DMS-1250-10SPL
Multi-Gigabit Smart Switch with 8-port 2.5GBase-T PoE and 2-port SFP+
Kirjeldus
The DMS-1250 Series is D-Link’s Multi-Gigabit Ethernet smart switch. It provides multi-Gigabit connectivity, Power over Ethernet (PoE) capability, multiple management interfaces and advanced layer 2 features. The DMS-1250 Series provides a high-performace solution to expand your network and adapts to your business needs.
Multi-G Speeds for Wi-Fi 6 Networks
The DMS-1250 Series provide full 2.5 Gbps Ethernet ports to significantly upgrade network performance with increased bandwidth suitable for Wi-Fi 6 applications such as high-speed streaming environments. The DMS-1250-10SPL also provides additional 10 Gbps SFP+ ports for high-speed uplink connections and increase overall efficiency of data network.
PoE+ Availability on All Ports
The DMS-1250-10SPL switch has two IEEE 802.3bt PoE ports and six IEEE802.3at PoE ports with 120 W PoE budget. The 802.3bt ports can provide up to 60 W per port and allow connections for high-power devices. PoE models also support innovative PoE functions such as Perpetual PoE, which delivers uninterrupted power to connected powered devices (PD) even when the power sourcing equipment (PSE) switch is booting. The Fast PoE enables the switch to supply power to connected endpoint devices in a relatively short time without waiting for the operating system to boot up. Additionally, an extended Link Layer Discovery Protocol (LLDP) automatically negotiates and manages the power feed to IEEE 802.3at PoE+ and 802.3bt PoE++ powered devices for optimal power distribution.
Secure Your Network
The D-Link’s innovative Safeguard Engine protects the switches against traffic flooding caused by malicious attacks. 802.1X port-based and host-based authentication allows clients to be authenticated through external RADIUS servers and can provide a more secure network connection. The Access Control List (ACL) feature can help enhance network security and better control access between internal networks. The DHCP server screening feature can filter DHCP replies on unauthorized ports to prevent them from being assigned an IP address, which provides an additional security mechanism.
Enhanced Surge Protection
The DMS-1250 Series switches offer enhanced 6kV surge protection on all 2.5-Gigabit Ethernet access ports. The 6kV surge protection helps shield the switches against sudden electrical surges, such as lightning strikes or unstable electrical current. Built-in 6kV surge protection helps reduce the chances of equipment being damanged from electrical surges, and effectively lowers maintenance costs by minimizing the need for expensive repairs and replacement.
Advanced L2/L2+ Features
The DMS-1250 series switches provides configurable L2 network features like VLANs, Quality of Services, Spanning Tree Protocol. The Auto Surveillance VLAN (ASV) and Voice VLAN function can guarantee the quality of video and voice services through the individual VLAN with higher priority. The Differentiated Service Code Point (DSCP) markings on Ethernet packets enable different levels of service to be assigned to network traffic. These voice and video packets thus can take precedence over other packets. It also supports Static route, IPv4/IPv6, LACP link aggregation and IGMP snooping, which can meet the needs of most business applications.
Põhiomadused
Number of Ports
• 8 x 100/1000/2.5GBase-T PoE
• 2 x SFP+ ports
LEDs
• Power
• Link/Activity/Speed (per port)
• PoE OK/PoE Fail (per PoE port)
• PoE Max
• LED Mode (Link/PoE)
Standards
• IEEE 802.3 10Base-T
• IEEE 802.3u 100Base-TX
• IEEE 802.3ab 1000Base-T
• IEEE 802.3bz 2.5GBase-T
• IEEE 802.3z 1000Base-X
• IEEE 802.3ae 10GBase-X
• IEEE 802.3x Flow Control
• Auto MDI/MDIX adjustment for all twisted-pair ports
Performance
• Switching Capacity: 80 Gbps
• Transmission Method: Store-and-forward
• MAC Address Table: 16K entries
• Packet Forwarding Rate: 59.53 Mpps
• Static MAC Addresses: 256 entries
• Packet Buffer Memory: 1.5 MB
• Jumbo Frame Size: 12,288 bytes
PoE Standards
• IEEE 802.3af
• IEEE 802.3at
• IEEE 802.3bt/UPoE
• Perpetual PoE
• Fast PoE
PoE Capable Ports
• Ports 1-8
PoE Power Budget
• 120 W (maximum 60 W per PoE port 1-2, maximum 30 W per PoE port 3-8)
Software Features
L2 Features
• IGMP Snooping
• IGMP v1/v2/v3 awareness
• Supports 256 groups
• Supports 256 static multicast groups
• IGMP Snooping per VLAN
• IGMP Snooping Querier
• Port-based IGMP Snooping Fast Leave
• Loopback Detection
• 802.3ad Link Aggregation:
• Supports maximum 8 groups per per device and 8 ports per group
