prefix delegation
				DNS relay
				Dynamic DNS
				IGMPx
				Support of UPnP
				Support of VLAN
				Interface grouping
				Support of SIP ALG
				Support of RTSP
				Support of H.323
				Autonegotiation of speed, duplex mode, and flow control / Manual speed and duplex mode setup for each Ethernet port
				Built-in UDPXY application
				XUPNPD plug-in
				Equal load distribution while using several WAN connections (traffic balancing)
				Support of VRRP
				Support of TWAMP
				Wake-on-LAN support
				 VPN
				 • PPPoE pass-through
				• L2TP over IPsec client
				• PPTP/L2TP servers
				• OpenVPN server/tunnels with PKI option (certificates/keys)
				• PPTP/L2TP/IPIP/GRE/WireGuard tunnels (L3)
				• EoGRE/L2TPv3 tunnels (L2)
				• IPsec tunnels
				Transport/Tunnel mode
				IKEv1/IKEv2 support
				DES/3DES/AES/BLOWFISH/CAMELLIA/SERPENT/TWOFISH encryption
				NAT Traversal
				Support of DPD (Keep-alive for VPN tunnels)
				 USB interface functions
				 • USB modem
				Auto connection to available type of supported network (4G/3G/2G)
				Auto configuration of connection upon plugging in USB modem
				Enabling/disabling PIN code check, changing PIN code1
				Sending/receiving/reading/removing SMS messages1
				Support of USSD requests1
				• USB storage
				File browser
				Print server
				Access to storage via accounts
				Built-in Samba server
				Built-in FTP server supporting TLS
				Built-in DLNA server
				Built-in Transmission torrent client; uploading/downloading files from/to USB storage
				 Management and monitoring
				 • Local and remote access to settings through SSH/TELNET/WEB (HTTP/HTTPS)
				• Bilingual web-based interface for configuration and management (Russian/English)
				• Support of logging to remote host/connected USB storage
				• Ping utility
				• Traceroute utility
				• TR-069 client
				• SNMP agent
				• SLA agent
				• Schedules for rules and settings of firewall, automatic reboot, and saving a configuration backup to a connected USB storage
				• Automatic upload of configuration file from ISP's server (Auto Provision)
				• Automatic and manual recovery points
				• iPerf3 utility (client/server)
				• Route monitoring
				 Physical Parameters
				 Dimensions (L x W x H)
				 • 428 x 270 x 44 mm (16.9 x 10.6 x 1.7 in)
				 Weight
				 • 3.28 kg (7.2 lb)
				 Operating Environment
				 Power
				 • 100 ~ 240V AC, internal power supply
				•  Power cable length: 1.4 m
				 Maximum Power Consumption
				 • 75W
				 Ventilation system
				 • 2 fans
				 Temperature
				 • Operating: from 0 to 45 °C
				• Storage: from -20 to 80 °C
				 Humidity
				 • Operating: from 5% to 90% (non-condensing)
				• Storage: from 5% to 90% (non-condensing)
				 Delivery Package
				 • Router DSA-2308X
				• Power cable
				• 2 19-inch rack mounting brackets
				• Quick Start Guide
				 Supported USB Modems2
				 GSM
				 • Alcatel X500
				• D-Link DWM-152C1
				• D-Link DWM-156A6
				• D-Link DWM-156A7
				• D-Link DWM 156A8
				• D-Link DWM-156C1
				• D-Link DWM-157B1
				• D-Link DWM-157B1 (Velcom)
				• D-Link DWM-158D1
				• D-Link DWR-710
				• Huawei E150
				• Huawei E1550
				• Huawei E156G
				• Huawei E160G
				• Huawei E169G
				• Huawei E171
				• Huawei E173 (Megafon)
				• Huawei E220
				• Huawei E3131 (MTS 420S)
				• Huawei E352 (Megafon)
				• Huawei E3531
				• Prolink PHS600
				• Prolink PHS901
				• ZTE MF112
				• ZTE MF192
				• ZTE MF626
				• ZTE MF627
				• ZTE MF652
				• ZTE MF667
				• ZTE MF668
				• ZTE MF752
				 LTE
				 • Alcatel IK40V
				• Brovi E3372-325
				• D-Link DWM-221
				• D-Link DWM-222
				• D-Link DWR-910 (revision D1)
				• Huawei E3131
				• Huawei E3272
				• Huawei E3351
				• Huawei E3372s
				• Huawei E3372h-153
				• Huawei E3372h-320
				• Huawei E367
				• Huawei E392
				• Megafon M100-1
				• Megafon M100-2
				• Megafon M100-3
				• Megafon M100-4
				• Megafon M150-1
				• Megafon M150-2
				• Megafon M150-3
				• Megafon M150-4
				• Quanta 1K6E (Beeline 1K6E)
				• MTS 824F
				• MTS 827F
				• MTS 830FT
				• Yota LU-150
				• Yota WLTUBA-107
				• ZTE MF823
				• ZTE MF823D
				• ZTE MF827
				• ZTE MF833T
				• ZTE MF833V
				 Smartphones in USB tethering mode
				 • Some models of Android smartphones
				 Compatible Equipment
				 DEM-310GT
				 1000Base-LX Single-Mode SFP transceiver (up to 10 km)
				 DEM-311GT
				 1000Base-SX Multi-Mode SFP transceiver (up to 550 m)
				 DEM-330T/10KM
				 1000Base-BX-D Single-Mode WDM SFP transceiver (LC connector, up to 10 km), Tx:1550 nm, Rx:1310 nm
				 DEM-330R/10KM
				 1000Base-BX-U Single-Mode WDM SFP transceiver (LC connector, up to 10 km), Tx:1310 nm, Rx:1550 nm
				 DEM-432XT
				 10GBase-LR Single-Mode SFP+ transceiver (up to 10 km)
				 DEM-433XT
				 10GBase-ER Single-Mode SFP+ transceiver (up to 40 km)
				 DEM-436XT-BXD
				 10GBase-LR Single-Mode WDM SFP+ transceiver (up to 20 km), Tx:1330 nm, Rx:1270 nm)
				 DEM-436XT-BXU
				 10GBase-LR Single-Mode WDM SFP+ transceiver (up to 20 km), Tx:1270 nm, Rx:1330 nm
1For some models of USB modems.
2The manufacturer does not guarantee proper operation of the router with every modification of the firmware of USB modems.
Certificates
Order info
DSA-2308X Service Router with 8 Configurable Ports (6x10/100/1000Base-T, 2x10GBase-X SFP+) and 2 USB Ports
