DIR-879EOL EOS
Wireless AC1900 Dual Band Gigabit Router
Apraksts
Wireless Interface
Using the DIR-879 device, you are able to quickly create a high-speed wireless network at home or in your office, which lets computers and mobile devices access the Internet virtually anywhere (within the operational range of your wireless network). Simultaneous activity of 2.4GHz band and 5GHz band allows performing a wide range of tasks. The router can operate as a base station for connecting wireless devices of the standards 802.11a, 802.11b, 802.11g, 802.11n, and 802.11ac (at the wireless connection rate up to 1900Mbps1 ).
Secure Wireless Connection
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, WPS, WMM.
In addition, the device is equipped with a button for switching the Wi-Fi network off/on. If needed, for example, when you leave home, you can easily switch the router’s WLAN by pressing the button, and devices connected to the LAN ports of the router will stay online.
Support of guest Wi-Fi network allows you to create a separate wireless network with individual security settings and maximum rate limitation. Devices connected to the guest network will be able to access the Internet, but will be isolated from the devices and resources of the router's LAN.
Smart adjustment of Wi-Fi clients is useful for networks based on several D-Link access points or routers – when the smart adjustment function is configured on each of them, a client always connects to the access point (router) with the highest signal level.
Also the device is equipped with a two-position mode selector. You can leave DIR-879 in the router mode in order to connect devices to the Internet or switch it to the access point mode in order to create a new wireless network or extend the range of an existing wireless network.
Security
The wireless router DIR-879 includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
Built-in Yandex.DNS service protects against malicious and fraudulent web sites and helps to block access to adult content on children's devices.
Easy configuration and update
You can configure the settings of the wireless router DIR-879 via the user-friendly web-based interface (the interface is available in two languages – in Russian and in English).
The configuration wizard allows you to connect DIR-879 to a wired or wireless ISP (when switched to the router mode) in several simple steps or quickly set needed parameters for operation as an access point, repeater, or client (when switched to the access point mode).
You can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
1 Up to 600Mbps for 2.4GHz and up to 1300Mbps for 5GHz.
Īpašības
| Hardware | |
| Interfaces | • 10/100/1000BASE-T WAN port • 4 10/100/1000BASE-T LAN ports |
| LEDs | • POWER/WPS |
| Buttons | • POWER button to power on/power off • RESET button to restore factory default settings • WPS button to set up wireless connection and to enable/disable wireless network • Mode selector |
| Antenna | • Four external non-detachable antennas (3dBi gain for 2.4GHz and 5GHz) |
| MIMO | • 3 x 4 |
| Power connector | • Power input connector (DC) |
| Software | |
| Operation modes | • Router • Access point |
| WAN connection types | • PPPoE • IPv6 PPPoE • PPPoE Dual Stack • Static IP / Dynamic IP • Static IPv6 / Dynamic IPv6 • PPPoE + Static IP • PPPoE + Dynamic IP • PPTP/L2TP • PPTP/L2TP + Static IP • PPTP/L2TP + Dynamic IP |
| Network functions | • Support of IEEE 802.1X for Internet connection • DHCP server/relay • DHCPv6 server (Stateful/Stateless), IPv6 prefix delegation • DNS relay • Support of DNSv6 AAAA records • Dynamic DNS • Static IP routing • Static IPv6 routing • IGMP Proxy • RIP • Support of UPnP IGD • Support of VLAN • WAN ping respond • Support of SIP ALG • Support of RTSP • Autonegotiation of speed, duplex mode, and flow control/Manual speed and duplex mode setup for each Ethernet port • Setup of maximum TX rate for each port of the router • Built-in UDPXY application |
| Firewall functions | • Network Address Translation (NAT) • Stateful Packet Inspection (SPI) • IP filter • IPv6 filter • MAC filter • URL filter • DMZ • Prevention of ARP and DDoS attacks • Virtual servers • Built-in Yandex.DNS web content filtering service |
| VPN | • IPSec/PPTP/L2TP/PPPoE pass-through • IPSec tunnels |
| Management | • Local and remote access to settings through TELNET/WEB (HTTP/HTTPS) • Bilingual web-based interface for configuration and management (Russian/English) • Notification on connection problems and auto redirect to settings • Firmware update via web-based interface • Automatic notification on new firmware version • Saving/restoring configuration to/from file • Automatic synchronization of system time with NTP server and manual time/date setup • Ping function • Traceroute utility • TR-069 client |
