DGS-6600-PWRDCProjektideks
Redundant 300 W DC Power Supply for DGS-6600 Series
Kirjeldus
Redundant AC and DC power supplies can not be used together. Redundant DC power supplies don't support PoE functionality, i.e. PoE modules will work as usual modules.
Põhiomadused
Output Power
• 300 W
Input Voltage Range
• 36~72 VAC
Max. Input Current
• 10 A @ 48 VAC
Max. Inrush Current
• 30 A
Efficiency
• 80%
Physical Parameters
Dimensions (L x W x H)
• 279.4 x 81.3 x 39.9 mm
MTBF
• 300 000 hours
Temperature
• Operating: 0 to 50 C
• Storage: -40 to 70 C
Humidity
• Operating: 10 to 90% non-condensing
• Storage: 5 to 90% non-condensing
Sertifikaadid
Sidustooted
DGS-6600-PWRDC/A1A Redundant 300 W DC Power Supply for DGS-6600 Series
