DES-1008AEOL EOS
Description
Auto-sensing 10/100 ports
The DES-1008A uses auto-sensing 10/100 Mbps ports, allowing a small workgroup to flexibly connect to Ethernet and Fast Ethernet devices to create an integrated network. These ports detect the network speed and auto-negotiate between 10BASE-T and 100BASE-TX, as well as between full and half-duplex, allowing you to get the maximum speed possible for each device connected to your network.
Auto MDI/MDIX CrossOver
All ports support automatic MDI/MDIX crossover, eliminating the need for crossover cables or uplink ports. Each port can be plugged directly to a server, hub, router, or switch using regular straight-through twisted-pair Ethernet cables.
Flow Control for Secure Transmission
802.3x flow control on each port minimizes dropped packets when the port’s receiving buffer is full. This gives you a more reliable connection for all of your connected devices.
General features
Key Features
Inexpensive Fast Ethernet solution for
Home/SOHO
+ 8 10/100 Mbps Fast Ethernet ports
+ Auto MDI/MDIX crossover for all ports
+ Store-and-forward switching scheme
+ Full/half-duplex for Ethernet/Fast
Ethernet speeds
+ IEEE 802.3x Flow Control
+ Plug-and-play installation
+ RoHS compliant
SWITCHING FABRIC
1.6 Gbps switching fabric
Standards
+ IEEE 802.3 10BASE-T Ethernet (twisted-pair copper)
+ IEEE 802.3u 100BASE-TX Fast Ethernet (twisted-pair copper)
+ ANSI/IEEE 802.3 NWay auto-negotiation
+ IEEE 802.3x flow control
Protocol
CSMA/CD
Data Transfer Rates
Ethernet:
+ 10 Mbps (half duplex)
+ 20 Mbps (full duplex)
Fast Ethernet:
+ 100 Mbps (half duplex)
+ 200 Mbps (full duplex)
Topology
Star
Media Interfa ce Exchange
Auto MDI/MDIX adjustment for all ports
Network Cables
10BASE-T:
+ UTP CAT 3/4/5/5e (100 m max.)
+ EIA/TIA-586 100-ohm STP (100 m max.)
100BASE-TX:
+ UTP CAT 5/5e (100 m max.)
+ EIA/TIA-568 100-ohm STP (100 m max.)
LED Indicators
+ Per port: Link/Activity
+ Per device: Power
Transmission Method
Store-and-forward
MAC Address Table
1K entries per device
MAC Address Learning
Automatic update
Packet Filtering/Forwarding Rates
+ Ethernet: 14,880 pps per port
+ Fast Ethernet: 148,800 pps per port
RAM Buffer
57 KBytes per device
Certificates
Order info
DES-1008A 8-port 10/100 switch
