DIR-815
AC1200 Wave 2 MU-MIMO Wi-Fi EasyMesh Router with 3G/LTE Support and USB Port
Apraksts
USB Port1
The router is equipped with a USB port for connecting a USB modem, which can be used to establish connection to the Internet. In addition, to the USB port of the router you can connect a USB storage device, which will be used as a network drive, or a printer.
In order to use the multifunction USB port effectively, the router supports simultaneous operation of several USB devices. For example, you can access multimedia content of the connected HDD storage and at the same time share a USB printer.2
Wireless Interface
Using the DIR-815 device, you are able to quickly create a high-speed wireless network at home or in your office, which lets computers and mobile devices access the Internet virtually anywhere (within the operational range of your wireless network). Simultaneous activity of 2.4GHz band and 5GHz band allows performing a wide range of tasks. The router can operate as a base station for connecting wireless devices of the standards 802.11a, 802.11b, 802.11g, 802.11n, and 802.11ac (at the wireless connection rate up to 1167Mbps3).
Secure Wireless Connection
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2/WPA34), MAC address filtering, WPS, WMM.
In addition, the device is equipped with a button for switching the Wi-Fi network off/on. If needed, for example, when you leave home, you can easily switch the router’s WLAN by pressing the button, and devices connected to the LAN ports of the router will stay online.1
The EasyMesh function1 is D-Link implementation of mesh networks designed to quickly connect several5 devices into one transport network, for example, when it's required to provide high-quality Wi-Fi coverage without dead zones in living units of complicated planning or it's needed to create a large temporary Wi-Fi network for an outdoor event.
Multi-user MIMO technology allows to distribute the router's resources to let multiple wireless clients use the Wi-Fi network efficiently, keeping high rates for HD media streaming, lag-free gaming, and fast transfer of large files.
Transmit Beamforming technology allows to flexibly change the antennas' radiation pattern and to redistribute the signal directly to wireless devices connected to the router.
Smart adjustment of Wi-Fi clients6 is useful for networks based on several D-Link access points or routers – when the smart adjustment function is configured on each of them, a client always connects to the access point (router) with the highest signal level.
Support of guest Wi-Fi network allows you to create a separate wireless network with individual security settings and maximum rate limitation. Devices connected to the guest network will be able to access the Internet, but will be isolated from the devices and resources of the router's LAN.
4-port Switch
The built-in 4-port switch enables you to connect Ethernet-enabled computers, game consoles, and other devices to your network.
Security
The wireless router DIR-815 includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
The SSH protocol1 support provides more secure remote configuration and management of the router due to encryption of all transmitted traffic, including passwords.
In addition, the router supports IPsec and allows to create secure VPN tunnels. Support of the IKEv2 protocol1 allows to provide simplified message exchange and use asymmetric authentication engine upon configuration of an IPsec tunnel.
The router also supports the SkyDNS web content filtering service1, which provides more settings and opportunities for safer Internet experience for home users of all ages and for professional activities of corporate users.
Now the schedules7 are also implemented; they can be applied to the rules and settings of the firewall and used to reboot the router at the specified time or every specified time period, to automatically save the configuration of the router to a connected USB storage, to set rules for limitation of wireless client maximum bandwidth, and to enable/disable the wireless network and the Wi-Fi filter.
Easy Configuration and Update
You can configure the settings of the wireless router DIR-815 via the user-friendly web-based interface (the interface is available in two languages – in Russian and in English).
The configuration wizard allows you to quickly switch DIR-815 to one of the following modes: router (for connection to a wired or wireless ISP), access point, repeater, or client, and then configure all needed setting for operation in the selected mode in several simple steps.
Also DIR-815 supports configuration and management via mobile application for Android smartphones.
You can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
1Only for DIR-815/R4.
2When using a USB hub with external power supply.
3Up to 300Mbps for 2.4GHz and up to 867Mbps for 5GHz.
4WPA3 is available only for DIR-815/R4.
5Up to 6 devices. Cooperation is supported for the following models: DIR-X1530/A1, DIR-X1510/R1, DIR-842V2/A1, DIR-842/R7, DIR-842/R5, DIR-842/S2, DIR-842/S1, DIR-842/R4, DIR-830M/A1, DIR-825/R7, DIR-825/R5, DIR-825/I1, DIR-825/R4, DIR-822/E1, DIR-822/R4, DIR-815/R4. Provided that the FW version supporting the EasyMesh function is used.
