DEM-330T
1000Base-BX-D Single-Mode WDM SFP transceiver (up to 3/10 km), Tx:1550 nm, Rx:1310 nm
Description
General features
General features
Standard
• IEEE 802.3z 1000Base-BX-D
Wavelength
• Tx: 1550 nm, Rx: 1310 nm
Data Rate
• 1.25 Gbps
Connector
• Simplex SC (DEM-330T/3KM)
• Simplex LC (DEM-330T/10KM)
Fiber Type
• 9/125 um Single-mode Fiber
Maximum Fiber Cable Length
• 3 km (DEM-330T/3KM)
• 10 km (DEM-330T/10KM)
Transmit Power Range
• -8 to -15 dBm (DEM-330T/3KM)
• -3 to -9 dBm (DEM-330T/10KM)
Receive Power Range
• -3 to -20 dBm (DEM-330T/3KM)
• -3 to -21 dBm (DEM-330T/10KM)
Sensitivity
• -20 dBm (DEM-330T/3KM)
• -21 dBm (DEM-330T/10KM)
Supported Features
• Hot swap
• MSA compliant
• RoHS compliant
Physical Parameters
Power Support
• 3.3 V
Supply Current
• 220 mA
Temperature
• Operating: 0° to 70°C
• Storage: -40° to 85°C
Humidity
• Operating: 0% to 85%
• Storage: 0% to 85%
Dimensions
• 63.8 mm x 13.7 mm x 8.5 mm (DEM-330T/3KM)
• 55.4 mm x 13.7 mm x 8.5 mm (DEM-330T/10KM)
Certificates
Order info
DEM-330T/10KM
1000Base-BX-D Single-Mode WDM SFP transceiver (up to 10 km), Tx:1550 nm, Rx:1310 nm
DEM-330T/3KM
1000Base-BX-D Single-Mode WDM SFP transceiver (up to 3 km), Tx:1550 nm, Rx:1310 nm
