![](/up/prod/600/DIS-PWR180AC_.jpg)
DIS-PWR180ACEOL
External AC Power Adapter (180 W) for the DIS-200G-12PS switch
Kirjeldus
The DIS-PWR180AC external AC power adapter is an efficient and reliable device, that allows to provide power supply for the DIS-200G-12PS switch.
Põhiomadused
Output Power
• 180 W
Input Voltage Range
• 90 to 264 V AC
Input Voltage Frequency Range
• 47 Hz to 63 Hz
Max. Input Current
• 2.5 A
Max. Inrush Current
• 3.34 A @ 100 V AC, 240 V AC
Efficiency
• 89%
Physical Parameters & Environmental Conditions
Dimensions (L x W x H)
• 170 x 85 x 42.5 mm
Weight
• 0.801 kg
MTBF
• Over 100 000 hours
Temperature
• Operating: -40 to 50 °C
• Storage: -40 to 50 °C
Humidity
• Operating: 20% to 80% non-condensing
• Storage: 10% to 90% non-condensing
Compatible Equipment
• DIS-200G-12PS switch
Sertifikaadid
Sidustooted
DIS-PWR180AC External AC Power Adapter (180 W) for the DIS-200G-12PS switch
