DGS-1008D
8-Port 10/100/1000Base-T Switch
Kirjeldus
The DGS-1008D 8-Port 10/100/1000Base-T switch is ideally suited for Small Office Home Office (SOHO), Small Medium Business (SMB), and Small Medium Enterprise (SME) environments. With a durable design, silent operation, and plug-and-play functionality, the DGS-1008D switch can be easily set up and be placed in almost any location where network connectivity is required. Support for IEEE 802.3az Energy-Efficient Ethernet (EEE), 802.1p Quality of Service (QoS), and Gigabit Ethernet connection speeds provide advanced features in a compact package.
Integrated Networking
The DGS-1008D switch uses auto-sensing 10/100/1000 Mbps ports, providing a small workgroup to flexibly connect Ethernet, Fast Ethernet, and Gigabit devices to create an integrated network. These ports detect the network speed and auto-negotiate between 10Base-T and 100Base-TX at full and half-duplex, and 1000Base-TX at full duplex, allowing you to get the maximum speed possible for each device connected to your network.
Simplified Installation
All of the ports on the DGS-1008D switch supports automatic MDI/MDIX crossover, eliminating the need for crossover cables. Each port can be plugged in directly to a server, hub, router, or switch using regular straight-through twisted-pair Ethernet cables. In addition, the DGS-1008D switch features multiple front, easy-to-access Ethernet ports with LED indicators per port to easily distinguish link status.
Green Technology
The DGS-1008D switch features green technology, such as IEEE 802.3az Energy-Efficient Ethernet (EEE), link status detection, and cable length detection. Energy-Efficient Ethernet reduces power consumption of the switch when network utilization is low, reducing the cost of ownership during periods of inactivity. Link status detection automatically powers down ports when there is no link detected, saving power when the connected device has been shut down or disconnected. Cable length detection automatically adjusts the power output of the port based on the length of the cable, reducing the power requirements of the switch to only what is necessary for the installation.
Traffic Management
The DGS-1008D switch includes traffic management features, such as IEEE 802.1p Quality of Service (QoS) and IEEE 802.3x Flow Control. The 802.1p QoS feature allows traffic to be classified in 8 priority levels, allowing different types of traffic to be prioritized, depending on their importance. Flow Control will temporarily stop data transmission when the switch’s input buffer is full, helping to minimize dropped packets and providing a more reliable connection for all of your connected devices.
Põhiomadused
Interfaces
• 8 x 10/100/1000Base-T ports
Diagnostic LEDs
• Power
• Link/Act (per port)
Enclosure
• Metal
Installation
• Desktop
• Wall mounting
Standards
• IEEE 802.3 10Base-T
• IEEE 802.3u 100Base-TX
• IEEE 802.3ab 1000Base-T
• IEEE 802.3x Flow Control
• Speed and duplex mode auto-negotiation for each port
• Auto-MDI/MDIX adjustment on all ports
Data Transfer Rates
• Ethernet:
• 10 Mbps (half duplex)
• 20 Mbps (full duplex)
• Fast Ethernet:
• 100 Mbps (half duplex)
• 200 Mbps (full duplex)
• Gigabit Ethernet
• 2000 Mbps (full duplex)
Additional Features
• Green Technology: power saving by link status detection and cable length detection
• IEEE 802.1p QoS: 8 queues
• IGMP Snooping
Switching Capacity
• 16 Gbps switching fabric
Transmission Method
• Store-and-forward
MAC Address Table
• 4K entries
Max. Packet Forwarding Rate
• 11.9 Mpps
MAC Address Learning
• Automatic update
Packet Buffer
• 192 KB
Jumbo Frame Size
• 9,216 bytes
Physical Parameters
Dimensions
• 139 x 85 x 22.4 mm
Weight
• 270 g
Power Input
• 5 V DC / 1 A external power adapter
Maximum Power Consumption
• 5.12 W
Standby Power Consumption
• 0.58 W
Heat Dissipation
• 5.12 W (17.47 BTU/hr)
MTBF
• 1,467,882 hours
Ventilation System
• Fanless
Temperature
• Operating: 0° to 40°C
• Storage: -10° to 70°C
Humidity
• Operating: 0 to 95% non-condensing
• Storage: 0% to 95% non-condensing
Certificates
• RoHS
Safety
• LVD
• BSMI
• CCC
• EN62368-1
EMI/EMC
• FCC Class B
• CE Class B
• ICES-003 Class B
• KCC
• RCM
• CCC
• BSMI
Sertifikaadid
Sidustooted
DGS-1008D/R1
