DAP-3760Projektideks
Kirjeldus
A wireless backhaul installation can provide network access for remote offices and academic buildings areas that cannot be reached by cable. For instance, rural medical clinics can use the system for telemedicine applications, to exchange vital patient data with city hospitals and health care centers.
Põhiomadused
System
• CPU
• IXP425, 533MHz
Memory
• 16MB Flash
• 32MB SDRAM (modified to 64MB)
Power
• Power over Ethernet (PoE Injector Output 19,3 W)
Radio
• Module RF *
• FCC: XA-632AH
• CE: AG-623C
Operating frequency *
• FCC: 5,725 ~ 5,850 GHz
• CE: 5,470 ~ 5,600 GHz, 5.650 ~ 5.725 GHz
RF modulation
• 802.11a: OFDM (BPSK, QPSK, 16-QAm, 64-QAm)
Output power RF *
• 24dBm at Radio for FCC (Band 4)
• 30dBm EIRP for ETSI 301 893 (Band 3)
Sensitivity
• -90 dBm @ 6 Mbps / sec
• -73 dBm @ 54 Mbit / s
Certificates
• FCC Class B, CE, IC, C-Tick, NCC
Operation / Software
• Operating Modes
• Bridge
Security
• WEP64/128/152, WPA-PSK/WPA2-PSK, TKIP, AES
Bandwidth Management
• 20MGts/40MGts
Super A / G
• Technology Fast Frames, Bursting, Compression
Intel TDMA
• Data transmission over long distances
Distance in meters
• Auto ACK-Time Adjustment
Statistics
• Wireless LAN and Ethernet
Link Test
• Checking the Wireless Connection
Configuring and Managing
• Management of Web-based (Secure SSL)
• Command line interface (SSH or RS-232 (9600))
• Utility on Windows
• SNMPv2
Software Update
• Management through Web / Windows
Physical parameters / Interfaces
• Ethernet
• 10/100 BaseT x 1 supports auto-negotiation, auto-negotiation
RS-232 (COM)
• RS-232 (UART) in RJ-45 Form Factor (for debugging)
Audible alarm
• Time Signal
Reset Pin
• COM Port (2 Pin)
Type of antenna
• Internal directional antenna with high gain
Gain
• 23dBi
Frequency range
• 5400 ~ 5850 MHz
HPBW (Horizontal)
• 10 °
HPBW (Vertical)
• 10 °
