Kirjeldus
SHARE USB PRINTERS AND MULTIFUNCTION EQUIPMENT
The DPR-2000 Multi-port Wireless G Print Server lets you share up to four USB printers among your offce workers across a wired or wireless network. With four USB 2.0 ports, this print server can create up to four printer connections from any workstation, so users can send documents from their PC to the networked printers to print. In addition, it also supports the scan and fax functions of multifunction equipment, so users can send faxes directly from their computers, or scan images without having to attach scanners to their PC. If you plan to cluster together multiple printers or multifunction equipment at a central place, this print server can reduce costs and simplify installation.
HIGH PERFORMANCE AND EASE OF USE
Equipped with a powerful CPU and a large buffer RAM, the DPR-2000 performs operations quickly and effciently. All devices attached to it can print, scan, and fax at the same time, giving you the performance of four separate single-port print servers at a fraction of the cost. For wireless connections, an integrated Wi-Fi Protected Setup (WPS) function allows you to set up a secure connection from this print server to your wireless router or access point, and then on to all wireless users, in a matter of minutes.
ACCESS SECURITY AND MULTIPLE OS SUPPORT
The DPR-2000 provides the necessary security by allowing the administrator to confgure user access right to the network printers and equipment. It supports a wide range of network operating systems, including Windows, Mac OS, Linux and Unix. Operation is completely transparent, so users can enjoy hassle-free performance, fexibility and compatibility.
REMOTE PRINTING SUPPORT
The DPR-2000 supports the Internet Printing Protocol (IPP), enabling remote users to output fles to their offce printers even when they are away from the offce. This print server also provides network administrators with critical information about the networked printers so they can monitor the printers’ operation in a timely manner.
Põhiomadused
INTERFACE STANDARDS
+ USB 2.0
+ IEEE 802.3, IEEE 802.3u Ethernet
+ IEEE 802.11b/g wireless LAN
DEVICE INTERFACES
+ 4 USB 2.0 ports
+ 802.11b/g wireless LAN
+ 1 10/100BASE-TX Ethernet LAN port
WIRELESS FREQUENCY RANGE
2.4GHz to 2.5GHz
WIRELESS ANTENNA TYPE
PIFA antenna
WIRELESS SECURITY
+ 64/128 bit WEP
+ WPA/WPA2 (Wi-Fi Protected Access)
+ WPS support (Wi-Fi Protected Setup)
DEVICE MANAGEMENT
+ Web-based management through Internet Explorer v6 or later; or other Java-enabled browsers
+ Print Server setup and management program running under Windows
DIAGNOSTIC LEDs
+ Power
+ Ethernet
+ USB (4 LEDs)
+ Wireless
Sertifikaadid
Sidustooted
DPR-2000 Multi-port wireless G multifunction print server