6Only for DIR-815/S.
7For DIR-815/S only reboot on schedule is available.
Īpašības
| DIR-815/R4 | DIR-815/S | |
				 Hardware
				 Processor
				 RTL8197FH-VG (1GHz)
				 RTL8197FN (1GHz)
				 RAM
				 128MB, DDR2, built in processor
				 64MB, DDR2, built in processor
				 Flash
				 128MB, NAND SPI
				 16MB, SPI
				 Interfaces
				 10/100BASE-TX WAN port
				4 10/100BASE-TX LAN ports
				USB 2.0 port
				 LEDs
				 Power
				Internet
				4 LAN LEDs
				WLAN 2.4G
				WLAN 5G
				WPS
				USB
				 Internet
				WLAN/WPS 2.4G
				WLAN/WPS 5G
				WAN
				4 LAN LEDs
				 Buttons
				 POWER button to power on/power off
				WIFI button to enable/disable wireless network
				WPS button to connect mesh network devices and set up wireless connection
				RESET button to restore factory default settings
				 RST/WPS button to restore factory default settings and set up wireless connection
				 Antenna
				 Four external non-detachable antennas
				 Four internal antennas
				 5dBi gain
				 3.5dBi gain
				 MIMO
				 2 x 2, MU-MIMO
				 Power connector
				 Power input connector (DC)
				 Mounting
				 Desktop
				Wall
				 Software
				 WAN connection types
				 Mobile Internet (via supported USB modem)
				 PPPoE
				 IPv6 PPPoE
				 PPPoE Dual Stack
				 Static IPv4 / Dynamic IPv4
				 Static IPv6 / Dynamic IPv6
				 PPPoE + Static IP / Dynamic IP (PPPoE Dual Access)
				 PPTP/L2TP + Static IP
				 PPTP/L2TP + Dynamic IP
				 Network functions
				 Support of IEEE 802.1X for Internet connection
				 DHCP server/relay
				 Advanced configuration of built-in DHCP server
				 Stateful/Stateless mode for IPv6 address assignment, IPv6 prefix delegation
				 Automatic obtainment of LAN IP address (for access point/repeater/client modes)
				 DNS relay
				 Dynamic DNS
				 Static IP routing
				 Static IPv6 routing
				 IGMP Proxy
				 MLD Proxy
				 RIP
| Support of UPnP |
				 Support of UPnP IGD
				 Support of VLAN
				 WAN ping respond
				 Support of SIP ALG
				 Support of RTSP
				 WAN failover
				 Autonegotiation of speed, duplex mode, and flow control/Manual speed and duplex mode setup for each Ethernet port
				 Setup of maximum TX rate for each port of the router
				 XUPNPD plug-in
				 Built-in UDPXY application
				 Firewall functions
				 Network Address Translation (NAT)
				 Stateful Packet Inspection (SPI)
				 IP filter
				 IPv6 filter
				 MAC filter
				 URL filter
				 Ad blocking function
				 DMZ
				 Prevention of ARP and DDoS attacks
				 Virtual servers
				 Built-in SkyDNS web content filtering service
				 VPN
				 IPsec/PPTP/L2TP/PPPoE pass-through
				 PPTP/L2TP tunnels
				 L2TP over IPsec client
				 IPsec tunnels
				 Transport/Tunnel mode
				 IKEv1 support
				 IKEv2 support
				 DES encryption
				 NAT Traversal
				 Support of DPD (Keep-alive for VPN tunnels)
				 USB interface functions
				 USB modem
				 Auto connection to available type of supported network (4G/3G/2G)
				 Auto configuration of connection upon plugging in USB modem
				 Enabling/disabling PIN code check, changing PIN code1
				 Sending/receiving/reading/removing SMS messages1
				 Support of USSD requests1
