DGS-1210-52MPProjektideks
Web Smart Switch with 48 Port 10/100/1000 Mbps PoE and 4-port SFP
Kirjeldus
The D-Link DGS-1210 Series is the latest generation of switches to provide a range of physical interface types, multiple management interfaces, and advanced Layer 2 features. With all of these features combined, the DGS-1210 Series provides a cost-efficient and flexible solution for expanding any business network.
Seamless Integration
The DGS-1210-52MP switch is equipped with 48 10/100/1000Base-T PoE ports and 4 100/1000Base-T/SFP combo ports, allowing you to choose the most suitable media type for your requirements.
PoE Support
The DGS-1210-52MP switch features Power over Ethernet (PoE) technology, allowing compatible devices to be installed and powered in remote locations without immediate access to power outlets. Dedicated power adapters are no longer required, as the DGS-1210-52MP complies with IEEE 802.3af and 802.3at PoE standards and provide up to 30 watts per port. Perpetual PoE is also available with the DGS-1210-52MP. Perpetual PoE delivers uninterrupted power to connected powered devices (PD) even when the power sourcing equipment (PSE) switch is booting.
Advanced Features
The DGS-1210-52MP switch comes equipped with a complete lineup of L2 features, including IGMP snooping, port mirroring, Spanning Tree Protocol (STP), and Link Aggregation Control Protocol (LACP). The IEEE 802.3x Flow Control function allows servers to directly connect to the switch for fast, reliable data transfers. The switch also supports advanced features such as static routes, which allow network administrators to divide the network into VLANs, increasing network efficiency. Network maintenance features include loopback detection and cable diagnostics. Loopback detection significantly speeds up troubleshooting by automatically detecting and shutting down switching loops. The cable diagnostics feature, designed primarily for administrators and customer service representatives, determines the cable quality and quickly discovers errors, allowing for hassle-free diagnostics and maintenance.
Auto Surveillance VLAN and Auto Voice VLAN
The DGS-1210-52MP supports Auto Voice VLAN and Surveillance Mode, which allows voice and video traffic to be automatically identified and handled differently to regular network traffic. Auto Voice VLAN detects Voice over IP (VoIP) traffic and automatically segments it from the rest of the network, increasing security and allowing Quality of Service (QoS) to be applied. Surveillance Mode detects compatible ONVIF cameras and places them in a surveillance VLAN, allowing a single switch to be used for voice, video, and data, removing the need for dedicated hardware and reducing maintenance costs. Surveillance Mode also includes its own Web UI, making surveillance features easily accessible and simplifying management of your surveillance network.
Secure your Network
D-Link's innovative Safeguard Engine protects the switches against traffic flooding caused by virus attacks. The switch also supports 802.1X port-based authentication, allowing the network clients to be authenticated through external RADIUS servers. The Access Control List (ACL) feature enhances network security and helps to protect the internal IT network. The DGS-1210-52MP also features Address Resolution Protocol (ARP) spoofing prevention, which provides protection from attacks on the network that could allow an intruder to sniff data frames, modify traffic, or bring traffic to a halt altogether by sending fake ARP messages. To prevent ARP spoofing attacks, the switch uses packet control ACLs to block invalid packets that contain fake ARP messages. For added security, the DHCP server screening feature filters DHCP replies on unauthorized ports to prevent them from being assigned an IP address.
Versatile Management
The DGS-1210-52MP switch comes with the D-Link Network Assistant (DNA) utility that enables administrators to remotely control their network down to the port level. The D-Link Network Assistant utility furthermore allows customers to easily discover multiple D-Link Smart Managed Switches within the same L2 network segment and display them on-screen for instant access. With this utility, users do not need to change the IP address of their PC. This allows for simultaneous configuration and basic setup of all discovered devices, including password changes and firmware upgrades. The switch also supports D-View 7.0 and Command Line Interface (CLI) through Telnet. D-View 7.0 is a network management system that allows for the central management of critical network characteristics such as availability, reliability, resilience, and security.
