DIS-100G-10P
Industrial Configurable Switch with 8x10/100/1000Base-T PoE Ports, 2x1000Base-X SFP Ports and DIP Switch
Description
The DIS-100G-10P Industrial Configurable Switch is equipped with 8 10/100/1000Base-T PoE ports, 2 1000Base-X SFP ports and DIP switch. This switch features a robust design, making it ideal for deployment in industrial and outdoor cabinet surveillance settings and capable of withstanding the harshest environments. In addition, the DIS-100G-10P is plug-and-play, allowing for effortless and swift deployment.
Durable, Reliable, and Efficient
The DIS-100G-10P switch is housed in a highly resistant IP30-rated metal casing to protect the switch from harsh environmental conditions. High electromagnetic susceptibility (EMS) protects the DIS-100G-10P from undesirable effects when operating in environments with strong electromagnetic interference. Meanwhile, the fanless design extends the life of the DIS-100G-10P while also enabling it to operate in a wide temperature range from -40 °C up to 75 °C. With DIN rail mounting capability, the DIS-100G-10P can fit seamlessly into your industrial equipment infrastructure. In addition, the DIS-100G-10P supports dual power input, which allows for a redundant power supply configuration to make sure the switch continues to operate in the event of a primary power supply failure.
DIP Switches for Several Operating Modes
The DIS-100G-10P has two DIP switches:
  • Alarm ON - for turning on/off the power alarm;
  • Extend - the data rate of 1 to 4 port is limited to 10 Mbps, whereas the maximum transmission distance of the port is increased to 250 meters.
Long-Reach PoE Connection
The DIS-100G-10P supports long-range PoE connection configurations, simplifying the issues of distance, power source, and cable deployment for your network systems. Extend connection distances with reduced power transmission loss. Utilize 250 m PoE cable connections at transmission speeds of 10 Mbps. Take advantage of D-Link’s GE PoE Extenders to power devices up to 650 m away, making the DIS-100G-10P switch the ideal choice for deploying PoE devices to your network, no matter your deployment’s location.
Green Ethernet Technology
The DIS-100G-10P features green technology; IEEE 802.3az Energy-Efficient Ethernet (EEE). Energy-Efficient Ethernet reduces the power consumption of the switch when network utilization is low, effectively lowering the cost of ownership during periods of inactivity.
General features
Hardware Version
• A1
Number of Ports
• 8 10/100/1000Base-T PoE ports
• 2 1000Base-X SFP ports
Alarm Relay
• 1 A at 24 V DC
Diagnostic LEDs
• PWR1
• PWR2
• ALM
• SFP1
• SFP2
• PoE Max
• Link/Act (per 10/100/1000Base-T port)
• PoE (per PoE port)
DIP Switch
• Alarm ON
• Extend Mode
Material
• IP30-rated metal casing
Installation
• DIN rail mountable
Port Functions
• IEEE 802.3 10Base-T
• IEEE 802.3u 100Base-TX
• IEEE 802.3ab 1000Base-T
• IEEE 802.3z 1000Base-X
• IEEE 802.3x Flow Control
Media Interface Exchange
• Auto-MDI/MDIX adjustment for all twisted pair ports
Switching Capacity
• 20 Gbps
Transmission Method
• Store-and-forward
Maximum Forwarding Rate
• 14.88 Mpps
MAC Address Table Size
• 4K entries
Packet Buffer Memory
• 256 KB
Jumbo Frame
• 9,216 bytes
Advanced Features
• Power saving by link status
PoE Standards
• IEEE 802.3at
• IEEE 802.3af
PoE Ports
• Ports 1 to 8
PoE Budget
• 240 W
• Up to 30 W per port
Physical Parameters
Power Input
• 44-57 V DC terminal block dual input
Power Consumption
• Maximum: 244.86 W (PoE on) / 4.86 W (PoE off)
• Standby: 0.54 W
Heat Dissipation
• 245.36 W (837.704 BTU/hr)
MTBF
• 421,942 hours
Acoustic
• 0 dB
Ventilation
• Fanless
Surge Protection
• Built-in 6 KV surge protection on copper ports
Dimensions
• 99 x 40 x 130.6 mm
Weight
• 0.44 kg
Temperature
• Operating: -40° to 75°C
• Storage: -40° to 85°C
Humidity
• Operating: 5% to 95% non-condensing
• Storage: 5% to 95% non-condensing
Certificates
• RoHS
Safety
• cUL
• CB
• CE
• BSMI
EMI
• CE Class A
• VCCI Class A
• FCC Class A
• IC
• BSMI
• RCM
Certificates
Order info
DIS-100G-10P Industrial Configurable Switch with 8x10/100/1000Base-T PoE Ports, 2x1000Base-X SFP Ports and DIP Switch
Pictures
DIS-100G-10P/A1
Front view
View from the right
Left side view
Back view
Bottom view
Downloads
Support Resources
