Ātrā meklēšana
Produkta iespējas:
Wi-Fi AC750 Portable Router and Charger
Īpašības:
Device Interfaces
• 802.11 a/b/g/n/ac Wireless LAN, up to 750 Mbps***
• WAN 10/100 Ethernet port
• WPS button
• Power switch
• Reset button
• USB 2.0 Type A port (1 A) for compatible 3G/4G adapters****, USB drive, or charging other devices
• USB 2.0 Type A port (0.5 A) for USB drive or DCS-300
• Power port (MicroUSB)
LEDs
• Power/Status
• Battery status
Standards
• IEEE 802.11ac (draft)
• IEEE 802.11n
• IEEE 802.11b
• IEEE 802.11g
• IEEE 802.11a
• IEEE 802.3
• IEEE 802.3x
• IEEE 802.3u
• USB 2.0
Internet Modes
• Broadband Router Mode
• Mobile Router Mode
• Wi-Fi Hotspot Mode
Power Modes
• On/Off/Charger*****
Wireless Frequency Range
• IEEE 802.11a: 5150 MHz ~ 5850 MHz
• IEEE 802.11b: 2400 ~ 2497 MHz in ISM band
• IEEE 802.11g: 2400 ~ 2483.5 MHz in ISM band
• IEEE 802.11n (2.4 GHz): 2400 ~ 2483.5 MHz in ISM band
• IEEE 802.11n (5 GHz): 5180 MHz ~ 5320 MHz, 5745 MHz ~ 5825 MHz
• IEEE 802.11ac (draft) (5 GHz): 5180 MHz ~ 5320 MHz, 5745 MHz ~ 5825 MHz
Wireless speed
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit/s
• IEEE 802.11b: 1, 2, 5.5 and 11 Mbit/s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit/s
• IEEE 802.11n (5 GHz): 6.5 ~ 150 Mbit/s
Transmitter output power
• IEEE 802.11a:
  17 dBm (+/-1 dB) at 6-18 Mbit/s
  16 dBm m (+/-1 dB) at 24-36 Mbit/s
  14 dBm (+/-1 dB) at 48-54 Mbit/s
• IEEE 802.11b: 17 dBm at 1, 2, 5.5, 11 Mbit/s
• IEEE 802.11g:
  18 dBm at 6-18 Mbit/s
  16 dBm at 24-36 Mbit/s
  14 dBm at 48-54 Mbit/s
• IEEE 802.11n (5 GHz band):
  17 dBm (+/-1 dB) at MCS0
  17 dBm (+/-1 dB) at MCS1
  17 dBm (+/-1 dB) at MCS2
  17 dBm (+/-1 dB) at MCS3
  16 dBm (+/-1 dB) at MCS4
  16 dBm (+/-1 dB) at MCS5
  14 dBm (+/-1 dB) at MCS6
  14 dBm (+/-1 dB) at MCS7
• IEEE 802.11n (2.4 GHz band):
  18 dBm at MCS0
  18 dBm at MCS1
  18 dBm at MCS2
  18 dBm at MCS3
  16 dBm at MCS4
  16 dBm at MCS5
  14 dBm at MCS6
  14 dBm at MCS7
  21 dBm at MCS8
  21 dBm at MCS9
  21 dBm at MCS10
  21 dBm at MCS11
  19 dBm at MCS12
  19 dBm at MCS13
  17 dBm at MCS14
  17 dBm at MCS15
• IEEE 802.11ac (5 GHz band):
  17 dBm at MCS0
  17 dBm at MCS1
  17 dBm at MCS2
  17 dBm at MCS3
  16 dBm at MCS4
  16 dBm at MCS5
  14 dBm at MCS6
  14 dBm at MCS7
  13 dBm at MCS8
  13 dBm at MCS9
Receiver sebsitivity
• IEEE 802.11a:
  –91 dBm at 6 Mbit/s
  –90 dBm at 9 Mbit/s
  –89 dBm at 12 Mbit/s
  –87 dBm at 18 Mbit/s
  –83 dBm at 24 Mbit/s
  –80 dBm at 36 Mbit/s
  –76 dBm at 48 Mbit/s
  –75 dBm at 54 Mbit/s
• IEEE 802.11b:
  –86 dBm at 1 Mbit/s