				 USB storage
				 File browser
				 Print server
				 Access to storage via accounts
				 Built-in Samba server
				 Built-in FTP server
				 Built-in DLNA server
				 Built-in Transmission torrent client; uploading/downloading files from/to USB storage
				 Management and monitoring
				 Local and remote access to settings through SSH
				 Local and remote access to settings through TELNET/WEB (HTTP/HTTPS)
				 Bilingual web-based interface for configuration and management (Russian/English)
				 Support of D-Link Assistant application for Android smartphones
				 Notification on connection problems and auto redirect to settings
				 Firmware update via web-based interface
				 Automatic notification on new firmware version
				 Saving/restoring configuration to/from file
				 Support of logging to remote host
				 Support of logging to connected USB storage
				 Automatic synchronization of system time with NTP server and manual time/date setup
				 Ping utility
				 Traceroute utility
				 TR-069 client
				 Automatic reboot on schedule
				 Schedules for rules and settings of firewall, automatic saving a configuration backup to a connected USB storage, limitation of wireless client maximum bandwidth, and enabling/disabling wireless network and Wi-Fi filter
				 Automatic upload of configuration file from ISP's server (Auto Provision)
				 Wireless Module Parameters
				 Standards
				 IEEE 802.11ac Wave 2
				IEEE 802.11a/b/g/n
				IEEE 802.11k/v
				IEEE 802.11w
				IEEE 802.11a/b/g/n
				 Frequency range
				The frequency range depends upon the radio frequency regulations applied in your country
				 2400 ~ 2483.5MHz
				5150 ~ 5350MHz
				5650 ~ 5850MHz
				 Wireless connection security
				 WEP
				 WPA/WPA2 (Personal/Enterprise)
				 WPA3 (Personal)
				 МАС filter
				 WPS (PBC/PIN)
				 Advanced functions
				 EasyMesh function
				 Support of client mode
				 WMM (Wi-Fi QoS)
				 Information on connected Wi-Fi clients
				 Advanced settings
				 Guest Wi-Fi / support of MBSSID
				 Rate limitation for wireless network/separate MAC addresses
				 Periodic scan of channels, automatic switch to least loaded channel
				 Support of 2.4GHz TX Beamforming
				 Support of 5GHz TX Beamforming
				 Autonegotiation of channel bandwidth in accordance with environment conditions (20/40 Coexistence)
				 Support of STBC
				 CoovaChilli authentication portal
				 Wireless connection rate
				 IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
				IEEE 802.11b: 1, 2, 5.5, and 11Mbps
				IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
				IEEE 802.11n (2.4GHz/5GHz): from 6.5 to 300Mbps (from MCS0 to MCS15)
				IEEE 802.11ac (5GHz): from 6.5 to 867Mbps (from MCS0 to MCS9)
				 Transmitter output power
			Less than 20dBm (100mW) |
				 2.4GHz
					5GHz
					Less than 17.5dBm (56.2mW)
				 802.11b
				 15dBm at 1, 11Mbps
				 16.5dBm at 1, 2, 5.5, 11Mbps
				 802.11g
				 15dBm at 6, 54Mbps
				 16.5dBm at 6, 9, 12, 18, 24, 36, 48Mbps
					15dBm at 54Mbps
				 802.11n
				 2.4GHz
					15dBm at MCS0/8, 7/15
					5GHz
				 2.4GHz
						HT20/HT40
						16.5dBm at MCS0/8~6/14
