![](/up/prod/600/DCS-6510.jpg)
DCS-6510
Kirjeldus
Round-the-clock Surveillance
The D-link DCS-6510 is a fixed dome day and night network camera, ideal for small-to-medium business applications and remote monitoring over the internet. The camera employs a superior CMOS sensor with low lux sensitivity to deliver a truly superior image quality under varied lighting conditions. The DCS-6510 is equipped with a BNC video connector for an analog video signal, and Di/Do (digital input/digital output) connectors for external alarms and sensors.
High-quality video feeds
To maximize bandwidth efficiency and improve image quality, the DCS-6510 provides real-time video compression using the MJPEG, MPEG-4 and H.264 codecs. Furthermore, the DCS-6510 supports 3 separate profiles for simultaneous video streaming and is capable of recording in MJPEG, MPEG-4 and H.264 compression at VGA resolution. This kind of versatility enables a wide variety of security applications. For example, keep an eye on your home during lunch through a 3GPP enabled mobile device, or fine-tune your security system in real-time over the local network. You may also remotely manage a directory of recorded video files on a network attached storage (NAS) device or SD card.
Flexible installation
Power over ethernet (PoE) connectivity allows for discreet installation in virtually any indoor location. This camera’s built-in 802.3af compliant Poe module eases the installation process by reducing the need to drill holes or lay additional cabling. In addition, the 10/100BASE-TX ethernet port seamlessly connects to local network or to the internet via a gateway router. This camera can be accessed and viewed from any network place as a device on the network.
Removable IR cut filter for continuous monitoring
The ICR filter can be manually applied via the web, or set to automatically adjust based on lightning conditions. This feature allows the camera to capture crisp color images during the daytime, and grayscale images in low-light conditions.
Centralized Management with D-ViewCam™
The included D-link D-ViewCam™ is sophisticated video management software which enables you to manage up to 32 network cameras, set e-mail alert notifications, create recording schedules, and trigger motion detection to record directly to your hard drive. D-ViewCam™ also allows you to upload a floor plan of your business, and create a realistic layout according to the locations of your cameras, further simplifying the management process.
Põhiomadused
Kaamera näitajad:
- ¼ CMOS sensor
- Eemaldatav IR-cut filter: Auto/Schedule/Manual
- AGC, AWB, AES
- BLC: Backlight compensation
- Sisseehitatud IR LED (– 20 meetrit)
- DC Iris Varifocal 3.7 – 12 mm, F 1.4 – 2.8
Vaatenurk:
- Vertikaalne: 56.9o – 17.1o
- Horisontaalne: 76.9o – 22.7o
- Diagonaal: 97.6o – 28.4o
IR LED:
- Kuni 20 meetri kaugusele, 12 LED-i ja valgussensoriga
Miinimumvalgustus:
- Värviline: 0.2 lux (F 1.4)
- Must-valge: 0.02 lux (F 1.4) ilma IR LED-ta
- Must-valge: 0 lux koos IR LED-ga
3-telje nurk:
- Vertikaalne: 120o
- Horisontaalne: 340o
- Pööraminurk: 300o
Süsteeminõuded:
- Operatsioonisüsteem: Windows XP, Vista, 7
- Brauser: Internet Explorer 6.0, Firefox 3.5, Safari 4 või uuem
Võrguprotokoll:
- IPv4, DHCP, ARP, DNS, TCP/IP, DDNS (D-Link), HTTP, HTTPS, UPnP Port Forwarding, Samba, SMTP, PPPoE, NTP (D-Link), FTP, RTP, RTSP, UDP, RTCP, ICMP, 3GPP
Integreeritud võrguliides:
- 10/100Base-TX Fast Ethernet
Videokoodekid:
- H.264
- MPEG4
- MJPEG
- JPEG – stop kaadrid
Resolutsioon:
- 640 x 480 kuni 30 kaadrit/s
- 320 x 240 kuni 30 kaadrit/s
- 160 x 120 kuni 30 kaadrit/s
Video omadused:
- Muudetav pildi suurus, kvaliteet ja bit rate
- Aja ja teksti sisestamine
- Privacy Mask: 3 tsooni
- Flip & Mirror
Audiokoodekid:
- G.726
- G.711