  –86 dBm at 2 Mbit/s
  –85 dBm at 5.5 Mbit/s
  –84 dBm at 11
• IEEE 802.11g:
  –84 dBm at 6 Mbit/s
  –84 dBm at 9 Mbit/s
  –83 dBm at 12 Mbit/s
  –80 dBm at 18 Mbit/s
  –78 dBm at 24 Mbit/s
  –74 dBm at 36 Mbit/s
  –70 dBm at 48 Mbit/s
  –69 dBm at 54 Mbit/s
• IEEE 802.11n:
  HT20
  -89 dBm at BPSK, encoding rate 1/2 (MCS-0)
  -87 dBm at QPSK, encoding rate 1/2 (MCS-1)
  -85 dBm at QPSK, encoding rate 3/4 (MCS-2)
  -84 dBm at 16-QAM, encoding rate 1/2 (MCS-3)
  -80 dBm at 16-QAM, encoding rate 3/4 (MCS-4)
  -76 dBm at 64-QAM, encoding rate 2/3 (MCS-5)
  -74 dBm at 64-QAM, encoding rate 3/4 (MCS-6)
  -73 dBm at 64-QAM, encoding rate 5/6 (MCS-7)
  HT40
  -86 dBm at BPSK, encoding rate 1/2 (MCS-8)
  -85 dBm at QPSK, encoding rate 1/2 (MCS-9)
  -83 dBm at QPSK, encoding rate 3/4 (MCS-10)
  -81 dBm at 16-QAM, encoding rate 1/2 (MCS-11)
  -78 dBm at 16-QAM, encoding rate 3/4 (MCS-12)
  -72 dBm at 64-QAM, encoding rate 2/3 (MCS-13)
  -71 dBm at 64-QAM, encoding rate 3/4 (MCS-14)
  -69 dBm at 64-QAM, encoding rate 5/6 (MCS-15)
  HT-20
  -84 dBm at 16-QAM, encoding rate /2 (MCS-3)
  HT-40
  HT-20
  -83 dBm at BPSK, encoding rate 1/2 (MCS-0)
  -82 dBm at QPSK, encoding rate 1/2 (MCS-1)
  -81 dBm at QPSK, encoding rate 3/4 (MCS-2)
  -77 dBm at 16-QAM, encoding rate 1/2 (MCS-3)
  -74 dBm at 16-QAM, encoding rate 3/4 (MCS-4)
  -72 dBm at 64-QAM, encoding rate 2/3 (MCS-5)
  -69 dBm at 64-QAM, encoding rate 3/4 (MCS-6)
  -68 dBm at 64-QAM, encoding rate 5/6 (MCS-7)
  HT-40
  -82 dBm at BPSK, encoding rate 1/2 (MCS-8)
  -82 dBm at QPSK, encoding rate 1/2 (MCS-9)
  -80 dBm at QPSK, encoding rate 3/4 (MCS-10)
  -77 dBm at 16-QAM, encoding rate 1/2 (MCS-11)
  -73 dBm at 16-QAM, encoding rate 3/4 (MCS-12)
  -68 dBm at 64-QAM, encoding rate 2/3 (MCS-13)
  -68 dBm at 64-QAM, encoding rate 3/4 (MCS-14)
  -66 dBm at 64-QAM, encoding rate 5/6 (MCS-15)
  HT-20
  -81 dBm at 16-QAM, encoding rate 1/2 (MCS-3)
  -78 dBm at 16-QAM, encoding rate 3/4 (MCS-4)
  -74 dBm at 64-QAM, encoding rate 2/3 (MCS-5)
  -72 dBm at 64-QAM, encoding rate 3/4 (MCS-6)
  -71 dBm at 64-QAM, encoding rate 5/6 (MCS-7)
  -66 dBm at 256-QAM, encoding rate 3/4 (MCS-8)
  HT-40
  -86 dBm at BPSK, encoding rate 1/2 (MCS-0)
  -84 dBm at QPSK, encoding rate 1/2 (MCS-1)
  -82 dBm at QPSK, encoding rate 3/4 (MCS-2)
  -78 dBm at 16-QAM, encoding rate 1/2 (MCS-3)
  -76 dBm at 16-QAM, encoding rate 3/4 (MCS-4)
  -71 dBm at 64-QAM, encoding rate 2/3 (MCS-5)
  -70 dBm at 64-QAM, encoding rate 3/4 (MCS-6)
  -63 dBm at 256-QAM, encoding rate 3/4 (MCS-8)
