DAP-2622
Wireless AC1200 Wave 2 Dual-Band PoE Access Point
Description
The D-Link DAP-2622 AC1200 Wave 2 Wireless Access Point is designed for small to medium businesses or enterprises, providing unparalleled bandwidth and flexibility for administrators looking to deploy a Wi-Fi network with manageable dual-band wireless LAN options and utilizing the speed of Wireless AC Wave 2.
Greater Speed and Connectivity
The DAP-2622 delivers reliable, high-speed wireless performance with signal rates of up to 867 Mbps over the 5 GHz band, and 300 Mbps over the 2.4 GHz band. This, coupled with support for the Wi-Fi Multimedia™ (WMM) Quality of Service (QoS) feature, makes it an ideal access point for audio, video, and voice applications. When enabled, QoS allows the DAP-2622 to automatically prioritize network traffic according to the level of interactive streaming, such as HD movies or VoIP.
MU-MIMO Technology
The DAP-2622 supports MU-MIMO (Multi-User Multiple Input Multiple Output), which enables the device to simultaneously communicate with multiple clients using multiple antennas. This allows the access point to utilize the spectrum more efficiently and significantly increase the network capacity.
Multiple Operating Modes
The DAP-2622 supports four operating modes (AP Mode, WDS Mode, WDS with AP, and Wireless Client) for performance optimization
based on your network’s needs.
Reliable Security and Management Tools
The DAP-2622 supports WPA/WPA2-Personal/Enterprise data encryption. In addition, this access point supports MAC address access control and the Disable SSID Broadcast function to limit unauthorized access to the internal network. Network administrators have multiple options for managing the DAP-2622, including Web (HTTP), Secure Socket Layer (SSL), Secure Shell (SSH), and Telnet.
Power over Ethernet (PoE)
The DAP-2622 is powered by 802.3at PoE Switch through Ethernet cable. This facility allows you to install the access point in those places where electrical outlets are not available (the DAP-2622 is wall mounted). Also the DAP-2622 can provide power using PoE through the 802.3af PoE LAN port (PoE OUT + DATA) for PoE-capable devices and connecting them to the network (PoE Out port supports a maximum of 12 W).
General features
Interfaces
• 802.11b/g/n 2.4 GHz wireless
• 802.11a/n/ac Wave 2 5 GHz wireless
• 10/100/1000Base-T LAN PoE 802.3af port (PoE OUT + DATA)
• 10/100/1000Base-T LAN PoE 802.3at port (LAN (PoE))
• 10/100/1000Base-T LAN port (DATA)
LEDs
• Power/Status
  - Solid green - Device operational
  - Flashind red - Device booting up/Device malfunctioned
  - Solid red - Device boot up has failed
Buttons
• Factory reset button
Antenna
• Two internal antennas
Power Method
•  Through Ethernet (PoE) 802.3at
Network Management
• Web interface (HTTP)
• Secure Telnet (SSH)
• Secure Socket Layer (SSL)
• Telnet
• Traffic control
• D-Link Nuclias Connect
Wireless Security
• WPA/WPA2-Personal/Enterprise
• AES and TKIP
• 64/128-bit WEP encryption
• SSID broadcast disable
• MAC address access control
• Internal RADIUS server
Supported Features
• Quality of Service (QoS)
  - WMM
• Transmit power setting
Operating Modes
• Access Point
• Client
• WDS with AP
• WDS
Wireless Standards
• IEEE 802.11a/b/g//n/ac
Wireless Frequency Range
• 802.11b/g/n: 2.4 GHz to 2.4835 GHz
• 802.11a/n/ac: 5.15 GHz to 5.825 GHz