Põhiomadused
General Port Standards & Functions
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet (twisted- pair copper)
• IEEE 802.3z 1000Base-X
• IEEE 802.3x Flow Control
• Auto-negotiation
• Auto MDI/MDIX adjustment for all twisted-pair ports
Number of Ports
• 48 Ports 10/100/1000Mbps PoE
• 4 combo 100/1000Base-T/SFP ports
Network Cables
• UTP Cat. 5, Cat. 5e (100 m max.)
Full/Half Duplex
• Full/half duplex for 10/100 Mbps speeds
• Full duplex for Gigabit speed
Switching Capacity
• 104 Gbps
Transmission Method
• Store-and-forward
MAC Address Table
• 16,000 entries per device
MAC Address Update
• Up to 256 static MAC entries
Maximum 64 bytes packet forwarding rate
• 77.4 Mpps
Packet Buffer Memory
• 1.5 MB
DDRIII for CPU
• 128 Mbytes
Flash Memory
• 32 Mbytes
Software
L2 Features
• MAC Address Table
- 16K entries
• IGMP Snooping
- IGMP v1/v2 Snooping
- IGMP v3 awareness
- Supports 256 IGMP groups
- Supports at least 64 static multicast addresses
- IGMP per VLAN
- Supports IGMP Snooping Querier
• Loopback Detection
• 802.3ad Link Aggregation:
- Maximum of 16 groups/8 ports per group
• LLDP
• LLDP-MED
• Jumbo Frame
- Up to 10,000 bytes
• Spanning Tree Protocol
- 802.1D STP
- 802.1w RSTP
- 802.1s MSTP
• Flow Control
- 802.3x Flow Control
- HOL Blocking Prevention
• Port Mirroring
- One-to-One
- Many-to-One
- Supports Mirroring for Tx/Rx/Both
• Multicast Filtering
- Forwards all unregistered groups
- Filters all unregistered groups
• Configurable MDI/MDIX
• MLD Snooping
- MLD v1
- MLD v2 awareness
- 256 MLD groups
VLAN
• 802.1Q
• VLAN Group
- Max. 256 static VLAN groups
- Configurable VID from 1 - 4094
• Asymmetric VLAN
• Auto Voice VLAN
- Max. 10 user-defined OUI
- Max. 8 default OUI
• Auto Surveillance VLAN
• 802.1p
• 8 queues per port
• Queue Handling
- Strict
- Weighted Round Robin (WRR)
• Bandwidth Control
- Port-based (Ingress/Egress, min granularity 10/100/1000 is 64 Kbps)
• QoS based on:
- 802.1p Priority Queues
- DSCP
- ToS
- IP Precedence
- IPv6 Traffic Class
- TCP/UDP port
- MAC address
- EtherType
- IP address
- Protocol type
L3 Features
• IP Interface
- Supports 4 interfaces
• Static routing
- 124 IPv4 static route entries
- 50 IPv6 static route entries
• Max. 50 access list
• Max. 768 rules shared by IPv4, MAC and IPv6
• Each rule can only be associated with a single port
• ACL based on
- 802.1p priority
- VLAN
- MAC address
- Ether type
- IP address
- DSCP
- Protocol type
- TCP/UDP port number
Security
• Broadcast/Multicast/Unicast Storm Control
• D-Link Safeguard Engine
• DHCP Server Screening
• IP-MAC-Port Binding (Smart Binding)
- ARP Inspection
- ARP + IP Inspection
- Supports DHCP Snooping
• 802.1X Port-based Access Control
• ARP Spoofing Prevention
- Max. 127 entries
• Traffic Segmentation
• SSH v2
• SSL
• TLS v1.3
• DoS attack prevention
• Port Security
- Supports up to 64 MAC addresses per port
