DEM-S2801SR
25GBase-SR Multi-mode OM3 (70 m) / OM4 (100 m) SFP28 Transceiver
Kirjeldus
D-Link’s 25G SFP28 Module series are hot-swappable SFP28 transceivers that are plugged into SFP28 slots on switches and support 25G Ethernet. The transceivers use the Small Form-factor Pluggable 28 format (SFP28) connectors. The D-Link 25G SFP28 Module Series transceivers offer customers a wide variety of 25G Ethernet connectivity options for data centers, enterprise wiring closets, and service provider transport applications.
Hot Pluggable
All D-Link transceivers are hot pluggable. You can connect atransceiver while the system is powered on without causing any issues, and easily swap one for another without having to reboot the switch each time. This permits modules to be added or removed without interrupting the network, facilitating maintenance and greatly reducing downtime.
25G Ethernet speeds
The transceivers support 25G Ethernet, which results in very fast data transmissions of up to 25 Gbit/s. This is 25 times faster than Gigabit Ethernet and enables the switch to handle faster and higher data transmissions, making it very suitable for business needs.
Põhiomadused
Interfaces
• One 25GBase-SR port
Form-factor Type
• SFP28
Connector
• Duplex LC
Single/Bi Direction
• Single direction
Fiber Media support
• Multi-mode
Standards
• IEEE 802.3by 25GBase-SR
Distance Capacity
• OM3 MMF: 70 m
• OM4 MMF: 100 m
Data Rate
• 25 Gbps
Wavelength
• 850 nm
Output Optical Power (TX)
• Max.: 2.4 dBm
• Min.: -9.1 dBm
Input Optical Power (RX)
• Max.: 2.4 dBm
• Min.: -11 dBm
Sensitivity
• -11 dBm
Cable Type
• 50/125 um Multi-mode Fiber
Supported Features
• Hot Pluggable
• MSA Compliant
• RoHS Compliant
Physical Parameters
Power Support
• 3.3 V
Max. Input Current
• 300 mA
Min. Power Budget
• 1.9 dBm
Max. Power Budget
• 13.4 dBm
Heat Generated
• 3.6 KJ/h
Temperature
• Operating: 0° to 70°C
• Storage: -40° to 85°C
Humidity
• Operating: 5% to 95%
• Storage: 5% to 95%
Dimensions
• 57.3 x 13.7 x 8.5 mm
Weight
• 25 g
EMI
• CE
• FCC
• VCCI
Safety
• LVD
• EN 60825-1
• EN 60825-2
Sertifikaadid
Sidustooted
DEM-S2801SR/A1 25GBase-SR Multi-mode OM3 (70 m) / OM4 (100 m) SFP28 Transceiver
