DGS-3130-30PSProjektideks
24 1000Base-X SFP ports, 2 10GBase-T ports and 4 10G SFP+ port L3 Stackable* Managed Switch
Kirjeldus
The DGS-3130 Series switches are Lite Layer 3 Stackable* Managed Switches designed to connect end-users in a secure enterprise or metro Ethernet access network. These switches support multicast, and enhanced security, making them an ideal Gigabit access layer solution. The DGS-3130-30S provides 24 1000Base-X SFP ports, 2 10GBase-T ports and 4 10G SFP+ port. The switches are also equipped with an USB 2.0 port, allowing the user to boot images and upload configuration files directly from, as well as conveniently save syslog files onto a USB 2.0 storage device.
Enhanced Network Reliability
The DGS-3130 Series targets enterprises and metro Ethernet applications, and customers who require a high level of network security and maximum uptime. All the models in the DGS-3130 Series support an external redundant power supply** to ensure continued operation. They also include reliability features, such as 802.1D Spanning Tree (STP), 802.1w Rapid Spanning Tree (RSTP), and 802.1s Multiple Spanning Tree (MSTP), Loopback Detection (LBD), and Broadcast Storm Control, that enhances network resilience. G.8032 Ethernet Ring Protection Switching (ERPS) minimizes the recovery time to 50 ms. For load sharing and redundancy backup in a switch cascading/server attachment configuration, the DGS-3130 Series provides dynamic 802.3ad Link Aggregation Port Trunking.
Comprehensive Security
The DGS-3130 Series provides users with the latest security features such as Multi-layer and Packet Content Access Control Lists (ACL), Storm Control, and IP-MAC-Port Binding (IMPB) with DHCP Snooping. The IP-MAC-Port Binding feature allows administrators to bind a source IP address with an associated MAC and also define the port number to enhance user access control. With the DHCP Snooping feature, the switch automatically learns IP/MAC pairs by snooping DHCP packets and saving them to the IMPB white list.
Easy Access Control Policies
The DGS-3130 Series supports authentication mechanisms such as 802.1X, Web-based Access Control (WAC), and MAC-based Access Control (MAC) for strict access control and easy deployment. After authentication, individual policies such as VLAN membership, QoS policies, and ACL rules can be assigned to each host. In addition, the switch also supports Microsoft® NAP (Network Access Protection). NAP is a policy enforcement technology that allows customers to protect network assets from compromised computers by enforcing compliance with network health policies.
Versatile Traffic Management
The DGS-3130 Series implements a rich set of multilayer QoS/CoS features to ensure that critical network services such as VoIP, video conferencing, IPTV, and IP surveillance are given high priority. Traffic Shaping features guarantee bandwidth for these services when the network is busy. L2 Multicast support enables the DGS-3130 Series to handle growing IPTV applications. Host-based IGMP/MLD Snooping allows multiple multicast subscribers per physical interface and ISM VLAN to send multicast streams in a multicast VLAN to save bandwidth and to provide better security to the backbone network. The ISM VLAN profiles allow users to bind/replace the pre-defined multicast registration information to subscriber ports quickly and easily.
* When stacking the DGS-3130-30TS/30S/30PS models, the stacking cost is 1 per unit so the maximum units per stack is 9.
When stacking the DGS-3130-54TS/54S/54PS models, the stacking cost is 2 per unit so the maximum units per stack is 6.
When stacking different models in the same stack, switches can be stacked up to a maximum of 12 stacking cost per stack. For example: 2 x DGS-3130-30TS (2 stacking cost) + 2 x DGS-3130-30S (2 stacking cost) + 4 x DGS-
3130-54TS (8 stacking cost) consumes a total stacking cost of 12 (2+2+8).