Wireless speed
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit/s
• IEEE 802.11b: 1, 2, 5.5 and 11 Mbit/s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit/s
• IEEE 802.11n: 6.5 ~ 300 Mbit/s
• IEEE 802.11ac: 6.5 ~ 867 Mbit/s
Transmitter Output Power
• IEEE 802.11a:
  18 dBm at 6~24 Mbit/s
  17 dBm at 36~48 Mbit/s
  16 dBm at 54 Mbit/s
• IEEE 802.11b:
  18 dBm at 1, 2, 5.5 and 11 Mbit/s
• IEEE 802.11g:
  18 dBm at 6~18 Mbit/s
  17 dBm at 24~36 Mbit/s
  16 dBm at 48~54 Mbit/s
• IEEE 802.11n:
  2.4 GHz/HT-20:
  17 dBm at MCS0-MCS3
  16 dBm at MCS4-MCS5
  15 dBm at MCS6-MCS7
  2.4 GHz/HT-40:
  16 dBm at MCS0-MCS3
  15 dBm at MCS4-MCS5
  14 dBm at MCS6-MCS7
  5 GHz/HT-20:
  18 dBm at MCS0-MCS3
  17 dBm at MCS4-MCS5
  16 dBm at MCS6-MCS7
  5 GHz/HT-40:
  17 dBm at MCS0-MCS3
  16 dBm at MCS4-MCS5
  15 dBm at MCS6-MCS7
• IEEE 802.11ac:
  VHT20:
  18 dBm at MCS0-MCS3
  17 dBm at MCS4-MCS6
  16 dBm at MCS7-MCS8
  14 dBm at MCS9
  VHT40:
  17 dBm at MCS0-MCS3
  16 dBm at MCS4-MCS6
  15 dBm at MCS7-MCS8
  14 dBm at MCS9
  VHT80:
  16 dBm at MCS0-MCS4
  15 dBm at MCS5-MCS7
  14 dBm at MCS8-MCS9
Receiver Sensitivity
• IEEE 802.11a:
  -85 dBm at 6 Mbit/s
  -82 dBm at 9 Mbit/s
  -79 dBm at 12 Mbit/s
  -77 dBm at 18 Mbit/s
  -76 dBm at 24 Mbit/s
  -75 dBm at 36 Mbit/s
  -73 dBm at 48 Mbit/s
  -72 dBm at 54 Mbit/s
• IEEE 802.11b:
  -88 dBm at 2 Mbit/s
  -84 dBm at 11 Mbit/s
• IEEE 802.11g:
  -86 dBm at 6 Mbit/s
  -83 dBm at 9 Mbit/s
  -80 dBm at 12 Mbit/s
  -78 dBm at 18 Mbit/s
  -77 dBm at 24 Mbit/s
  -76 dBm at 36 Mbit/s
  -74 dBm at 48 Mbit/s
  -73 dBm at 54 Mbit/s
• IEEE 802.11n:
  2.4 GHz/HT-20:
  -84 dBm at MCS0
  -83 dBm at MCS1
  -82 dBm at MCS2
  -78 dBm at MCS3
  -76 dBm at MCS4
  -72 dBm at MCS5
  -71 dBm at MCS6
  -70 dBm at MCS7
  2.4 GHz/HT-40:
  -82 dBm at MCS0
  -80 dBm at MCS1
  -79 dBm at MCS2
  -75 dBm at MCS3
  -73 dBm at MCS4
  -69 dBm at MCS5
  -68 dBm at MCS6
  -67 dBm at MCS7
  5 GHz/HT-20:
  -83 dBm at MCS0
  -82 dBm at MCS1
  -81 dBm at MCS2
  -77 dBm at MCS3
  -75 dBm at MCS4
  -71 dBm at MCS5
  -70 dBm at MCS6
  -69 dBm at MCS7
  5 GHz/HT-40:
  -81 dBm at MCS0
  -79 dBm at MCS1
  -78 dBm at MCS2
  -74 dBm at MCS3
  -72 dBm at MCS4
  -68 dBm at MCS5
  -67 dBm at MCS6
  -66 dBm at MCS7
• IEEE 802.11ac:
  VHT20:
  -83 dBm at MCS0
  -82 dBm at MCS1
  -81 dBm at MCS2
  -77 dBm at MCS3
  -75 dBm at MCS4
  -71 dBm at MCS5
  -70 dBm at MCS6
  -69 dBm at MCS7
  -64 dBm at MCS8
  -62 dBm at MCS9
  VHT40:
  -81 dBm at MCS0
  -79 dBm at MCS1
  -78 dBm at MCS2
  -74 dBm at MCS3
  -72 dBm at MCS4
  -68 dBm at MCS5
  -67 dBm at MCS6
  -66 dBm at MCS7
  -61 dBm at MCS8
  -59 dBm at MCS9
  VHT80:
  -79 dBm at MCS0
  -76 dBm at MCS1
  -75 dBm at MCS2
  -71 dBm at MCS3
  -69 dBm at MCS4
  -65 dBm at MCS5
  -64 dBm at MCS6
  -63 dBm at MCS7
  -58 dBm at MCS8
  -56 dBm at MCS9
Physical Parameters
Dimensions (L x W x H)
• 154.1 x 95 x 27.4 mm
Weight
• 216 g (without mounting base)
Max Power Consumption
• 12 W
Temperature
• Operating: 0° to 40°C
• Storage: -20° to 65°C
Humidity
• Operating: 10% to 90% (Non-condensing)
• Storage: 5% to 95% (Non-condensing)
Certifications
• CE
• FCC
Certificates
Order info
DAP-2622 Wireless AC1200 Wave 2 Dual-Band PoE Access Point
Pictures
DAP-2622/A
Front view
View from the right
Left side view
Back view
Bottom view
Downloads
Support Resources