• LLDP
• LLDP-MED
• Spanning Tree Protocol
• 802.1D STP
• 802.1w RSTP
• 802.1s MSTP
• Flow Control
• 802.3x Flow Control
• HOL Blocking Prevention
• Port Mirroring
• One-to-One
• Many-to-One
• Supports Mirroring for Tx/Rx/Both
• Ethernet Ring Protection Switching (ERPS)
• Multicast Filtering
• Forwards all registered groups
• Filters all unregistered groups
• MLD Snooping
• MLD v1/v2 awareness
• Supports 64 static multicast groups
• MLD Snooping per VLAN
• MLD Snooping Querier
• Port-based MLD Snooping Fast Leave
VLAN
• 802.1Q
• VLAN Group
• Max. 4094 static VLAN groups
• Configurable VID from 1 - 4094
• Asymmetric VLAN
• Auto Voice VLAN
• Auto Surveillance VLAN
• GVRP
• Double VLAN (Q-in-Q)
• Selective Q-in-Q
• VLAN translation
• Multicast VLAN (ISM VLAN для IPv4/IPv6)
QoS (Quality of Service)
• 802.1p Quality of Service
• 8 queues per port
• Queue Handling
• Strict
• Weighted Fair Queuing (WFQ)
• Weighted Round Robin (WRR)
• Bandwidth Control
• Port-based (ingress/egress, min granularity 10/100/1000 is 16 Kbps)
• QoS based on:
• 802.1p priority queues
• DSCP
• Switch port
L3 Features
• IP interface
• Supports 8 IPv4 interfaces
• Supports 8 IPv6 interfaces
• Static route
• 128 IPv4 static route entries
• 64 IPv6 static route entries
• Max. 50 access lists
• Max. 768 entries shared by IPv4 and MAC
• Max. 384 entries for IPv6
• Each rule can only be associated with a single port
• ACL based on
• MAC address
• 802.1p priority
• VID
• Source/destination MAC address wildcard
• EtherType mask
• IP address
• Source/destination IP address wildcard
• DSCP
• Protocol type
• TCP/UDP port number
• IPv6 address
• Source/destination IP address prefix length
• DSCP
• Protocol type
• IPv6 traffic class
Security
• Broadcast/Multicast/Unicast Storm Control
• D-Link Safeguard Engine
• Traffic segmentation
• TLS v1.3
• DoS attack prevention
• Port Security
• Supports up to 64 MAC addresses per port
• DHCP Server Screening
• IP-MAC-Port Binding (Smart Binding)
• ARP Inspection
• Max. 64 entries
• DHCP Snooping
AAA
• 802.1X Authentication
• Supports local/RADIUS database
• Supports port-based access control
• Supports host-based access control
• Supports EAP, OTP, TLS, TTLS, PEAP
• IPv6 RADIUS server
• Support MD5 authentication
• AAA support for RADIUS/TACACS+
OAM
• Cable diagnostics
• Factory reset
• DDM support for optics
Management
• Web-based GUI
• CLI through Telnet and SSH
• Telnet Server
• SSH Server
• TFTP Client
• Auto MDI/MDIX
• SNMP
• Supports v1/v2c/v3
• SNMP Trap
• Backup/upgrade firmware
• Smart Wizard
• Upload/download configuration file
• BootP/DHCP Client
• DHCP Relay
- DHCP Relay option 82
• System Log
• SNTP
• ICMPv6
• IPv4/v6 Dual Stack
• DHCP Auto Configuration
• Time setting
• SNTP
• RMONv1
• Trusted host
• Dual image
• Dual configuration
• Password encryption
• Command logging
• PD-Alive
Green Features
• Power saving by link status
• Power saving by LED shut-off
• Power saving by port shut-off
• Power saving by system hibernation
• Time-based PoE
MIBs
• RFC1213 MIBII
• RFC1493 Bridge MIB
• RFC1157, RFC2573, RFC2575, RFC2576 SNMP MIB
• RFC1442, RFC1901, RFC1902, RFC1903, RFC1904, RFC1905, RFC1906, RFC1907, RFC1908, RFC2578, RFC3418 SNMPv2 MIB
• RFC271, RFC1757, RFC2819 RMON MIB
• RFC2021 RMONv2 MIB
• RFC1398, RFC1643, RFC1650, RFC2358, RFC2665 Ether-like MIB
• RFC2674 802.1p MIB
• Interface Group MIB
• RFC4022 MIB for TCP
• RFC4113 MIB for UDP
• Private MIB
• PoE MIB
• DDP MIB
• LLDP-MED MIB
RFC Standards
• RFC791 IP
• RFC768 UDP
• RFC793 TCP
• RFC792 ICMPv4
• RFC2463, RFC4443 ICMPv6
• RFC826 ARP
• RFC1321, RFC2284, RFC2865, RFC2716, RFC3580 Extensible Authentication Protocol (EAP)
• RFC2573 SNMP Applications
• RFC2461, RFC4861 Neighbor Discovery for IPv6
• RFC2462, RFC4862 IPv6 Stateless Address Auto-configuration (SLAAC)
• RFC4291 IPv6 Addressing Architecture
• RFC2893, RFC4213 IPv4/IPv6 dual stack function
Physical Parameters
MTBF
• 591,612.47 hours
Heat Dissipation
• 146.91 W (501.58 BTU/h)
Power Input
• DC 54V / 2.78A
Maximum Power Consumption
• 147 W (PoE On) / 18.84 W (PoE Off)
Standby Power Consumption
• 5.14 W
Dimensions
• 210 x 210 x 44 mm
Weight
• 1.34 kg
Acoustic
• 0 dB
Ventilation
• Fanless
Surge Protection
• Built-in 6 kV surge protection on all copper ports
Operating Temperature
• 0 to 40 °C
Storage Temperature
• -20 to 70 °C
Operating Humidity
• 0% to 95% non-condensing
Storage Humidity
EMI
• CE Class A, VCCI Class A, FCC Class A, IC, BSMI
Safety
• CB, UL, BSMI
Sertifikaadid
Sidustooted
DMS-1250-10SPL/A1A/6KV Multi-Gigabit Smart Switch with 8-port 2.5GBase-T PoE and 2-port SFP+
