DGS-6600-PWRDCProject
Redundant 300 W DC Power Supply for DGS-6600 Series
Where to buy
Description
Redundant AC and DC power supplies can not be used together. Redundant DC power supplies don't support PoE functionality, i.e. PoE modules will work as usual modules.
General features
Output Power
• 300 W
Input Voltage Range
• 36~72 VAC
Max. Input Current
• 10 A @ 48 VAC
Max. Inrush Current
• 30 A
Efficiency
• 80%
Physical Parameters
Dimensions (L x W x H)
• 279.4 x 81.3 x 39.9 mm
MTBF
• 300 000 hours
Temperature
• Operating: 0 to 50 C
• Storage: -40 to 70 C
Humidity
• Operating: 10 to 90% non-condensing
• Storage: 5 to 90% non-condensing
Certificates
Order info
DGS-6600-PWRDC/A1A   Redundant 300 W DC Power Supply for DGS-6600 Series
Pictures
DGS-6600-PWRDC/A
Front view
Back view
Downloads
Support Resources
