DAP-X3060Uus
Wi-Fi 6 Dual-Band PoE Access Point
Kirjeldus
The DAP-X3060 is designed to support small to medium business or enterprise environments by providing network administrators with secure and manageable dual-band wireless LAN options, and utilizing the cutting-edge speed of Wi-Fi 6.
DAP-X3060 can be managed by DNH-100 Nuclias Connect Controller. The Nuclias Connect solution provides for easier administration of wireless networks, including continuous monitoring of network activities, equipment configuration automation, performance parameters and network security control etc.
Wi-Fi 6 (802.11ax)
The DAP-X3060 delivers reliable, high-speed wireless performance using the latest 802.11ax* standards with maximum wireless signal rates of up to 574 Mbps over the 2.4 GHz band, and 2402 Mbps over the 5 GHz band*. This, coupled with support for the Wi-Fi Multimedia (WMM) Quality of Service (QoS) feature, makes it an ideal access point for audio, video, and voice applications. When enabled, QoS allows the DAP-X3060 to automatically prioritize network traffic according to the level of interactive streaming, such as HD movies or VoIP. The QoS feature can be adjusted through the DAP-X3060’s web GUI using a drop-down menu option to select customized priority rules.
Versatile Access Point Functionality
The DAP-X3060 allows network administrators to deploy a highly manageable and extremely robust simultaneous dual-band wireless network. The DAP-X3060 can provide optimal wireless coverage over either the 2.4 GHz or the 5 GHz band. For advanced installations, the DAP-X3060 has integrated 802.3at Power over Ethernet (PoE) support, allowing this device to be installed in areas where power outlets are not readily available.
Security
To help maintain a secure wireless network, the DAP-X3060 supports both Personal and Enterprise versions of WPA, WPA2 (802.11i) and WPA3, with support for a built-in internal RADIUS server allowing users to create their accounts within the device itself. This access point also includes MAC address filtering, wireless LAN segmentation, SSID broadcast disable, rogue AP detection, and wireless broadcast scheduling to further protect your wireless network. Additionally, the DAP-X3060 supports Network Access Protection (NAP), allowing network administrators to define multiple levels of network access based on individual client’s need.
Multiple Operation Modes
To maximize total return on investment, the DAP-X3060 can be configured to optimize network performance based on any one of its operation modes: Access Point and Wireless Distribution System (WDS) with Access Point. Access Point mode can be used to connect 802.11b/g/n devices to the DAP-X3060. Wireless Distribution System (WDS) with Access Point provides for wireless connection with other access points in order to enhance the network area or to link several network segments to make a single network with no need for cable laying.
Network Management
Network administrators have multiple options for managing the DAP-X3060 including web (HTTP), Secure Socket Layer (SSL, which provides for a secure connection to the Internet). The DAP-X3060 can be configured and managed through D-Link Nuclias Connect or D-View 8. With simultaneous dual-band functionality, PoE support, extensive manageability, versatile operation modes, and solid security enhancements, the DAP X3060 provides small to medium business and enterprise environments with a business-class solution for deploying a wireless network.
Põhiomadused
Hardware
Interfaces
• 802.11a/b/g/n/ac/ax (Wi-Fi 6)*
• 1x10/100/1000/2.5GBase-T LAN 802.3at PoE port
• 1xRJ45 Concole port
LEDs
• Power/Status
Buttons
• Reset
Antennas
• Two internal 3dBi for 2.4GHz
• Two internal 3dBi for 5GHz
Power Connector
• Power input connector (DC)
Wireless Module Parameters
Standards
• IEEE 802.11a/b/g/n/ac/ax*
Frequency range
• 2.4GHz: 2.4~2.483GHz
• 5GHz: 5.15~5.35GHz, 5.47~5.85GHz**
Wireless connection security
• WPA-Personal/Enterprise
• WPA2-Personal/Enterprise
• WPA3-Personal/Enterprise
• WEP 64/128-bit Encryption
• AES,TKIP
• Captive Portal
• SSID Broadcast Disable
• MAC-based Access Control
• Network Access Protection (NAP)
• Internal RADIUS Server
Data Rate
• 802.11a: 6, 9, 12, 18, 24, 36, 48, 54Mbps
• 802.11b: 1, 2, 5.5, 11Mbps
• 802.11g: 6, 9, 12, 18, 24, 36, 48, 54Mbps
• 802.11n: 6.5~300Mbps (MCS0–MCS15)
• 802.11ac: 6.5~866Mbps
• 802.11ax: 6.5~2402Mbps
Functionality
Network Management
• Web-based User Interface (HTTP)
• Secure Socket Layer (SSL)
• SNMP
• Traffic Control
• Nuclias Connect
• D-View 8
Operating Modes
• Access Point
• WDS
• WDS with AP
Functions
• Quality of Service (QoS)
• WMM
• Multi-SSID
• VLAN
• ARP Spoofing Prevention
• Bandwidth Optimization
• Wireless Intrusion Detection
• DHCP Server
• Band Steering
• Airtime Fairness
• Fast Roaming
Standards
• IEEE 802.3u
• IEEE 802.3ab
• IEEE 802.3at Power over Ethernet
• Flow Control 802.3x
Physical
Weight
• 612,4g w/o bracket
Dimensions
• 190 x 190 x 42.8mm
Operation Conditions
Power
• External power adapter: 12V DC/2.5A
• Supports 802.3at PoE PD on LAN 1 Port
Max. Power Consumption
• 14.07W (by power adapter)
• 16.7W (by PoE)
Temperature
• Operating: 0 to 40 °C
• Storage: -20 to 65 °C
Humidity
• Storage: 5% to 95% non-condensing
Package Contents
• DAP-X3060 Access Point
• Mounting Bracket
• Mounting Kit (Wall/Pole Mount)
• Quick Installation Guide
Certifications
• CE
• FCC
• IC
• RCM
• LVD
• EN 60601-1-2
*Maximum wireless signal rate derived from IEEE standard 802.11 and 802.11ax specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials, construction, and network overhead may lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
**Please note that operating frequency ranges vary depending on the regulations of individual countries and jurisdictions. The DAP-X3060 may not support the 5.25 - 5.35 GHz and 5.47 - 5.725 GHz frequency ranges in certain regions.
Sertifikaadid
Sidustooted
DAP-X3060: Wi-Fi 6 Dual-Band PoE Access Point
Compatible Equipment
DNH-100: Nuclias Connect Controller
