DKVM-4K
4-Port PS/2 KVM Switch
Kirjeldus
The D-Link DKVM-4K 4-port PS/2 KVM switch allows you to manage up to four computers with one monitor, one keyboard and one mouse. The DKVM-4K requires no driver installation and no external power adapter connection. This KVM switch supports hot-plugging - you don't need to turn your computers off before installing the device. The DKVM-4K allows you to switch between computers quickly and easily using the buttons located on the top panel or keyboard hot keys. The DKVM-4K supports autoscan mode, which provides automatic switching to the next PC after the scan interval expires.
Põhiomadused
Ports for connecting KVM cables
• 4 VGA ports
Ports for connecting management console
• Monitor (local): VGA
• Keyboard (local): PS/2
• Mouse (local): PS/2
KVM cable connectors for connecting PC
• Video: 15-pin HDB connector (blue) (VGA)
• Keyboard: 6-pin mini-DIN connector (purple) (PS/2)
• Mouse: 6-pin mini-DIN connector (green) (PS/2)
LEDs
• 4 port LEDs for connected PCs
Buttons
• 4 port switching buttons
Enclosure
• Plastic
Connected PCs
• Up to 4
Autoscan mode
• Yes
Switching between PCs
• Switching buttons on the top panel
• Hot keys
Sound notification of switching
• Yes
Max. resolution
• 2048x1536
Physical Parameters
Dimensions (L x W x H)
• 100 x 65 x 25 mm
Weight
• 725 g
Environmental Conditions
Power Supply
• From PS/2 keyboard port on PC (no external power adapter required)
Temperature
• Operating: 0 to 50 °C
• Storage: -20 to 60 °C
Humidity
• 0% to 80% non-condensing
Compatible KVM cables*
• DKVM-CB/1.2M/B
• DKVM-CB/B
• DKVM-CB3/B
• DKVM-CB5/B
* NOTE! The KVM cables of hardware revision B are compatible only with the DKVM-4K KVM switch of hardware revision B.
Sertifikaadid
Sidustooted
DKVM-4K 4-Port PS/2 KVM Switch