AAA
• 802.1X Authentication
- Supports local/RADIUS database
- Supports port-based access control
- Supports EAP, OTP, TLS, TTLS, PEAP
• IPv6 RADIUS Server
• Support MD5 authentication
• Guest VLAN
MIB/RFC Standards
• RFC768 UDP
• RFC783, 1350 TFTP
• RFC791 IP
• RFC792 ICMPv4
• RFC793 TCP
• RFC826 ARP
• RFC951, 1542, 2131 BootP/DHCP Client
• RFC2463, 4443 ICMPv6
• RFC1213 MIB II
• RFC1350 TFTP
• RFC1493 Bridge MIB
• RFC1769 SNTP
• RFC1157, 2570, 2573, 2575, 2576 SNMP MIB
• RFC1442, 1901, 1902, 1903, 1904, 1905, 1906, 1907, 1908, 2578, 3418 SNMPv2 MIB
• RFC271, 1757, 2819 RMON MIB
• RFC2021 RMONv2 MIB
• RFC1398, 1643, 1650, 2358, 2665 Ether-like MIB
• RFC1321, 2284, 2865, 2716, 3580 Extensible Authentication Protocol (EAP)
• RFC2674 802.1p MIB
• RFC2461, 4861 Neighbor Discovery for IPv6
• RFC2462, RFC4862 IPv6 Stateless Address Auto-configuration (SLAAC)
• RFC4291 IPv6 Addressing Architecture
• RFC2893, 4213 IPv4/IPv6 dual stack function
• Interface Group MIB
• RFC2138, 2139, 2618, 2865 RADIUS Authentication Client MIB
• RFC2246 SSL
• RFC2475, 2598 CoS
• RFC3164, 3195 System Log
• RFC3411, 3412, 3413, 3414, 3415, 3416, 3417 SNMPv3
• RFC4022 MIB for TCP
• RFC4113 MIB for UDP
• RFC2389 MIB for Diffserv.
• Private MIB
• PoE MIB
• DDP MIB
• LLDP-MED MIB
OAM
• Cable Diagnostics
• Factory Reset
Management
• Web-based GUI
• D-Link Network Assistant Utility
• Compact CLI
• Telnet Server
• TFTP Client
• SNMP
- Supports v1/v2c/v3
• SNMP Trap
• Backup/Upgrade firmware
• Smart Wizard
• Upload/Download Configuration file
• System Log
- Max. 500 log entries
• BootP/DHCP Client
• SNTP
• ICMPv6
• IPv4/v6 Dual Stack
• DHCP Auto Configuration
• Time Setting
- SNTP
• RMONv1
• Trusted Host
• Dual image
• Dual configuration
• CPU monitoring
• PD Alive
Green V3.0 Technology
• Power Saving by:
- Link status
- Cable length detection
- Port shut off
- System hibernation
- Time-based PoE: PoE ports can be turned on/off by port or system through schedule
Physical/Environmental
AC Input
• 100 to 240 VAC 50/60 Hz internal universal power supply
Maximum Power Consumption (PoE enabled)
• 478.9 W/100 V
• 454.1 W/240 V
Maximum Power Consumption (PoE disabled)
• 54 W/100 V
• 54.4 W/240 V
Standby Power Consumption
• 32 W/100 V
• 31,6 W/240 V
Fan Quantity
• 3
Acoustics
• Low speed: 47.6 dBA
• High speed: 52.4 dBA
Heat Dissipation
• 1634.01 BTU/hr (100 V)
• 1549.29 BTU/hr (240 V)
Operating Temperature
• -5 to 50 ˚C
Storage Temperature
• -20 to 70 ˚C
Operating Humidity
• 0% to 95% non-condensing
Storage Humidity
Dimensions (L x W x H)
• 440 mm x 430 mm x 44 mm
Weight
• 6.26 kg
Diagnostic LEDs
• Power (per device)
• Link/Activity/Speed (per port)
• Power Fail/Power Ok (per PoE port)
• PoE Max
• Fan Error
Certifications
• CE Class A
• VCCI Class A
• FCC Class A
• BSMI
• CCC
• C-Tick
• cUL
Sertifikaadid
Sidustooted
DGS-1210-52MP/F3A