** RPS is not included in the package contents.
Põhiomadused
Number of Ports
• 24 x 1000Base-X SFP ports
• 2 x 10GBase-T ports
• 4 x 10G SFP+ ports
Optional Redundant Power Supply*
• DPS-500A
Console Port
• 10/100/1000Base-T RJ-45 port for out-of-band CLI management
Management Port
• 10/100/1000Base-T RJ-45 port for out-of-band IP management
USB Ports
• USB 2.0 Type A port
Performance
• Switching Capacity: 168 Gbps
• Switching Method: Store-and-forward
• Packet Forwarding Rate: 125 Mpps
• MAC Address Table: 16K entries
• Static MAC Addresses: 512 entries
• Packet Buffer Memory: 2 MB
• Jumbo Frame Size: 9 216 bytes
Software Features
Stackability
• Virtual Stacking
  - D-Link Single IP Management (SIM)
  - Up to 32 units per virtual stack
• Physical Stacking**
  - Up to 80 Gbps stacking bandwidth
  - Up to 9 switches in a stack
  - Ring topology support
L2 Features
• MAC Address Table: 16K (16,384) entries
• Flow Control
  - 802.3x Flow Control
  - HOL Blocking Prevention
• Link Aggregation
  - 802.1AX
  - 802.3ad
  - Max. 32 groups per device, 8 ports per group
• Spanning Tree Protocol
  - 802.1D STP
  - 802.1w RSTP
  - 802.1s MSTP
  - BPDU Filtering
  - Root Guard (Restriction)
• Loopback Detection
• Port Mirroring
  - One-to-One
  - Many-to-One
  - Mirroring for both Tx/Rx
  - RSPAN
• Ethernet Ring Protection Switching (ERPS)
  - Single /multiple ring topology
L2 Multicasting
• IGMP Snooping
  - IGMP v1/v2/v3 Snooping
  - Supports 1024 IGMP groups
  - Port-based IGMP Snooping Fast Leave
  - Supports 512 static IGMP groups
  - Per VLAN IGMP Snooping
  - Data Driven Learning
  - IGMP Snooping Querier
  - IGMP Authentication
  - IGMP Accounting
  - Report Suppression
• MLD Snooping
  - MLD v1/v2 Snooping
  - Support 1024 MLD Groups
  - Port-based MLD Snooping Fast Leave
  - Supports 512 static MLD groups
  - MLD Snooping Querier
  - Per VLAN MLD Snooping
  - MLD Proxy Reporting
VLAN
• VLAN Group
  - Max. 4K VLAN Groups
• GVRP
  - Max. 4K Dynamic VLAN Groups
• 802.1Q Tagged VLAN
• Port-based VLAN
• 802.1v Protocol VLAN
• Voice VLAN
• MAC-based VLAN
• VLAN translation
• ISM VLAN
• Asymmetric VLAN
• Private VLAN
• VLAN Trunking
• Double VLAN Q-in-Q
  - Port-based Q-in-Q
  - Selective Q-in-Q
QoS (Quality of Service)
• 802.1p
• 8 queues per port
• Queue Handling
  - Strict Priority
  - Weighted Round Robin (WRR)
  - Strict + WRR
• Supports following actions for flows
  - Remark 802.1p Priority Tag
  - Remark TOS/DSCP Tag
  - Bandwidth Control
• CoS based on
  - Switch Port
  - VLAN ID
  - 802.1p Priority Queues
  - MAC Address
  - IPv4 Address
  - DSCP
  - Protocol Type
  - TCP/UDP Port
  - User-Defined Packet Content***
  - IPv6 Address
  - IPv6 Traffic Class
  - IPv6 Flow Label
• Bandwidth Control
  - Port-based (Ingress/Egress, Min. Granularity 8 Kbps)
  - Flow-based (Ingress/Egress, Min. Granularity 8 Kbps)
• Three Color Marker
  - CIR/PIR minimum granularity: 8 kbps
  - Two Rate Three Color Marker (trTCM), CBS/PBS
  - Single Rate Three Color Marker (srTCM), CBS/EBS
• Congestion Control
  - Weighted Random Early Detection (WRED)
Access Control List (ACL)
• ACL based on
  - 802.1p Priority
  - VLAN ID
  - MAC Address
  - Ether Type
  - IPv4 Address
  - DSCP
  - Protocol Type
  - TCP/UDP Port Number
  - IPv6 Address
  - IPv6 Flow Label
• Supports up to 2048 ingress access entries
• Supports up to 512 egress access entries
• Time-based ACL
• CPU Interface Filtering
Security
• SSH v2
• SSL v1/v2/v3
• Port Security
  - Up to 64 MAC addresses per port
• IP-MAC Port Binding
• DHCP Snooping
• Supports up to 500 address binding entries
• Broadcast/Multicast/Unicast Storm Control
• Traffic Segmentation
• D-Link Safeguard Engine
• NetBIOS/NetBEUI Filtering
• IPv6 ND Snooping
• DHCP Server Screening
• ARP Spoofing Prevention
  - Max. 64 entries
• DoS Attack Prevention
• BPDU Attack Protection
• ARP Packet Inspection
• IP Packet Inspection
AAA
• 802.1X:
  - Port-based Access Control
  - Host-based Access Control
