DPN-R5402CEOL EOS
GPON ONT Wireless N Gigabit VoIP Gateway
Kirjeldus
The DPN-R5402C GPON ONT Wireless N Gigabit VoIP Gateway is a GPON (Gigabit-capable Passive Optical Network) ONT (Optical Network Terminal) device that provides a Gigabit connection and voice features for indoor environments such as small offices and multi-unit buildings. GPON technology delivers up to 2.4Gbps speeds over optical fiber wiring, and
enables next-generation simultaneous voice, video, and data services including high-speed Internet access, video streaming, and instant messaging. It has a built-in 802.11n wireless interface and four LAN ports, so family members can connect to the network wirelessly, or through network cables. The DPN-R5402C is an effective, easy-to-deploy technology that can be used as a high-performance Internet solution.
Leverage Your Fiber
The DPN-R5402C GPON ONT Wireless N Gigabit VoIP Gateway provides an optical line connection to a GPON OLT on the CO side, multiple VoIP phone connections, an 802.11n wireless interface, two USB ports, and four 10/100/1000Mbps Gigabit Ethernet connections to the end-user’s LAN side. It utilizes the extraordinary bandwidth of GPON technology, the next step in the delivery of new high-speed Internet applications to home and office users. Designed for deployment inside a home or an apartment building, this ONT device provides a reliable, long-reach last-mile connection by extending the public high-bandwidth network to people living and working in remote multi-unit, multi-tenant buildings.
Secure Wired and Wireless Connections
The DPN-R5402C provides an integrated 802.11n WLAN that supports wireless speeds of up to 300Mbps and four Gigabit Ethernet ports for connecting to non-wireless computers and other network devices via network cables. To secure your wireless connections, this gateway provides the latest WPA/WPA2 security encryption protocols to maximize security, while also allowing WEP-secured connections for maximum compatibility with legacy devices.
Põhiomadused
Device Interfaces
• IEEE 802.11n wireless LAN
• 2 FXS analog phone ports with an RJ-11
• 1 RF port (CATV)
• 1 optical port for SC GPON
• 4 ports with auto-negotiation 10/100/1000 Gigabit LAN with RJ-45
• WPS button
• Reset button (return to factory default state)
Wireless network and routing
• Compliant with IEEE 802.11b/802.11g/802.11n 2.4GHz
• 64/128-bit WEP encryption
• WPA and WPA2 security
• Wi-Fi protected setup (WPS)
• Internal customers WAN (DHCP, Static IP, PPPoE)
• Stateful packet inspection (SPI)
• Firewall
• Support for VPN Pass-through (IPSec, PPTP, L2TP)
• DHCP server, DNS Relay
• Filtering by IP/MAC addresses, DMZ
• IGMP, Multicast, VLAN
GPON specifications
• Compliance with ITU-T 984.x
• 1 SC connector, which can be connected to the fiber optic cable from the CO side
• Cable: single-mode fiber optic cable
• Support OMCI (ONT Management control interface) for remote control
• The maximum capacity for the upstream (ONT->OLT): 1.25 Gbit/s
• The maximum capacity for the downstream (OLT->ONT): 2.4 Gbit/s
• Output power of an optical receiver: 0.5 - 5 dBm
• Receiver sensitivity: -27 dBm
• The wavelength of the upstream (ONT->OLT): 1310 nm
• Wavelength for downstream (OLT->ONT): 1490 nm
• Wavelength for CATV: 1550 nm
• AES Encryption
• Supports IGMP v1/v2/v3 Snooping, 128 entries can be enabled/disabled
• UNI port configuration (speed, duplex mode, pause flow control, on/off, auto)
• The maximum length of frames: 1522 bytes
• MAC address learning
• Authentication ONT
VOIP function
• 2 FXS ports
• SIP (RFC3261)
• Echo cancellation
• Identification of tones and tone generation
• Call Transfer, Caller ID
• Fax relay
• Voice codecs: G.711 a-law, G.711 u-law, G.723.1 (optional), G.729a/b (optional)
Sertifikaadid
Sidustooted