  -61 dBm at 256-QAM, encoding rate 5/6 (MCS-9)
  HT-80
  -81 dBm at QPSK, encoding rate 1/2 (MCS-1)
  -79 dBm at QPSK, encoding rate 3/4 (MCS-2)
  -75 dBm at 16-QAM, encoding rate 1/2 (MCS-3)
  -72 dBm at 16-QAM, encoding rate 3/4 (MCS-4)
  -68 dBm at 64-QAM, encoding rate 2/3 (MCS-5)
  -66 dBm at 64-QAM, encoding rate 3/4 (MCS-6)
  -65 dBm at 64-QAM, encoding rate 5/6 (MCS-7)
  -60 dBm at 256-QAM, encoding rate 3/4 (MCS-8)
  -58 dBm at 256-QAM, encoding rate 5/6 (MCS-9)
Antennas
• Internal antennas
Sharing Features******
• mydlink SharePort app
  • App supports iPhone®, iPad®, iPod touch®, and Android™ devices
  • Remote Access Mode: Access files through the Internet*******
  • Local Access Mode: Access files from any device connected to the DIR-510L
• SharePort Web Access support (Web browser)
  • Access files from any device connected to the DIR-510L
• SharePort Mobile app support for Windows® 8/RT devices
Security
• Wi-Fi Protected Access (WPA/WPA2)
• WEP 64/128-bit encryption********
• WPS 2.0 (PBC)
Advanced Features
• Guest Zone support
• IPv6
• Wi-Fi WMM Quality of Service (QoS)
• UPnP support
• DLNA Media Server**
Advanced Firewall Features
• MAC address filtering
Device Management
• User-friendly Web UI with desktop and mobile interfaces
Fiziskie raksturlielumi
Dimensions
• 140.0 x 59.0 x 16.0 mm
Weight
• 154 g
Power
• Built-in 4000 mAh Li-ion rechargeable battery
• Input: 5 V DC/1.8 A maximum (standard adapter);
• Output: 5 V/1 A via USB Type A port, 5 V/0.5 A via USB Type A port
Temperature
• Operating: 0 to 40 °C
• Storage: -10 to 45 °C
Humidity
• Operating: 10% to 75% non-condensing
• Storage: 5% to 75% non-condensing
Certifications
• FCC
• CE
• IC
• C-Tick
• NCC
• cUL
• LVD
• BSMI
* Available in a future update.
** Actual usable capacity may vary depending on charging conditions.
*** Maximum wireless signal rate derived from IEEE standard specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
**** For a list of compatible 3G/4G USB adapters, check your local D-Link website.
***** The DIR-510L only supports charging on the USB port (1 A) in CHARGER mode.
****** If you have attached one or more USB devices (such as a 2.5” USB hard drive) that draw a total of 0.7 A or more power, the power adapter will not supply enough voltage to charge your DIR-510L while simultaneously powering the USB devices.
******* For an optimal streaming experience, 2 MB of upload bandwidth is recommended.
******** For WAN connection to a Wi-Fi hotspot in hotspot mode only.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
