DEM-410XProject
1-Port 10-Gigabit XFP Module for DGS-3600 Series
Where to buy
Description
The D-Link XFP module provides high-speed 10-Gigabit connection on the secure fiber cable. It provides a single or dual XFP slots and can be slid into an open slot of a D-Link Gigabit switch. A number of 10Gigabit transceivers are available for selection for installation in the XFP slot. Data transfer is operated in the full-duplex mode at 20 Gigabits per second on either the multi-mode or single-mode fiber network cable, depending on the type of transceiver being installed.
The D-Link XFP module allows flexible deployment of 10-Gigabit connection and is ideal for bandwidth-hungry applications that can meet greater cable distances and low signal interference requirements in the Local Area Network, Wide Area Network and Metropolitan Area Network.
General features
Number of XFP Slots
1 XFP slot
Data Rate & Operation
20 Gigabit per second (full-duplex)
Switch Compatibility
DGS-3400 series switches
Transceiver Support
- DEM-421XT (up to 300 m on multi-mode fiber cable)
- DEM-422XT (up to 10 km on single-mode fiber cable)
- DEM-423XT (up to 40 km on single-mode fiber cable)
Certificates
Order info
DEM-410X  Module
- 1 XFP Slot
- Compatible With DGS-3400 Series Gigabit Switches
Pictures
DEM-410X
Front view
Downloads
Support Resources