| Wireless Module Parameters | |
| Standards | • IEEE 802.11a/n/ac • IEEE 802.11b/g/n |
| Frequency range | • 2400 ~ 2483.5MHz • 5150 ~ 5350MHz • 5650 ~ 5725MHz |
| Wireless connection security | • WEP • WPA/WPA2 (Personal/Enterprise) • МАС filter • WPS (PBC/PIN) |
| Advanced functions | • “Client” function (router mode) WISP repeater • “Client” function (access point mode) Wireless network client Wireless network repeater • WMM (Wi-Fi QoS) • Information on connected Wi-Fi clients • Advanced settings • Smart adjustment of Wi-Fi clients • Guest Wi-Fi / support of MBSSID • Limitation of wireless network rate |
| Wireless connection rate1 | • IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48, and 54Mbps • IEEE 802.11b: 1, 2, 5.5, and 11Mbps • IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps • IEEE 802.11n (2.4GHz): 6,5–450Mbps (MCS0–MCS23) to 600Mbps (QAM256) • IEEE 802.11n (5GHz): from 6,5 to 450Mbps (from MCS0 to MCS23) • IEEE 802.11ac: from 6,5 to 1300Mbps (from MCS0 to MSC9) |
| Transmitter output power The maximum value of the transmitter output power depends upon the radio frequency regulations applied in your country | • 802.11a (typical at room temperature 25 °C) 17dBm at 6, 9, 12, 18, 24, 36, 48, 54Mbps • 802.11b (typical at room temperature 25 °C) 17dBm at 1, 2, 5.5, 11Mbps • 802.11g (typical at room temperature 25 °C) 17dBm at 6, 9, 12, 18, 24, 36, 48, 54Mbps • 802.11n (typical at room temperature 25 °C) 2.4GHz, HT20/HT40 17dBm at MCS0~7 5GHz, HT20/HT40 17dBm at MCS0~7 • 802.11ac (typical at room temperature 25 °C) VHT20 17dBm at MCS0~8 VHT40 17dBm at MCS0~9 VHT80 17dBm at MCS0~9 |
| Receiver sensitivity | • 802.11a (typical at PER = 10% (1000-byte PDUs) at room temperature 25 °C) -93dBm at 6Mbps -92dBm at 9Mbps -91dBm at 12Mbps -89dBm at 18Mbps -85dBm at 24Mbps -81dBm at 36Mbps -77dBm at 48Mbps -76dBm at 54Mbps • 802.11b (typical at PER = 8% (1000-byte PDUs) at room temperature 25 °C) -94dBm at 1, 2, 5.5Mbps -91dBm at 11Mbps • 802.11g (typical at PER = 10% (1000-byte PDUs) at room temperature 25 °C) -89dBm at 6, 9, 12Mbps -88dBm at 18Mbps -85dBm at 24Mbps -82dBm at 36Mbps -77dBm at 48Mbps -76dBm at 54Mbps • 802.11n (typical at PER = 10% (1000-byte PDUs)) 2.4GHz, HT20 -89dBm at MCS0/1/8/9 -88dBm at MCS2/10 -84dBm at MCS3/11 -81dBm at MCS4/12 -76dBm at MCS5/13 -74dBm at MCS6/14 -73dBm at MCS7/15 2.4GHz, HT40 -87dBm at MCS0/8 -86dBm at MCS1/9 -85dBm at MCS2/10 -81dBm at MCS3/11 -78dBm at MCS4/12 -73dBm at MCS5/13 -71dBm at MCS6/14 -70dBm at MCS7/15 5GHz, НТ20 -93dBm at MCS0/8/16 -90dBm at MCS1/9/17 -88dBm at MCS2/10/18 -84dBm at MCS3/11/19 -80dBm at MCS4/12/20 -76dBm at MCS5/13/21 -75dBm at MCS6/14/22 -73dBm at MCS7/15/23 5GHz, НТ40 -90dBm at MCS0/8/16 -88dBm at MCS1/9/17 -85dBm at MCS2/10/18 -81dBm at MCS3/11/19 -78dBm at MCS4/12/20 -73dBm at MCS5/13/21 -72dBm at MCS6/14/22 -71dBm at MCS7/15/23 • 802.11ac (typical at PER = 10% (1000-byte PDUs)) HT20 -93dBm at MCS0 -90dBm at MCS1 -88dBm at MCS2 -84dBm at MCS3 -80dBm at MCS4 -76dBm at MCS5 -75dBm at MCS6 -73dBm at MCS7 -69dBm at MCS8 HT40 -90dBm at MCS0 -88dBm at MCS1 -85dBm at MCS2 -81dBm at MCS3 -78dBm at MCS4 -73dBm at MCS5 -72dBm at MCS6 -71dBm at MCS7 -66dBm at MCS8 -64dBm at MCS9 HT80 -87dBm at MCS0 -84dBm at MCS1 -81dBm at MCS2 -77dBm at MCS3 -73dBm at MCS4 -70dBm at MCS5 -68dBm at MCS6 -67dBm at MCS7 -63dBm at MCS8 -60dBm at MCS9 |
| Modulation schemes | • 802.11a: BPSK, QPSK, 16QAM, 64QAM with OFDM • 802.11b: DQPSK, DBPSK, CCK • 802.11g: BPSK, QPSK, 16QAM, 64QAM with OFDM • 802.11n: BPSK, QPSK, 16QAM, 64QAM with OFDM • 802.11ac: BPSK, QPSK, 16QAM, 64QAM, 256QAM with OFDM |
| Physical Parameters | |
| Dimensions (L x W x H) | • 240 x 199 x 69 mm (9.45 x 7.83 x 2.72 in) |
| Weight | • 750 g (1.65 lb) |
| Operating Environment | |
| Power | • Output: 12V DC, 2A |
| Temperature | • Operating: from 0 to 40 °C • Storage: from -20 to 65 °C |
| Humidity | • Operating: from 10% to 90% (non-condensing) • Storage: from 5% to 95% (non-condensing) |
1Maximum wireless signal rate is derived from IEEE standard 802.11ac and 802.11n specifications. In order to get the rate of 600Mbps in the 2.4GHz band, a Wi-Fi client should support MIMO 3x3 and QAM256 modulation scheme. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
Sertifikāti
Informācija pasūtījumam
DIR-879 Wireless AC1900 Dual Band Gigabit Router
