DGS-1016DEOL
16-Port Unmanaged Gigabit Switch
Description
The D-Link DGS-1016D switch offers an economical way for SOHO and Small-to-Medium Businesses (SMB) to take advantage of Gigabit Ethernet speeds, while reducing energy consumption and minimizing noise output.
Gigabit Connectivity
The DGS-1016D switch brings the speed of Gigabit Ethernet to all ports for a truly high-speed network. If your network has a mix of legacy and modern connection interfaces, each port allows for standard Ethernet, Fast Ethernet, or Gigabit Ethernet connections. With this switch, the latest technology available on every computer and device connected to your network.
Improved Network Efficiency
The DGS-1016D switch incorporates several advanced features to help simplify and improve network management and efficiency. Flow Control throttles connections to ensure reliability during heavy usage periods by reducing packet loss and wasteful data retransmission. The switch also offers auto MDI/MDIX crossover for all ports as well as supporting up to 10,000 bytes jumbo frames.
Innovative Design
The DGS-1016D features a durable, compact metal case alongside a fanless design allowing for improved heat dissipation while maintaining silent operation. The switch is a rack-mountable and ideal for any business with demanding requirements and a small budget.
Green Technology
The DGS-1016D helps you conserve energy automatically through several methods. Link status detection automatically powers down ports that have no link, allowing the switches to save substantial amounts of power by cutting power usage for unused ports or any ports connected to computers that have been shut down.
Meanwhile, Energy-Efficient Ethernet (EEE) conserves energy by dynamically reducing power consumption when data activity is low. These environmentally friendly switches are also RoHS compliant, use recyclable packaging, and minimize the use of harmful substances. These green features combined, provide more energy savings and a longer product life, without sacrificing operational performance or functionality.
General features
Device Interfaces
• 16 10/100/1000 Gigabit ports
LEDs
• Power
• Link/Activity/Speed (per port)
DIP Switches
• Energy-Efficient Ethernet (EEE)
• Flow Control
• Port Isolation and Storm Control
Standards
• IEEE 802.3 10BASE-T
• IEEE 802.3u 100BASE-TX
• IEEE 802.3ab 000BASE-T
• IEEE 802.1p QoS
• IEEE 802.3x Flow Control supported for Full Duplex
• Auto-Negotiation
• IEEE 802.3az Energy-Efficiency Ethernet (EEE)
Data Transfer Rates
• Ethernet: 10 Mbps/20 Mbps (Half-duplex/Full-duplex)
• Fast Ethernet: 100 Mbps/200 Mbps (Half-duplex/Full-duplex)
• Gigabit Ethernet: 2000 Mbps (Full-duplex)
Network Cables
• Ethernet: 2-pair UTP Cat.3/4/5/5e, Unshield Twisted Pair (UTP )Cable
• Fast Ethernet: 2-pair UTP Cat.5/5e, Unshield Twisted Pair (UTP )Cable
• Gigabit Ethernet: 4-pair UTP Cat.5/ 5e, Unshield Twisted Pair (UTP )Cable
D-Link Green Features
• Power saving by link status and cable length
Security
• Storm Control
QoS (Quality of Service)
• 802.1p priority
• 8 queues
Cable Diagnostics
• Indicated through port LEDs
Protocol
• CSMA/CD
Packet Buffer RAM
• 512 KBytes per device
Filtering Address Table
• 8K MAC address per device
MAC Address Learning
• Self-learning, auto-aging
Forwarding Mode
• Store-and-forward
Switching Capacity
• 32 Gbps
Max. Forwarding Rate
• 23.8 Mbps
Pshysical Parameters
AC inputs
• Internal universal power supply: 100~240VAC; 50-60Hz, 0.2A Max.
Maximum Power Consumption
• 10.3 watts
Standby Power Consumption
• 4.85 watts
Maximum Heat Dissipation
• 35.14 BTU/hr
MTBF
• 740,073 hours
Acoustic Value
• 0dB(A) Fanless
Dimensions
• 280 x 126 x 44 mm
Weight
• 0.94 kg
Temperature
• Operating: 0° to 40°C
• Storage: -10° to 70°C
Humidity
• Operating: 0% to 95% (Non-condensing)
• Storage: 0% to 95%
Emission Certifications (EMI)
• ICES-003 Class A
• FCC Class A
• RCM Class A
• BSMI Class A
• CE Class A
• VCCI Class A
• CCC
Safety
• cUL/UL
• CE LVD
• CB
• CCC
• BSMI
• BSMI
Certificates
Order info
DGS-1016D/I1  16-Port Unmanaged Gigabit Switch
Pictures
DGS-1016D/I
Front view
View from the right
Back view
Downloads
Support Resources
