![](/up/prod/600/DVG-2032S_16MO_C.jpg)
DVG-2032S/16MOProjektideks
16 FXS Port Module for DVG-2032S/16CO Gateway
Kirjeldus
The DVG-2032S/16MO module with 16 FXS ports is designed for installation into the DVG-2032S/16CO VoIP gateway. With the installed DVG-2032S/16MO module the DVG-2032S/16CO gateway allows you to double the amount of available FXS ports (from 16 to 32) with ease. This allows you to increase the system capacity and save customer's investments as the amount of users grows.
IMPORTANT! The DVG-2032S/16MO module of C1 hardware version is compatible only with the DVG-2032S/16CO gateway of C1 hardware version. The module of C1 hardware version is not compatible with devices of A1 and B1 hardware versions.
Põhiomadused
Device Interfaces
• 16 FXS ports in 1 RJ-21 connector
Physical & Environmental
Dimensions
• 155 x 204 x 30 mm
Weight
• 330 g
Operating Temperature
• 0 to 45 C
Storage Temperature
• -25 to 75 C
Humidity
• Up to 95% non-condensing
Sertifikaadid
Sidustooted
DVG-2032S/16MO/С 16 FXS Port Module for DVG-2032S/16CO Gateway