						16dBm at MCS7/15
						5GHz, HT20
						14dBm at MCS0/8~4/12
						13dBm at MCS5/13
						12.5dBm at MCS6/14
						12dBm at MCS7/15
						5GHz, HT40
						14dBm at MCS0/0~2/10
						13dBm at MCS3/11~4/12
						12.5dBm at MCS5/13~6/14
						12dBm at MCS7/15
				 802.11ac
				 15dBm at MCS0, 9
				 VHT20
					14dBm at MCS0~4
					13dBm at MCS5
					12.5dBm at MCS6
					12dBm at MCS7
					11dBm at MCS8
					VHT40
					14dBm at MCS0~2
					13dBm at MCS3~4
					12dBm at MCS5~6
					11dBm at MCS7/8/9
					VHT80
					14dBm at MCS0~4
					13dBm at MCS5~6
					12dBm at MCS7
					11dBm at MCS8/9
				 Receiver sensitivity
				 802.11a
				 -92dBm at 6Mbps
				-91dBm at 9Mbps
				-90dBm at 12Mbps
				-88dBm at 18Mbps
				-85dBm at 24Mbps
				-81dBm at 36Mbps
				-77dBm at 48Mbps
				-75dBm at 54Mbps
				 -82dBm at 6Mbps
				-81dBm at 9Mbps
				-79dBm at 12Mbps
				-77dBm at 18Mbps
				-74dBm at 24Mbps
				-70dBm at 36Mbps
				-66dBm at 48Mbps
				-65dBm at 54Mbps
				 802.11b
				 -95dBm at 1Mbps
				-91dBm at 2Mbps
				-90dBm at 5.5Mbps
				-87dBm at 11Mbps
				 -80dBm at 1Mbps
				-80dBm at 2Mbps
				-76dBm at 5.5Mbps
				-76dBm at 11Mbps
				 802.11g
				 -92dBm at 6Mbps
				-91dBm at 9Mbps
				-90dBm at 12Mbps
				-88dBm at 18Mbps
				-85dBm at 24Mbps
				-81dBm at 36Mbps
				-77dBm at 48Mbps
				-76dBm at 54Mbps
				 -82dBm at 6Mbps
				-81dBm at 9Mbps
				-79dBm at 12Mbps
				-77dBm at 18Mbps
				-74dBm at 24Mbps
				-70dBm at 36Mbps
				-66dBm at 48Mbps
				-65dBm at 54Mbps
				 802.11n
				 2.4GHz, HT20
					-92dBm at MCS0/8
					-90dBm at MCS1/9
					-87dBm at MCS2/10
					-84dBm at MCS3/11
					-81dBm at MCS4/12
					-77dBm at MCS5/13
					-75dBm at MCS6/14
					-74dBm at MCS7/15
					2.4GHz, HT40
					-88dBm at MCS0/8
					-86dBm at MCS1/9
					-84dBm at MCS2/10
					-81dBm at MCS3/11
					-77dBm at MCS4/12
					-73dBm at MCS5/13
					-71dBm at MCS6/14
					-70dBm at MCS7/15
					5GHz, HT20
					-91dBm at MCS0/8
					-90dBm at MCS1/9
					-88dBm at MCS2/10
					-84dBm at MCS3/11
					-81dBm at MCS4/12
					-76dBm at MCS5/13
					-75dBm at MCS6/14
					-73dBm at MCS7/15
					5GHz, HT40
					-90dBm at MCS0/8
					-87dBm at MCS1/9
					-84dBm at MCS2/10
					-81dBm at MCS3/11
					-78dBm at MCS4/12
					-73dBm at MCS5/13
					-72dBm at MCS6/14
					-70dBm at MCS7/15
				 HT20
				-82dBm at MCS0/8
				-79dBm at MCS1/9
				-77dBm at MCS2/10
				-74dBm at MCS3/11
				-70dBm at MCS4/12
				-66dBm at MCS5/13
				-65dBm at MCS6/14
				-64dBm at MCS7/15
				HT40
				-79dBm at MCS0/8
				-76dBm at MCS1/9
				-74dBm at MCS2/10
				-71dBm at MCS3/11
				-67dBm at MCS4/12
				-63dBm at MCS5/13
				-62dBm at MCS6/14
				-61dBm at MCS7/15
				 802.11ac
				 VHT20
				-91dBm at MCS0
				-89dBm at MCS1
				-87dBm at MCS2
				-84dBm at MCS3
				-81dBm at MCS4
				-76dBm at MCS5
				-75dBm at MCS6
				-74dBm at MCS7
				-69dBm at MCS8
				VHT40
				-90dBm at MCS0
				-87dBm at MCS1
				-84dBm at MCS2
				-81dBm at MCS3
				-78dBm at MCS4
				-73dBm at MCS5
				-72dBm at MCS6
				-71dBm at MCS7
				-66dBm at MCS8
				-64dBm at MCS9
				VHT80
				-87dBm at MCS0
				-83dBm at MCS1
				-81dBm at MCS2
				-78dBm at MCS3