  - Identity-driven Policy (VLAN, ACL or QoS) Assignment
• Web-based Access Control (WAC):
• MAC-based Access Control (MAC):
• Authentication Database Failover
• Guest VLAN
• Microsoft® NAP
  - Support 802.1X NAP
  - Support DHCP NAP
• RADIUS Accounting
• RADIUS and TACACS+ authentication for switch access
• Four levels of User Account control
Green Features
• Power saving by link status
• Power saving by LED shut-off
• Power saving by port shut-of
• Power saving by system hibernation
• Time-based PoE
OAM
• 802.3ah Ethernet Link OAM
• D-Link Unidirectional Link Detection (DULD)
• Dying Gasp
• Y.1731 OAM
• Optical Transceiver Digital Diagnostic Monitoring (DDM)
Management
• Web-based GUI
• Command Line Interface (CLI)
• Telnet Server
• Telnet Client
• TFTP Client
• DNS Client
• Secure FTP Server
• ZModem
• SNMP v1/v2c/v3
• SNMP Traps
• System Log
• sFlow
• RMON v1:
  - Supports 1,2,3,9 groups
• RMON v2:
  - Supports ProbeConfig group
• LLDP
• BootP/DHCP Client
• DHCP Auto-Configuration
• DHCP Relay
• DHCP Client Option 12
• DHCP Relay Option 18, 37, 82
• Flash File System
• PPPoE Circuit-ID Tag Insertion
• Multiple Images
• Multiple Configurations
• CPU Monitoring
• Debug Command
• SNTP
• Password Recovery
• Password Encryption
• Trusted Host
• Microsoft® NLB (Network Load Balancing) Support
• ICMPv6
• DHCP server
L3 Features
• 4K ARP entries
   - 256 static ARP entries
• Max. 128 IP Interfaces
• ARP Proxy
• IPv6 Neighbour Discovery (ND)
L3 Routing
• Static Route
  - Max. 512 IPv4 entries
  - Max. 256 IPv6 entries
• RIPv1/v2/ng
• OSPFv2/v3
• VRRP
• VRRPv3
• Supports 1024 hardware routing entries shared by IPv4/IPv6
• Supports up to 4096 hardware L3 forwarding entries shared by IPv4/IPv6
• Policy-based Route
L3 Multicasting
• IGMP v1/v2/v3
• PIM-SM
• IGMP Filtering
  - Port-based filtering
  - VLAN-based filtering
MIB
• RFC 1213 MIB II
• RFC 4188 Bridge MIB
• RFC 1157, 2571-2576 SNMP MIB
• RFC 1907 SNMPv2 MIB
• RFC 1757, 2819 RMON MIB
• RFC 2021 RMONv2 MIB
• RFC 1398, 1643, 1650, 2358, 2665 Ether-like MIB
• RFC 2674 802.1p MIB
• RFC 2233, 2863 IF MIB
• RFC 2925 PING & TRACEROUTE MIB
• RFC 2674, 4363 802.1p MIB
• RFC 1065, 1066, 1155, 1156, 2578 MIB Structure
• RFC 1212 Concise MIB Definitions
• RFC 4022 MIB for TCP
• RFC 4113 MIB for UDP
• RFC 2737 Entity MIB (version 2)
RFC Standard Compliance
• RFC 768 UDP
• RFC 791 IP
• RFC 792, 2463, 4443 ICMP
• RFC 793 TCP
• RFC 826 ARP
• RFC 3513, 4291, IPv6 Addressing Architecture
• RFC 2893, 4213 IPv4/IPv6 dual stack function
• RFC 2463, 4443 ICMPv6
• RFC 2462, 4862 IPv6 Stateless Address Auto Configuration
• RFC 2464 IPv6 Ethernet and definition
• RFC 1981 Path MTU Discovery for IPv6
• RFC 2460 IPv6
• RFC 2461, 4861 Neighbor Discovery for IPv6
• RFC 783 TFTP
• RFC 2068 HTTP
• RFC 1492 TACACS
• RFC 2866 RADIUS Accounting
• RFC 2474, 3260 DiffServ
• RFC 1321, 2284, 2865, 3580, 3748 Extensible Authentication Protocol (EAP)
• RFC 2571, 2572, 2573, 2574, SNMP
• IPv6 Ready Logo Phase 2
• RFC 854 Telnet
• RFC 951, 1542 BootP
• RFC 3484 Default Address Selection
Physical Parameters
MTBF
• 400,490 hours
Acoustics
• Max: 52.3 dB
• Min: 42.7 dB
Heat Dissipation
• 221.8 BTU/h
Power Input
• 100 to 240 VAC 50/60 Hz
Maximum Power Consumption
• 65.01 W
Standby Power Consumption
• 22.77 W
Dimensions
• 440 x 250 x 44 mm
Weight
• 3.5 kg
Ventilation
• 3 Smart fans
Operating Temperature
• 0 to 50 °C
Storage Temperature
• -40 to 70 °C
Operating Humidity
• 10% to 90% RH
Storage Humidity
• 5% to 90% RH
Certificates
• RoHS
EMI
• FCC Class A, CE Class A, VCCI Class A, IC, RCM, BSMI
Safety
• CB, cUL, BSMI
** When stacking the DGS-3130-30TS/30S/30PS models, the stacking cost is 1 per unit so the maximum units per stack is 9.
*** Will be available in future firmware versions.
Sertifikaadid
Sidustooted
DGS-3130-30PS/B1A  24 1000Base-X SFP ports, 2 10GBase-T ports and 4 10G SFP+ port L3 Stackable* Managed Switch
Pildid
DGS-3130-30PS/B1
Eestvaade
Paremvaade
Tagantvaade
Failid
Vaadake samuti
