DEM-CB700SEOL
10G Passive SFP+ Twinaxial Direct Attach Cable, 7m
Kirjeldus
The 10G Passive SFP+ Twinaxial Direct Attach Cable is designed to support connections1 for 10 Gbps Gigabit Ethernet switches. DEM CB700S is equipped with SFP+ connectors, and is suitable for the distances up to 7 meters.
Ideal for High-Bandwidth Operations
The D-Link 10G Passive SFP+ Twinaxial Direct Attach Cable supports speeds of up to 10Gbps, while having lower latency and power consumption than other cables types such as 10GBASE-CX4 and CAT6/CAT6A 10GBASE-T. This makes it an optimal solution for handling high bandwidth transmission within short distances such as inside energy-efficient data centers.
1It is recommended that you only use the 10G Passive SFP+ Twinaxial Direct Attach Cable with D-Link products.
Põhiomadused
General
Device Rate
• 10 Gbps Gigabit Ethernet
Connector Type
• SFP+ Cable Assembly
Wire AWG
• 24 AWG
VMA Loss to Crosstalk Ratio (VCR)
• Min.: 32.5 dB
Physical
Minimum Cable Bend Radius
• 23.5 mm (0.93 inches)
Cable Characteristic Impedance
• 100 Ohms
Maximum Nominal Voltage
• 30 V AC
Operating Voltage
• 3.3 V DC
Current
• 0.5 А
Operating Temperature
• -40 to 85 °C (-40 to 185 °F)
Storage Temperature
Operating Humidity
• 45% to 75%
Storage Humidity
• 45% to 75%
Certifications
• SFP MSA (Multi-Source Agreement)
• SFF-8431
• EIA 364
• UL 94
Sertifikaadid
Sidustooted
DEM-CB700S 10G Passive SFP+ Twinaxial Direct Attach Cable, 7m