				-74dBm at MCS4
				-70dBm at MCS5
				-69dBm at MCS6
				-67dBm at MCS7
				-63dBm at MCS8
				-62dBm at MCS9
				 VHT20
				-82dBm at MCS0
				-79dBm at MCS1
				-77dBm at MCS2
				-74dBm at MCS3
				-70dBm at MCS4
				-66dBm at MCS5
				-65dBm at MCS6
				-64dBm at MCS7
				-56dBm at MCS8
				VHT40
				-79dBm at MCS0
				-76dBm at MCS1
				-74dBm at MCS2
				-71dBm at MCS3
				-67dBm at MCS4
				-63dBm at MCS5
				-62dBm at MCS6
				-61dBm at MCS7
				-56dBm at MCS8
				-54dBm at MCS9
				VHT80
				-76dBm at MCS0
				-73dBm at MCS1
				-71dBm at MCS2
				-68dBm at MCS3
				-64dBm at MCS4
				-60dBm at MCS5
				-59dBm at MCS6
				-58dBm at MCS7
				-53dBm at MCS8
				-51dBm at MCS9
				 Modulation schemes
				 802.11a
				 BPSK, QPSK, 16QAM, 64QAM with OFDM
				 802.11b
				 DQPSK, DBPSK, DSSS, CCK
				 802.11g
				 802.11n
				 802.11ac
				 BPSK, QPSK, 16QAM, 64QAM, up to 256QAM with OFDM
				 Physical Parameters
				 Dimensions (L x W x H)
				 205 x 136 x 33 mm (8.07 x 5.35 x 1.3 in)
				 160 x 55 x 110 mm (6 x 2 x 4 in)
				 Weight
				 289 g (0.63 lb)
				 197 g (0.43 lb)
				 Operating Environment
				 Power
				 Output: 12V DC, 1A
				 Output: 12V DC, 0.5A
				 Temperature
				 Operating: from 0 to 40 °C
				Storage: from -20 to 65 °C
				 Humidity
				 Operating: from 10% to 90% (non-condensing)
				Storage: from 5% to 95% (non-condensing)
				 Delivery Package
				 Router DIR-815
				 Power adapter DC 12V/1A
				 Power adapter DC 12V/0.5A
				 Ethernet cable
				“Quick Installation Guide” (brochure)
				 Supported USB modems2
				 GSM
				 Alcatel X500
				 D-Link DWM-152C1
				 D-Link DWM-156A6
				 D-Link DWM-156A7
				 D-Link DWM-156A8
				 D-Link DWM-156C1
				 D-Link DWM-157B1
				 D-Link DWM-157B1 (Velcom)
				 D-Link DWM-158D1
				 D-Link DWR-710
				 Huawei E150
				 Huawei E1550
				 Huawei E156G
				 Huawei E160G
				 Huawei E169G
				 Huawei E171
				 Huawei E173 (Megafon)
				 Huawei E220
				 Huawei E3131 (MTS 420S)
				 Huawei E352 (Megafon)
				 Huawei E3531
				 Prolink PHS600
				 Prolink PHS901
				 ZTE MF112
				 ZTE MF192
				 ZTE MF626
				 ZTE MF627
				 ZTE MF652
				 ZTE MF667
				 ZTE MF668
				 ZTE MF752
				 LTE
				 Alcatel IK40V
| Brovi E3372-325 | + | – |
				 D-Link DWM-222
| D-Link DWR-910 (revision D1) | + | – |
				 Huawei E3131
				 Huawei E3272
				 Huawei E3351
				 Huawei E3372s
				 Huawei E3372h-153
				 Huawei E3372h-320
				 Huawei E367
				 Huawei E392
				 Megafon M100-1
				 Megafon M100-2
				 Megafon M100-3
				 Megafon M100-4
				 Megafon M150-1
				 Megafon M150-2
				 Megafon M150-3
| Megafon M150-4 | + | – |
				 MTS 824F
				 MTS 827F
				 Quanta 1K6E (Beeline 1K6E)
				 Yota LU-150
				 Yota WLTUBA-107
				 ZTE MF823
				 ZTE MF823D
				 ZTE MF827
				 ZTE MF833T
				 ZTE MF833V
				 Smartphones in USB tethering mode
				 Some models of Android smartphones
1For some models of USB modems.
2The manufacturer does not guarantee proper operation of the router with every modification of the firmware of USB modems.
Sertifikāti
Informācija pasūtījumam
DIR-815  AC1200 Wave 2 MU-MIMO Wi-Fi EasyMesh Router with 3G/LTE Support and USB Port
