DIS-100G-10
Industrial Switch with 8x10/100/1000Base-T Ports and 2x1000Base-X SFP Ports
Description
The DIS-100G-10 Gigabit Industrial Unmanaged Switch features a robust design, making it ideal for deployment in industrial and outdoor cabinet surveillance settings and capable of withstanding the harshest environments. In addition, the DIS-100G-10 is plug-and-play, allowing for effortless and swift deployment.
Durable, Reliable, and Efficient
The DIS-100G-10 switch is housed in a highly resistant IP40-rated metal casing to protect the switch from harsh environmental conditions. High electromagnetic susceptibility (EMS) protects it from undesirable effects when operating in environments with strong electromagnetic interference. Meanwhile, the fanless design extends the life of the DIS-100G-10 while also enabling it to operate in a wide temperature range from -40 °C up to 75 °C. With DIN rail mounting capability, the DIS-100G-10 can fit seamlessly into your industrial equipment infrastructure. In addition, the DIS-100G-10 supports dual power input, which allows for a redundant power supply configuration to make sure the switch continues to operate in the event of a primary power supply failure.
Green Ethernet Technology
The DIS-100G-10 features green technology; IEEE 802.3az Energy-Efficient Ethernet (EEE). Energy-Efficient Ethernet reduces the power consumption of the switch when network utilization is low, effectively lowering the cost of ownership during periods of inactivity.
General features
Hardware Version
• A1
Number of Ports
• 8 10/100/1000Base-T ports
• 2 1000Base-X SFP ports
Diagnostic LEDs
• Power
• Link/Act (per port)
Material
• IP40-rated metal casing
Installation
• DIN rail mountable
Port Functions
• IEEE 802.3 10Base-T
• IEEE 802.3u 100Base-TX
• IEEE 802.3ab 1000Base-T
• IEEE 802.3z 1000Base-X
Media Interface Exchange
• Auto-MDI/MDIX adjustment for all twisted pair ports
Switching Capacity
• 20 Gbps
Transmission Method
• Store-and-forward
Maximum Forwarding Rate
• 14.88 Mpps
MAC Address Table Size
• 8K entries
Packet Buffer Memory
• 4.1 MB
Jumbo Frame
• 9 KB
Flash Memory
• 16 MB
DRAM Size
• 128 MB
Advanced Features
• Power saving by link status
Physical Parameters
Power Input
• 12-55 V DC / 0.6 A terminal block dual input
• External power adapter* (12-55 V DC / 2.5 A output)
Power Consumption
• Maximum: 6.99 W
• Standby: 2.85 W
Heat Dissipation
• 6.3 W (21.5 BTU/hr)
MTBF
• > 200,000 hours
Acoustic
• 0 dB
Ventilation
• Fanless
Surge Protection
• Built-in 6 KV surge protection on copper ports
Dimensions
• 108 x 44 x 138 mm
Weight
• 0.62 kg
Temperature
• Operating: -40° to 75°C
• Storage: -40° to 85°C
Humidity
• Operating: 5% to 95% non-condensing
• Storage: 5% to 95% non-condensing
Certificates
• RoHS
Safety
• cUL
• CB
• CE
• BSMI
EMI
• CE Class A
• VCCI Class A
• FCC Class A
• IC
• BSMI
• RCM
* Not included.
Certificates
Order info
DIS-100G-10 Industrial Switch with 8x10/100/1000Base-T Ports and 2x1000Base-X SFP Ports
Pictures
DIS-100G-10/A1
Front view
View from the right
Left side view
Back view
Top view
Downloads
Support Resources
